low non-paged pool (Out of resources)
All Forums >> [ISA 2006 Firewall] >> General >> low non-paged pool (Out of resources) Page: [1]
low non-paged pool (Out of resources) - 5.Oct.2008 8:49:59 AM
forcerider
Hi everyone!
I'm experiencing some problems with ISA 2006 Standard server. After a while of operation the following message appears in the system log: "The size of the free non-paged pool fell below the system-defined minimum. ISA Server will reject new connections unless they are initiated by the ISA Server computer. In addition, the timeout for idle TCP connections was reduced. This alert may indicate an attack on the ISA Server computer. Use the log viewer to examine ISA Server traffic. This event may also be raised when the ISA Server computer does not have the resources needed to handle legitimate traffic. If this is the case, you may need to add more memory to the system." Event ID 21280.
My Server Spec :
Asus TS-300E5 with 4Gb Ram, 1 x 2.53Ghz Core2Duo, 2x 160Gb HD RAID0 (striped).
After a while of operation, ISA firewall reject all new connection except old connection.
When i checked my resource in task manager, i found that when
Total Kernel Memory number near 150 000K and nonpaged number near 130 000 K, it causes that problem.
Can anyone help me
Thanks in advance!!!
RE: low non-paged pool (Out of resources) - 6.Oct.2008 1:50:00 PM
paulo.oliveira
is the /3gb switch enabled in your boot.ini file?
Run the ISA Best Practice Analyzer and see the results.
Paulo Oliveira.
(in reply to forcerider)
RE: low non-paged pool (Out of resources) - 7.Oct.2008 2:45:51 AM
forcerider
Dear paulo.oliveira
Thanks for your kindly help
this is my boot.ini file contents
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Windows Server 2003, Enterprise" /noexecute=optout /fastdetect /3GB
how can i do next ? hoping your help soon
ORIGINAL: paulo.oliveira
Paulo Oliveira.
(in reply to paulo.oliveira)
RE: low non-paged pool (Out of resources) - 7.Oct.2008 5:07:52 AM
Remove the "/3GB" switch
http://blogs.technet.com/yuridiogenes/archive/2008/08/21/why-3gb-can-negatively-affect-your-isa-server.aspx
RE: low non-paged pool (Out of resources) - 7.Oct.2008 5:54:31 AM
forcerider
Dear Jason Jones
really thanks for your help
i'll remove and test it again
ORIGINAL: Jason Jones
RE: low non-paged pool (Out of resources) - 7.Oct.2008 9:15:28 AM
paulo.oliveira
Hi Jason,
thanks! You were faster than me!
Paulo Oliveira.
RE: low non-paged pool (Out of resources) - 7.Oct.2008 11:54:09 AM
Hi Jason,
Paulo Oliveira.
It makes a change!
RE: low non-paged pool (Out of resources) - 1.Nov.2008 4:35:02 AM
forcerider
Dear Jason
I've removed this and it work well several days
but now, cause this error again.
what should i do next ?
do i need to increase my physical memory (now 4G) ?
i've some cache rules that cache dynamic contents
RE: low non-paged pool (Out of resources) - 4.Dec.2008 6:21:35 AM
forcerider
Can anyone advice me.
i increased  physical memory 4G to 8G
but, this error still occur.
When this error occur, i check my resource in task manager and i found that nonpaged number near 250 000 K.
RE: low non-paged pool (Out of resources) - 4.Dec.2008 6:35:29 AM
forcerider
This is performance assessment of  my server
RE: low non-paged pool (Out of resources) - 4.Dec.2008 6:41:11 AM
forcerider
http://img361.imageshack.us/my.php?image=lownonpagedpooltimech4.jpg
