https web sites
All Forums >> [ISA Server 2000 General] >> General >> https web sites Page: [1] 2   next >   >>
https web sites - 9.Dec.2002 4:03:00 PM
squee
For our receiving department, we have setup a destination set that allows them to go to certain shipping sites: (i.e. www.ups.com, www.airborne.com, www.fedex.com). We are using the deny access except for selected destination set of above sites with selected users for all content.
The problem we are running into is when they need to login to a secure site within the requested site. Once they click on the login, they receive a blank page with the error message "This page can not be displayed message".
If the destination set is not used, the users can login fine. With the destination set applied, the above error occurs.
RE: https web sites - 10.Dec.2002 7:39:00 PM
Hi James,
I tried to reproduce the problem, but I had no problems accessing the allowed sites. Make sure the users are not trying to access disallowed sites. The Web Proxy log will give you the details.
(in reply to squee)
RE: https web sites - 10.Dec.2002 8:08:00 PM
squee
Tom:
Once they get to www.ups.com, they will then click the logon option, which takes them to
https://www.ups.com/servlet/login?returnto=
This is the page that appears blank.
www.ups.com they can get to.
https://www.ups.com/servlet/login?returnto= they can not get to.
Is that any better?
-Jim
(in reply to squee)
RE: https web sites - 10.Dec.2002 11:29:00 PM
Hi Jim,
I've tested the same link, and I get to the page just fine.
Here's the setup:
1. Create a group called "lusers". Create an account called "Joe". Put Joe in the "lusers" group
2. Create a Site and Content Rule Allow rule that allows the "lusers" group access to the Destination Set that contains www.ups.com and the other sites in it.
3. Create a Site and Content Rule that denies the "lusers" group access to all sites and content EXCEPT for the Destination Set included in the Allow rule
Now the user can access any page, including SSL, that is on the www.ups.com server. He cannot access pages not on that server. This testing was done with the Web Proxy client configuration.
(in reply to squee)
RE: https web sites - 16.Dec.2002 1:28:00 PM
squee
Tom:
Thanks for the info. I will test & let you know.
-Jim
(in reply to squee)
RE: https web sites - 16.Dec.2002 2:57:00 PM
Biagio
I have tha same problem of Jim...I've test your solutions....but now if the destinations set deny is used it's impossible to navigate...if I disable the deny rule we work but we can't go to https....help me please!
Claudio
(in reply to squee)
RE: https web sites - 16.Dec.2002 3:58:00 PM
squee
Tom:
Followed your steps & I am still getting the blank page. In the destination set I am using, *.ups.com /*.
-Jim
(in reply to squee)
squee
That should be *.ups.com & /* for the directories below.
-Jim
(in reply to squee)
RE: https web sites - 16.Dec.2002 6:08:00 PM
ceb
Tom, Bia ,James, All, [Confused]
I¦m having the same problem too...
I¦m searching (long time) a solution to the problem, but I¦m having no sucess....
I need some help to..
CEB, MCSE
cbeuter@yahoo.com
(in reply to squee)
RE: https web sites - 16.Dec.2002 6:37:00 PM
Hey guys,
Did you check out my article I did a couple of days ago on this?
BTW -- the Destination Set should just be www.ups.com. If you want more, use *.ups.com, but no path statement is required at all.
(in reply to squee)
RE: https web sites - 16.Dec.2002 8:19:00 PM
ceb
Hey People,
Good news...
You will not believe...
The solution is very, very complexing:
(LEAVE THE PATH FIELD, ON DESTINATION SETS COMPLETLY EMPTY, WITH NO WILCARD OR /*)
Can you beleieve this ?????
Try and tell me if works...
Regardas... :-)
CEB, MCSE
cbeuter@yahoo.com
(in reply to squee)
RE: https web sites - 16.Dec.2002 8:35:00 PM
squee
Tom:
Read the article. It was very nicely written. I followed all of the steps, but I am still getting the blank page to the login page. Here is the output from the log.
Field1 Field2 Field3 Field4 Field5 Field6 Field7 Field8 Field9 Field10 Field11 Field12 Field13 Field14 Field15 Field16 Field17 Field18 Field19 Field20 Field21 Field22 Field23 Field24 Field25
10.39.253.42 GALYANS\s03ups Mozilla/4.0 (compatible; MSIE 5.5; Windows NT 5.0; T312461) Y 12/16/2002 2:12:40 PM w3proxy GALYANS-ISA - www.ups.com - 80 0 345 153 http TCP GET http://www.ups.com/images/homepage/global_corp_set_04.gif image/gif NotModified 0 0x2 Certain Protocols Allow Sites (1)
10.39.253.42 GALYANS\s03ups Mozilla/4.0 (compatible; MSIE 5.5; Windows NT 5.0; T312461) Y 12/16/2002 2:12:39 PM w3proxy GALYANS-ISA - www.ups.com - 80 0 346 153 http TCP GET http://www.ups.com/images/nav/global/nav1_custserv_off.gif image/gif NotModified 0 0x2 Certain Protocols Allow Sites (1)
10.39.253.42 GALYANS\s03ups Mozilla/4.0 (compatible; MSIE 5.5; Windows NT 5.0; T312461) Y 12/16/2002 2:12:39 PM w3proxy GALYANS-ISA - www.ups.com - 80 0 345 153 http TCP GET http://www.ups.com/images/nav/global/nav1_e-business2.gif image/gif NotModified 0 0x2 Certain Protocols Allow Sites (1)
-Jim
(in reply to squee)
RE: https web sites - 16.Dec.2002 9:01:00 PM
squee
CEB!
You are the MAN! That works. So Tom, why did this change make it work?
-Jim
(in reply to squee)
RE: https web sites - 16.Dec.2002 9:11:00 PM
Hey guys,
you should read again Tom's article http://www.isaserver.org/articles/sitecontentssl.html [Razz]
These log entries tell me that bob was connecting from a Web Proxy client at IP address 10.0.0.3 and that he attempted to connect to www.ups.com:443 via an SSL-tunnel connection. Note that the ISA Server does not log what objects were accessed at the SSL site. The reason for this is that these objects are hidden inside the SSL tunnel at the point where the logging is takes place. This is also the reason why you canĘt limit the type of object a user can access in an SSL site. If you try to limit the types of objects the user can access at an SSL site, the ISA Server will deny access to all objects, because it canĘt determine what objects the user is accessing. This is a common cause for denials at sites where user otherwise has access.
(in reply to squee)
RE: https web sites - 16.Dec.2002 9:39:00 PM
Hey guys,
As Stefaan said, read the article! But I do need to make it more clear that because the SSL connection is encrypted, that the ISA Server cannot evaluate the path, so unless the client has access to the ENTIRE server, the request will be denied.
Good to hear you got it working!
[ December 16, 2002, 09:42 PM: Message edited by: tshinder ]
(in reply to squee)
RE: https web sites - 16.Dec.2002 9:43:00 PM
Originally posted by James E. Rudolph:
Tom:
-Jim
Hi Jim,
None of these log entries indicate a failed HTTPS connection. Am I missing something?
(in reply to squee)
RE: https web sites - 17.Dec.2002 9:57:00 AM
Biagio
Hey guys,
thank you very much!
Now the SSL destinations works!
But if I configure the denies rule....doesn't work! :-(
Any idea?
Bia
(in reply to squee)
RE: https web sites - 17.Dec.2002 1:01:00 PM
ceb
Bia,
You must change your rule :
allow - not deny;
selected destination set - not all destimations except..
Understood ???
CEB, MCSE
cbeuter@yahoo.com
(in reply to squee)
RE: https web sites - 17.Dec.2002 2:25:00 PM
Biagio
Ceb, [Confused]
I have two site and content rules:
1) Allow...with...select destination set
2) Deny...with...All destinations except selected set
doesn't work!
Tks!
(in reply to squee)
Post #: 19
RE: https web sites - 17.Dec.2002 5:07:00 PM
ceb
Bia,
Try with just rule 1 enabled.(not both)
Must work.
CEB, MCSE
cbeuter@yahoo.com
(in reply to squee)
Post #: 20
