how to disabl FlashGet
All Forums >> [ISA 2006 General] >> General >> how to disabl FlashGet Page: [1]
how to disabl FlashGet - 5.Aug.2008 5:01:52 AM
b_karimi
Hi Dear Friends
I have installed  ISA Server 2006 SE  on windows server 2003 enterprise sp1
with 2 NIC's  i dont use active directory  and i dont use authentication
we have  firewall and webproxy Clients , some of my users , install flashget and download .zip and .rar and .exe  files and i cann,t block them
Mr  tshinder  i have learned a lot of things from your books and posts but i am a beginner to isa server it is nice of you if you answer my question
thanks a lot
RE: how to disabl FlashGet - 6.Aug.2008 1:08:10 PM
You can configure the HTTP Security Filter to block by file extension.
(in reply to b_karimi)
RE: how to disabl FlashGet - 6.Aug.2008 2:31:34 PM
M_Fairouz
1. you can configure your http rule to block download , using extention tab, add there the extention u would like to block
2.or u can use content type
good luck ,
RE: how to disabl FlashGet - 7.Aug.2008 5:15:21 AM
b_karimi
thanks a lot for your help
but flashget bypasses all extension  limits
i have limited RAR EXE and ZIP  file extensions but it does not work
(in reply to M_Fairouz)
RE: how to disabl FlashGet - 8.Aug.2008 9:47:49 AM
Try blocking the flashget user-agent string.
RE: how to disabl FlashGet - 13.Aug.2008 9:58:53 AM
b_karimi
thanks a lot Mr Tom
i have blocked flashget user-agent script ( it is FlashGet ) but unfortunately it doesnot help  !!!
they still can bypass my isa and download forbidden extensions
RE: how to disabl FlashGet - 15.Aug.2008 8:38:42 AM
How did you implement the block?
The ISA firewall is configured in full firewall mode, right?
RE: how to disabl FlashGet - 22.Aug.2008 10:43:41 AM
b_karimi
thanks a lot again
how can i determin . if isa server is configured as full firewall or not?
My network is a WORKGROUP
isa server has 2 NICs one conected to EXT. network and the other to INT. network
< Message edited by b_karimi -- 22.Aug.2008 10:48:09 AM >
RE: how to disabl FlashGet - 24.Aug.2008 12:38:17 PM
Are the machines configured as Web Proxy clients of the ISA firewall. The two NIC setup shows that full firewall mode is probably configured.
RE: how to disabl FlashGet - 25.Aug.2008 5:47:52 AM
b_karimi
Hello Mr Shinder
i have installed   FireWall Client   on some of the machines and the others are configured as WebProxy clients but i did't configure SecureNat clients
but i see some SecureNat Connections in isa server monitoring  " Session " Tab
as i mentioned earlier my network is a Workgroup Network not a Domain
Thanks Again
RE: how to disabl FlashGet - 25.Aug.2008 9:44:31 AM
OK, maybe the HTTP Security Filter wasn't configured correctly. What are the exact details of the entry?
