RE: Discussion on Installing ISA Server on Win2003
All Forums >> [ISA Server 2000 General] >> Installation >> RE: Discussion on Installing ISA Server on Win2003 Page: <<   < prev  1 [2] 3   next >   >>
RE: Discussion on Installing ISA Server on Win2003 - 9.Dec.2003 5:31:00 PM
lantechn
Tom shinder You Rocks Man!... Finally I have an stable Server With Win2003 Enterprise and ISA Server Without errors!...
Post #: 21
RE: Discussion on Installing ISA Server on Win2003 - 15.Dec.2003 5:06:00 AM
Hi LanTech,
GREAT!
Good to hear you got things working and thanks for the follow up!
Post #: 22
RE: Discussion on Installing ISA Server on Win2003 - 30.Jan.2004 8:32:00 PM
mperkins
Has anyone run into the problem of the firewall not starting on a Windows 2003 server?? this occures with Routing and remote access install with incoming VPN, outgoing NAT...
Network is outside nic, 10.x.x.x nic for exchange server and web server access, and 192.x.x.x for my internal users.
If I blow away RRAS, reinstall all sp for ISA, and restart the machine, firewall comes up. I then reconfigure the RRAS as before. Everything works until I reboot....
Any Ideas??
Thank you
Marvin
Post #: 23
RE: Discussion on Installing ISA Server on Win2003 - 30.Jan.2004 9:41:00 PM
Jkula
I have ISA up and running on 2003 and it's very stable. The only issue I have now is NLB isn't working right with the setup, not sure if it's 2003 related. Anyone else out there have ISA2000/Windows 2003 setup with NLB?
Post #: 24
RE: Discussion on Installing ISA Server on Win2003 - 30.Jan.2004 11:06:00 PM
mperkins
Here are a couple of events that I have logged.....
This one just happened today...
Event Type: Error
Event Source: Microsoft Firewall
Event Category: None
Event ID: 11001
Date: 1/28/2004
Time: 4:57:41 AM
User: N/A
Computer: SPECTOR
Description:
Microsoft Firewall failed. The failure occurred during Initialization of reverse Network Address Translation (NAT). because the configuration property of the key SOFTWARE\Microsoft\Fpc\Arrays\{1B7C16F8-E9B7-4456-AAEC-26738C77BDF2}\Publishing\PNATServerMappings\{BE62FDAC-EE0E-43A3-B6F6-EF2B8DE6D203}\ClientSetsExcluded could not be accessed. Use the source location 2.546.3.0.1200.166 to report the failure. The error code in the Data area of the event properties indicates the cause of the failure. For more information about this event, see ISA Server Help. The error description is: The system cannot find the file specified.
Data:
0000: 02 00 00 00 ....
This one happened when the firewall service does not start....
Event Type: Error
Event ID: 11011
Date: 1/28/2004
Time: 2:32:21 AM
User: N/A
Computer: SPECTOR
Description:
Microsoft Firewall failed. The failure occurred during Initialization of Network Address Translation (NAT) because the system call PNATInit failed. Use the source location 308.1151.3.0.1200.166 to report the failure. The error code in the Data area of the event properties indicates the cause of the failure. This failure may be due to the Internet Connection Firewall (ICF) service being enabled. If it is enabled, please disable the service named "Internet Connection Firewall (ICF) / Internet Connection Sharing (ICS)" (SharedAccess). Then, restart the computer. For more information about this event, see ISA Server Help. The error description is: The system cannot find the file specified.
Data:
Thank you
Marvin
Post #: 25
RE: Discussion on Installing ISA Server on Win2003 - 1.Feb.2004 5:27:00 AM
grufzilla
Ok Attempting to install ISA 2000 onto Windows 2003 into a Array is not working.
Process:
Install W2k3
Insall Isa 2000
Install ISA 2000 SP1
Reboot
install ISA 2000 2003 Hotfix
None of the ISA services will start.
The event log has:
Event ID: 11002
Microsoft ISA Server Control failed to start. The failure occurred during
Service initialization because the configuration property msFPCSiteName of
key LDAP://mydom.local/CN={some
GUID},CN=Arrays,CN=Fpc,CN=System,DC=yyy,DC=local is not valid. Use the source
location 114.260.3.0.1200.166 to report the failure. The error code in the
description is: The parameter is incorrect.
Using adsiedit to view this in AD and I cannot find the value at all.
There are 0 additional members in the array.
Opening ISA Admin and setting array policies etc works fine....
KB articles regarding errror 11002 say the AD is corrupt, uninstall and remove AD extensions...
I have done this to no avail, tried about 5 times with same result always.
OK, so Next decided to install as standalone... No problems encountered at all.
Any one know what gives???
Post #: 26
RE: Discussion on Installing ISA Server on Win2003 - 6.May2004 12:25:00 AM
mputtick
Upgraded last week from Win2k with ISA2k to Win2003 Standard. Since then, RRAS service will not start, reporting a 7052 error in the event log with 127 as the data. Tried clearing the configuration, but whenever I try to start it, I get the same message telling me the service won't start. Is used for VPN, which was working until re-install took place.
Any ideas?
Post #: 27
RE: Discussion on Installing ISA Server on Win2003 - 7.May2004 12:55:00 PM
Mac220
Hi there,
I've just experienced the vey same problem - 11002. There is a previos message which says:
ISA Server snapin failed to retrieve the arrays list since connection to Global Catalog could not be established. It will next try to retrieve the arrays information from current domain. Check your Active Directory configuration, DNS settings and ensure that the 'Net Logon' service is started.
What this message is saying is it can't contact the global catalogue server. So check the ISA server has visibility on the network to the GC DC. Also check your DNS has all the rellevent DNS entries for the domain and forest global catalogue DC. Once we entered the DNS entries back into DNS..... wham it all started working
[ May 07, 2004, 01:58 PM: Message edited by: Mozart ]
Post #: 28
RE: Discussion on Installing ISA Server on Win2003 - 20.May2004 11:48:00 AM
augustom
I cannot put Message Screener working. I Have a Windows 2003+ISA 2000+IIS 6 + SMTP and a Exchange Server 2000 on internal network. Can anyone please tell me if it has any know issue.
Post #: 29
RE: Discussion on Installing ISA Server on Win2003 - 8.Jun.2004 4:42:00 PM
CharlesScott
Originally posted by tonyg:
ISA SERVER 2000 DOES NOT INSTALL IN UNATTENDED MODE UNDER WINDOWS SERVER 2003!
When I attempt to run ISA Servers setup.exe with the /U switch, I receive the following message box:
______________________________________________
Setup Error 688
A command line option has been used, which is valid only in Maintenance mode.
Subsequent to that incredibly enlightening info, I receive this message next:
Setup Error 723
Setup was unable to read configuration information from the first section of the setup file:
C:\~MSSETUP.T\~msstfqf.t\setup.stf
I am attempting to run the installation from the CD ROM drive and have placed the MsISAund.ini on C:\ .
Any help would be appreciated!
Hi Tony,
I've never run ISA in unattended mode on Windows 2003. Are you OEM?
Chaps,
I've just successfully completed an unattended install on Windows 2003 followed by a successful manual uninstall. First time round, however, I got exactly the symptoms mentioned by Tony. The above indicates that the MsISAund.ini does not contain the relevant path to the install directory. I was trying to use it to install to D:\Program Files\ISA Server, but I hadn't used double quotes and I'd mucked up the drive letter so it installed to the default location.
To remedy this - run a manual install over the current directory and then manually uninstall it afterwards. Then check your MsISAund.ini and try again. Windows 2003 seems to require quotes in the installation directory path if you are using long file names.
Good luck
Post #: 30
RE: Discussion on Installing ISA Server on Win2003 - 8.Jun.2004 6:49:00 PM
dcbennett
Only issue I can't seem to get rid of is the WSPSRV.EXE service taking more and more CPU and memory usage until the users are no longer able to view the internet and the ISA services need to be restarted.
Has anyone come up with any fixes for this?
Other than ISA 2K and all updates, there is nothing installed on this server
Post #: 31
RE: Discussion on Installing ISA Server on Win2003 - 9.Jun.2004 11:08:00 PM
dcbennett
Does anyone have any ideas here? Otherwise I will have to reinstall using Win 2K again.
Post #: 32
RE: Discussion on Installing ISA Server on Win2003 - 4.Nov.2004 3:17:00 PM
Jeroen_317
Tom,
I read your article about installing ISA on 2K3. I notice you install the special hotfix isahf255.exe after SP1 and then you install FP1.
Is that hotfix still required? Is it included in SP2? I installed ISA on W2K3 by first installing SP1, then FP1 and then SP2. Is this good too?
I have done this on 3 servers but one of them has a crashy w3proxy service. The others are very stable. It might be caused by hardwareproblems but I wanted to be sure it is not caused by not installing the isahf225.exe
Thanks in advance,
Jeroen.
Post #: 33
RE: Discussion on Installing ISA Server on Win2003 - 5.Nov.2004 10:41:00 PM
aqib khan
hello,
i installed ISA 2000, on w3k server.
it work's really like a dream.
but i have a little bit problem.
i cannot stop my users from Downloading(serious problem)is any one have solution.
mail me (aqibkhan85@msn.com)or posted here.
Post #: 34
RE: Discussion on Installing ISA Server on Win2003 - 9.Nov.2004 10:17:00 AM
Jeroen_317
Aqib khan,
have you installed that specific hotfix? Or did you do SP1, FP1 and then SP2 only?
To stop users from downloading, you might tryout Websense.
Kind regards,
Jeroen.
Post #: 35
RE: Discussion on Installing ISA Server on Win2003 - 8.Jun.2005 4:42:00 AM
techguy75
Dear Tom,
Many thanks for your article and hope you help me out with this problem. I have a problem with downloading and I couldnĘt figure out reason for that.
The problem is, my clients behind ISA 2000 cant download anything. If they try to download any file it starts the download and finishes with less than 100 kb. Browsing seems fine. This happens with SecureNat clients, Web Proxy clients and firewall clinets, with authentication and without authentication. Iam sure it should be some configuration issue. But i tried a lot and last few days iam browsing through isaserver.org and iam tried now.
Setup details are
ISA 2000 server on Windows 2003 SBS as a stand-alone server.
Service pack 1, ISA hotfix to work in Windows 2003 and Feature Pack 1 is also installed.
All open firewall policy is enabled in the server.
Clients are Windows XP with IE 6.0 with Service Pack 1
Regards
TG
Post #: 36
RE: Discussion on Installing ISA Server on Win2003 - 13.Jun.2005 3:55:00 AM
aqib khan
thanks for suggestion,
i m searching for Websencs
Post #: 37
RE: Discussion on Installing ISA Server on Win2003 - 20.Sep.2005 9:53:00 AM
schristopher
I have the same problem as Marvin - see post -
January 30, 2004 11:06 PM. Does anyone know how to fix this other than removing RRAS?
Post #: 38
RE: Discussion on Installing ISA Server on Win2003 - 17.Jul.2006 8:55:39 AM
ridem
well this topic helps me lots to install isa (std version) on win 2003 but still have a problem (i-e) when i restart my server machine firwall service of isa  stoped and never start unless i reinstall the isa server again
installation procedure:
1- isa server installation
2- Service Pack 1 (restart after installation of service pack 1)
3- hot fix
4- Feature Pack 1
please tell me what is the solution i really need to solve this problem
Post #: 39
RE: Discussion on Installing ISA Server on Win2003 - 26.Jul.2007 12:14:51 PM
EdJaegers
I too am having problems getting ISA 2000 to run on Win 2003.
I have built a new Win 2003 server, installed Win 2003 SP2 and all updates.
Installed ISA 2000, got the message about it being shutdown by Win 2003.
I then installed SP2 which corrected the above issue.
However, I cannot get the Windows Firewall/Internet Connection Sharing (ICS) service to start.  I receive error 1068: The dependency service or group failed to start.
In the Event Viewer, the following entry is made when I attempt to start the service:
Event Type: Error
Event Source: Service Control Manager
Event ID: 7001
Date:  7/26/2007
Time:  11:08:50 AM
User:  N/A
Computer: ***-***-**
Description:
The Windows Firewall/Internet Connection Sharing (ICS) service depends on the Microsoft Firewall service which failed to start because of the following error:
The service cannot be started, either because it is disabled or because it has no enabled devices associated with it.
On the Microsoft site, I found the following: http://support.microsoft.com/kb/813915 but none of the 3 resolutions listed apply to my configuration.
Is ISA 2000 only compatible with Win 2003 SP1, maybe not SP2?  Any help would be greatly appreciated.
(in reply to ridem)
Post #: 40
