howto add/remove computer sets from a rule with ASP(vbscript) webpages
All Forums >> [ISA Server 2004 Misc.] >> ISA Server 2004 Programming >> howto add/remove computer sets from a rule with ASP(vbscript) webpages Page: [1]
howto add/remove computer sets from a rule with ASP(vbs... - 9.May2005 3:46:00 PM
browolf
I've got the sdk with its horrible manual.
I've managed to figure out adding, but removing is another matter. cant find any samples that deal with removing items not whole rules. It doesnt seem to be as simple as changing .add into .remove
code:
'to add room T10 to rule
sub controlcomputers()
dim root
set root = CreateObject("FPC.Root")
dim array
dim policyrules
dim computersets
dim pupilrule
set array = root.GetContainingArray
set policyrules = array.ArrayPolicy.PolicyRules
set computrsets = array.RuleElements.ComputerSets
set pupilrule = policyrules.item("Pupil Access")
pupilrule.SourceSelectionIPs.computersets.add "T10", fpcinclude
pupilrule.save
CheckError
wscript.echo "Done!"
end sub
sub CheckError()
if Err.Number <> 0 then
wscript.echo "An error occurred: 0x" & hex(err.number) & " " & err.Description
err.clear
end if
end sub
controlcomputers
[ June 21, 2005, 07:31 AM: Message edited by: browolf ]
RE: howto add/remove computer sets from a rule with ASP... - 9.May2005 4:25:00 PM
browolf
eventually, 45mins, i've worked out to replace .remove with .removespecified
code:
dim root
dim array
dim policyrules
dim computersets
dim pupilrule
pupilrule.SourceSelectionIPs.computersets.removespecified "T10"
pupilrule.save
CheckError
end sub
sub CheckError()
if Err.Number &lt;&gt; 0 then
err.clear
end if
end sub
controlcomputers
[ May 09, 2005, 05:01 PM: Message edited by: browolf ]
(in reply to browolf)
RE: howto add/remove computer sets from a rule with ASP... - 9.May2005 5:00:00 PM
browolf
i've got it to enumerate which computersets are added to the rule.
code:
dim root
dim array
dim policyrules
dim computersets
dim pupilrule
set computersets = pupilrule.SourceSelectionIPs.ComputerSets
for each blag in computersets
wscript.echo blag.Name
next
pupilrule.save
CheckError
end sub
sub CheckError()
err.clear
end if
end sub
controlcomputers
i found a typo, but luckily it was in a line not in use in the previous scripts.
RE: howto add/remove computer sets from a rule with ASP... - 10.May2005 9:47:00 AM
browolf
to list the computersets attached to a rule:
code:
next
to list all the computersets that exist
code:
 set computersets = array.RuleElements.ComputerSets
next
RE: howto add/remove computer sets from a rule with ASP... - 15.Jun.2005 4:30:00 AM
browolf
a combination of above that i'm going to run as a scheduled task to remove all the tcomputer sets from the rule at specified times.
code:
dim root
dim array
dim policyrules
dim computersets
dim pupilrule
pupilrule.SourceSelectionIPs.computersets.removespecified blag.Name
next
pupilrule.save
CheckError
end sub
sub CheckError()
err.clear
end if
end sub
controlcomputers
RE: howto add/remove computer sets from a rule with ASP... - 15.Jun.2005 8:38:00 AM
browolf
webpages to control what computer sets can access the internet. these pages only apply to a specific rule. in order for users to control access e.g. teachers in a school (my case) it appears you have to give them admin rights on the isa server.
index.asp
enumerates the names of all the possible computer sets into a form. if len(blag.name) < 6 then excludes the builtin sets. anything you dont want appearing on the form you can just make the name longer than 6 chars.
Any set currently set to 'on' has a ticked box.
code:
dim root
dim array
dim policyrules
dim computersets
dim pupilrule
dim onsets
set onsets = pupilrule.SourceSelectionIPs.ComputerSets
dim found,tmp
found = false
'tmp =
if setlookup(blag.name,onsets) then
Response.write "<input type='checkbox' name='room' value='" & blag.Name & "' checked>" & blag.name & "<br>"
else
Response.write "<input type='checkbox' name='room' value='" & blag.Name & "'>" & blag.name & "<br>"
end if
end if
next
pupilrule.save
CheckError
'wscript.echo "Done!"
end sub
sub CheckError()
Response.write "An error occurred: 0x" & hex(err.number) & " " & err.Description
err.clear
end if
end sub
function setlookup(lookupname,lookinto)
'response.write "function start" & lookupname & "<p>"
for each item in lookinto
if item.name=lookupname then
'response.write item.name & " true "
setlookup = true
exit function
end if
'response.write item.name & " false "
next
setlookup = false
end function
<style type="text/css">
.style6 {
font-size: 36px;
font-family: Arial, Helvetica, sans-serif;
color: #003300;
font-weight: bold;
.style7 {font-family: Arial, Helvetica, sans-serif}
</style>
<p class="style6">Internet Room Management </p>
<hr noshade>
<span class="style7">Ticked = Internet allowed in that room
</span>
<form action="process.asp" method="get">
<p>
<!-- <input type="checkbox" name="checkbox" value="check"> -->
<% controlcomputers %>
</p>
<p>&nbsp;</p>
<p>
<input type="submit" name="Submit" value="Submit">
</p>
</form>
process.asp
removes everything and then adds the ticked boxes passed from the previous page.
re-asks what is 'on' and lists the results.
if you have a set that contains pcs that are always 'on' its easier to put it on a separate rule.
code:
sub processform()
dim root
dim array
dim policyrules
dim computersets
dim pupilrule
'response.write blag.Name
next
for each itemx in request.querystring("room")
pupilrule.SourceSelectionIPs.computersets.add itemx, fpcinclude
'response.write itemx
next
pupilrule.save
CheckError
response.write "Validating...access allowed at: "
for each blagx in computersets
response.write blagx.Name & " "
next
end sub
sub CheckError()
err.clear
end if
end sub
.style6 {
font-size: 36px;
color: #003300;
font-weight: bold;
</style>
<p class="style6">Internet Room Management Processed</p>
<hr noshade>
<span class="style7">Ticked = Internet allowed in that room<p>
</span>
<% processform %>
