General proxy questions
All Forums >> [ISA Server 2000 Cache] >> Web Proxy Client >> General proxy questions Page: [1]
General proxy questions - 27.Nov.2002 5:56:00 PM
wgb
We are looking at the ISA server as a possible product to install. Here are my questions:
1. How fast is the raw proxy, will we see a slow down using the proxy as opposed to a direct connection?
2. Are there any types of web pages that have problems with the ISA proxy server? PHP, CGI, ASP...
3. Is the Windows 2000/ISA Proxy capable of handling a sustained 20Mbs if the hardware provides the needed horsepower?
4. Does the ISA server support WCCP?
5. Is failover built into the architecture? How about clustering?
6. How stable (downtime wise) is the Windows 2000/ISA Server combo?
WGB
RE: General proxy questions - 27.Nov.2002 11:30:00 PM
Hi W,
Inline:
--What do you mean by "raw proxy"? The Web Proxy client is the fastest configuration and a lot faster than plain Win2k NAT or SecureNAT
--Sites that embed IP addresses in the source code are a real problem. Many poorly coded Java applets seems problematic, but there are workarounds that I use to create the minimum of discomfort.
--The Web Proxy services has been tested and easily supported up to 400Mbps throughput. RAM and processor requirements are depedendent on the number of rules/packets/second
--Hasn't Cisco gone out of business yet? [Big Grin]
No, it doesn't.
--You can use CARP and the autoconfiguration script for load-balancing and a mild level of failover. You can use NLB for true fail over. RainWall gives you the best of both worlds
--My ISA Server was running for 201 days before I had to restart the machine a couple of days ago.
(in reply to wgb)
RE: General proxy questions - 22.Jan.2007 6:10:14 PM
TheRealLambera
So I have run into this with a client of mine. There web page which is hosted external is prolly wrote php/java for an application that is used.
External viewing of course is fine.
They have SBS 2k3 R2 currently running ISA 2000.
Question: If its only an issue with ISA 2000 then I can just move them to 2004 if not what are the work around mentioned?
Thanks for a quick reply.
PM of Windows Server Longhorn Field Readiness
RE: General proxy questions - 26.Feb.2007 9:08:56 PM
Hi Real,
Most likely 2004 or 2006 won't fix the problem if the application isn't written to support HTTP 1.1 compliant CERN Web proxy servers.
The solution is to configure the particular site for Direct Access -- they allows the client application to bypass the Web proxy service when accessing the site.
(in reply to TheRealLambera)
