how to filter porn sites?
how to filter porn sites? - 26.Mar.2004 3:12:00 AM
Sophorn
Dear All, Any one know how to set ISA to deny all porn sites? or set a certain time to deny?
Any help would be appreciated.
Thanks Sophorn
RE: how to filter porn sites? - 27.Mar.2004 5:44:00 PM
Hi Sophorn,
You can do it any way you like. Keywords in the page, keywords in the URL. Its up to you! You can block just about thing you want using the HTTP filter.
HTH, Tom
RE: how to filter porn sites? - 31.Mar.2004 2:09:00 PM
skidrow52
Tom can you please tell the procedure for blocking keywords?
Thanks Adnan
RE: how to filter porn sites? - 1.Apr.2004 6:05:00 AM
Hi Adnan,
Right click your Access rule, and click the HTTP policy. You'll be able to create strings or "signatures" there.
HTH, Tom
RE: how to filter porn sites? - 9.Apr.2004 4:41:00 AM
Hey guys,
Just use the HTTP filter to begin with. Its very powerful and you can enter keywords to control access to any site with any content using any HTTP directives.
HTH, Tom
RE: how to filter porn sites? - 15.Apr.2004 11:50:00 PM
susinger
is there any way to import the filter lists of isa2000 ?
RE: how to filter porn sites? - 19.Apr.2004 11:30:00 AM
Hi Stusi,
You can use the upgrade wizard and all that information should be migrated to a URL set.
HTH, Tom
RE: how to filter porn sites? - 22.Apr.2004 9:40:00 PM
penrose.l@2college.nl
Hi ,
There is some opensource webfilters based on .vbs scripts that will import and open-source webfilter listing ( something like a virus-update but then with websites ) that is updated weekly with sub types of content ( porn / games / violence / etc.. ) that you can then give rules within ISA.
As far as I know if should work with ISA 2004.
Here , have a look :
http://www.squidguard.org/ -> for the listings http://www.gslahr.og.bw.schule.de/ml/tools/webfilter-v0.94b.exe
for the filter.
Let me know if you run into any problems ! Kind regards, Lex P.
RE: how to filter porn sites? - 24.Apr.2004 11:49:00 PM
Hey Tom ,
could you mail that script to me ? <nospam> Kind regards, Lex Penrose. [ October 08, 2004, 05:41 PM: Message edited by: Lex Penrose ]
RE: how to filter porn sites? - 25.Apr.2004 3:26:00 PM
Hi Lex,
Will do!
Thanks! Tom
RE: how to filter porn sites? - 3.May2004 8:23:00 PM
susinger
hi tom, i also would like to get this script. thor_hg@yahoomail.de
thanks a lot !
RE: how to filter porn sites? - 4.May2004 11:55:00 AM
Hey guys,
Send me a note at tshinder@isaserver.org and I'll send it to you.
HTH, Tom
RE: how to filter porn sites? - 4.Aug.2004 2:57:00 PM
Tea
HTH, Tom
I sent a note to you from email: ductra19@yahoo.com, but have not received your script yet.
Hic, Hope receive your email soon.
Regards.
RE: how to filter porn sites? - 4.Aug.2004 2:58:00 PM
Tea
HTH, Tom
Regards.
RE: how to filter porn sites? - 5.Aug.2004 1:03:00 PM
Hi Tea,
I don't see the email from you. Did you send it, or did I send it to another address?
Thanks! Tom
RE: how to filter porn sites? - 10.Aug.2004 4:23:00 PM
Tom: (I sent you a note for this script) but one thing... where do the URL sets end up in ISA2004?
I wanted to experiment and create a list manually, but the only import option I have is via an XML config document. All I have is the text file URL list, which I want to pull in.
How can this be done in ISA2004 by hand?
Vic
RE: how to filter porn sites? - 11.Aug.2004 12:15:00 AM
Hi Vic,
Look in the toolbox for the URL Sets entries.
Did you get the script?
Thannks! Tom
RE: how to filter porn sites? - 11.Aug.2004 4:29:00 AM
Thannks! Tom
