RE: CP SecuRemote Client can't get out
All Forums >> [ISA Server 2000 Firewall] >> VPN >> RE: CP SecuRemote Client can't get out Page: <<   < prev  1 [2]
RE: CP SecuRemote Client can't get out - 13.Nov.2003 8:07:00 PM
Hi Trevor,
disable the Firewall client before using the VPN client. For more info, check out my article http://www.isaserver.org/articles/IPSec_Passthrough.html .
(in reply to wdPatterson)
Post #: 21
RE: CP SecuRemote Client can't get out - 13.Nov.2003 11:32:00 PM
kbs
Will this solution only be possible with Windows 2003 Server running ISA 2000 ?
I have a windows 2000 server running ISA 2000.
Post #: 22
RE: CP SecuRemote Client can't get out - 14.Nov.2003 7:17:00 PM
Hi KB,
to pass IPSec NAT-T traffic through ISA server you do *not* need to run ISA onto W2K3. Only if ISA is the VPN endpoint and you want the benefits of IPSec NAT-T, then you must run ISA onto W2K3.
Post #: 23
RE: CP SecuRemote Client can't get out - 13.Apr.2005 5:50:00 PM
nat_k@hotmail.com [Mad]
  Post #: 24
RE: CP SecuRemote Client can't get out - 27.Jun.2005 4:13:00 PM
Does it works fine?
Originally posted by wdPatterson:
How do I configure ISA to allow CheckPoint's SecuRemote Client out through ISA?
This is the KB article that CheckPoint publishes. Like everything else, it is maddeningly incomplete.
...you should configure the other firewalls to allow FW-1 services to pass from the SecuRemote Client to the SecuRemote Server. You should allow the following services:
- IKE
- IPSEC and IKE (UDP on port 500)
- IPSEC ESP (IP type 50)
- IPSEC AH (IP type 51)
- TCP/500 (if using IKE over TCP)
- UDP 2746 or another port (if using UDP encapsulation)
- SecureClient connections
- FW1_scv_keep_alive (UDP port 18233) used for SCV keep-alive packets
- FW1_pslogon_NG (TCP port 18231) used for SecureClient's logon to Policy Server protocol
- FW1_sds_logon (TCP port 18232) used for SecureClient's Software Distribution Server download protocol
How do you configure IKE? Should there be a packet filter? Bidirectional? Please help!
Bill
  Post #: 25
RE: CP SecuRemote Client can't get out - 25.Jun.2009 1:16:29 PM
mattgoldman
Sorry, I know this is an old thread.
I have tried the NAT-T solutions but they don't seem to work. I have set the following in the firewall policy:
UDP 500 send-receive
IP-level 51 send-receive
IP-level 50 send-receive
UDP 4500 send-receive
UDP 2746 send-receive
TCP 264 outbound
I have also set some other ports but I think they are specific to this implementation. Does anyone know the exact settings that should be enabled on the client?
any advice would be appreciated.
Matt
< Message edited by mattgoldman -- 25.Jun.2009 1:17:47 PM >
Post #: 26
