https in ISA
All Forums >> [ISA Server 2004 General ] >> ISA 2004 SBS >> https in ISA Page: [1]
https in ISA - 11.Nov.2007 11:21:57 PM
pwintho
Hi
I am trying to setup the firewall policy rule in ISA2004 to resrtrict a
group of users to be able to use certain websites only.
Every other web sites tested fine but all with https, I cant apply the rule.
The two example https web sites are
https://iescr.hpa.com.au/txu/reprint and
https://accessinfo.com.au.
I have tried *iescr.hpa.com.au/txu/reprint/* and *accessinfo.com.au/* and
both doesnt work. I have alook at the website on miscrosoft which says For
URL set entry:
“a.com", HTTPS requests will be matched, because no path is specified
".com/", HTTPS requests will not be ".com/", HTTPS requests will not be.
My setup in policy as below as I cant copy the screenshots to here.
     name           Action        Protocols       From/listener               To                                 Condition
2    Research     allow           FTP                all networks (and         excepted sites             restriced
      internet                                                    local host)                                                          users
     use                                   FTP server
                                              HTTP
                                              HTTPS
                                              HTTPS SERVER
I dont know what to do with my case. Any suggestion will be grateful. Many
thanks.
RE: https in ISA - 12.Nov.2007 11:04:49 AM
Rotorblade
It's not going to work. You can't use URL sets that contain SSL links. (It's encrypted!) You need to use a Domain name set instead.
The other option would be to use Clear Tunnel -> https://www.collectivesoftware.com/Products/
HTH
RB
(in reply to pwintho)
RE: https in ISA - 12.Nov.2007 2:26:53 PM
Rotorblade
Further more....
    use                                   FTP server
                                             HTTP
                                             HTTPS
                                             HTTPS SERVER
You should remove the HTTPS Server and FTP Server protocol definitions from your outbound access rules. Inbound protocols should never be combined with outbound access rules. Create Server or Web publishing rule’s that applies to the specific inbound protocol and place them in the proper order above any outbound or specific deny access rules.
HTH
RB
