Open ports 8000 - 8009 in ISA SERVER
All Forums >> [ISA Server 2000 General] >> Installation >> Open ports 8000 - 8009 in ISA SERVER Page: [1]
Open ports 8000 - 8009 in ISA SERVER - 17.May2002 1:24:00 PM
Ferran
I need to open the ports 8000 to 8009 to enter in the page https://aeat.es:8000/renta/irp1100i.html
Can anyone tell me how to open this ports manually?
Thanks for your help!
RE: Open ports 8000 - 8009 in ISA SERVER - 17.May2002 5:52:00 PM
Abraham
Hi.Ferran
Try to Create a Protocol Definition to this Site, the in the Secondary Connections you can create a Port range for this site. Then create a Protocol rule that use this Protocol definition.
(in reply to Ferran)
RE: Open ports 8000 - 8009 in ISA SERVER - 17.May2002 8:22:00 PM
Hi Ferran,
to add a port range for https traffic, check out http://support.microsoft.com/default.aspx?scid=kb;EN-US;q283284
RE: Open ports 8000 - 8009 in ISA SERVER - 18.May2002 1:54:00 AM
OskarSchneider
I not even can try to tell you how much your reply did help me.
THANKS !
Oskar
RE: Open ports 8000 - 8009 in ISA SERVER - 18.May2002 6:22:00 PM
Hi Oskar,
glad I could help. [Smile]
RE: Open ports 8000 - 8009 in ISA SERVER - 21.May2002 10:29:00 AM
Josecho
Well you need and Visual basic script like:
----------copy and paste----------------------------------
set isa=CreateObject("FPC.Root")
set tprange=isa.Arrays.GetContainingArray.ArrayPolicy.WebProxy.TunnelPortRanges
set tmp=tprange.AddRange("SSL 8000", 8000, 8009)
tprange.Save
make an file text and copy the above lines, save, and change the file extension to .VBS, then execute and restart ISA.
íFunciona!, lo he probado yo tambien tengo certificado.
Greetings
Josecho
RE: Open ports 8000 - 8009 in ISA SERVER - 22.May2002 8:08:00 PM
Ferran
Thanks thanks!
Luego lo pruebo.
