RE: How to pass IPSec traffic through ISA Server
All Forums >> [ISA Server 2000 Firewall] >> VPN >> RE: How to pass IPSec traffic through ISA Server Page: <<   < prev  3 4 [5] 6 7   next >   >>
RE: How to pass IPSec traffic through ISA Server - 25.Mar.2004 8:56:00 PM
networklab
Originally posted by spouseele:
Hey guys,
just to let you know I've updated the article with the latest IETF Internet RFC 3715 IPsec-NAT Compatibility Requirements. The IETF Internet Drafts Negotiation of NAT-Traversal in the IKE and UDP Encapsulation of IPsec Packets have now version 8.
I added also some links to two excellent Microsoft Webcasts and to a forum topic about the Cisco VPN client.
Once the IETF drafts become an RFC, I will revise the article and add some more info about specific implementations.
(in reply to spouseele)
Post #: 81
RE: How to pass IPSec traffic through ISA Server - 25.Mar.2004 9:16:00 PM
networklab
Originally posted by Nig:
Hey guys,
Well that was a good first posting!
Read your article with interest after looking for some info on getting Nortel Contivity client thru' ISA.
I have a number of clients using Contivity without problems. These reside behind Cisco, ICS machines, Linksys routers, 3Com routers and so on. Couple this with the fact that we front our Contivity switches with Watchguards, and it makes me wonder why this has to be so hard when you introduce ISA!
All I want to do is forward udp500 (AISI, this should be forwarded by default on ISA) and IP protocol 50. This is what everything else I've come into contact with has required, but how do you set the IP protocol on ISA? I can create udp or tcp filters but not ip ones. Do you know if this is possible? I have set a custom protocol in IP Packer Filters, but I think this doesn't actually mean IP protocols in the proper sense.
As regards the article, you show screendumps of IPSec setup on an ISA server. How do I get to these panels? Can't see anything IPSec related on this here 2K server. I also can't see anything when I try to add the service.
Cheers,
Nig
Post #: 82
RE: How to pass IPSec traffic through ISA Server - 27.Mar.2004 12:00:00 PM
Hi Nig,
first of all, the IPSec NAT Traversal problem is *not* an ISA specific problem. It is *general* problem due the way IPSec is designed! [Razz]
You should know that ISA server only supports TCP/UDP based protocols for outbound access. So, you simply can't pass other IP protocols such as AH/ESP through ISA. Moreover, because ISA server is also NATting all outbound traffic, you have to use NAT-T for IPSec based protocols.
BTW --- as explained in my article, the screenshots given are for the protocol definitions.
Post #: 83
RE: How to pass IPSec traffic through ISA Server - 15.Apr.2004 3:32:00 PM
I am trying to get SecuRemote Client 4.1 SP5 to communicate through ISA. I have read many of the discussions but cannot get it to work 100%.
The scenario is <CheckPoint VPN> -- <Internet> -- <ISA 2k / W2k> -- <DMZ> -- <ISA 2k / W2k> -- <LAN> -- <Client>. I have placed the client in the DMZ and was able to get authenticated but could not proceed beyond that point. I moved the client outside of ISA and all works fine.
I am not an ISA or network expert so I really do not know how to determine what is failing. I have tried sniffing the packets to see what is being sent but could not see anything that popped out as being wrong.
Does anyone know if SecuRemote Client 4.1 SP5 will work behind ISA? If so is there any specific documentation that would walk me through the proper configuration of ISA so that I can get the SecuRemote Client operational behind ISA?
  Post #: 84
RE: How to pass IPSec traffic through ISA Server - 17.Apr.2004 11:46:00 AM
Hi dyerj,
I haven't first hand experience with the SecuRemote Client. From the information that I gathered in the forums it should work if you have CheckPoint 4.1 SP6 or NG1 FP1 or higher. I suggest you check out http://forums.isaserver.org/ultimatebb.cgi?ubb=get_topic;f=13;t=001107 for more info.
Post #: 85
RE: How to pass IPSec traffic through ISA Server - 7.Jun.2004 8:32:00 PM
sroshan
Hi Stefan,
I am running a small network with internet connected thru DSL to ISA 2000 with SP2.
A few users (Win XP) need to connect an external VPN Server but when I am trying o connect getting an error "678, the computer did not respond".
I already create ports 4500 and 500 on the ISA Server but still unable to connect. I can connect from the ISA Server itself.
Please help and guide the procedure I have to follow.
Post #: 86
RE: How to pass IPSec traffic through ISA Server - 7.Jun.2004 9:39:00 PM
Hi Roshan,
what is the VPN protocol used: PPTP or L2TP/IPSec?
Post #: 87
RE: How to pass IPSec traffic through ISA Server - 7.Jul.2004 3:56:00 AM
Hi there, I have recently setup a vpn to pass through ISA server using Netscreen Remote v8.
I found that I must create a protocl definition in ISA on "UDP port 20358 direction receive" to connect to remote server.
Hope this help.
Stephen
  Post #: 88
RE: How to pass IPSec traffic through ISA Server - 9.Jul.2004 9:12:00 PM
Hi Stephen,
thanks for that info! [Smile]
However that doesn't make much sense unless you have also created a server publishing rule.
[ July 09, 2004, 09:13 PM: Message edited by: spouseele ]
Post #: 89
RE: How to pass IPSec traffic through ISA Server - 19.Jul.2004 3:47:00 AM
Hi Stefaan,
I follow the info provided by Netscreen and your article. It manage to connect to remote VPN gateway (a netscreen 5gt), but i just can't telnet to any server behind the VPN gateway.
After checking the ISA log, I found that port 20358 was blocked in ISA. I create the protocol defination and it works now!
The problem I encounter now is the connection timeout very fast. I'm wondering where should I change the timeout setting?? Anyway, thanks for your reply.
regards,
Stephen
  Post #: 90
RE: How to pass IPSec traffic through ISA Server - 1.Aug.2004 2:14:00 PM
Hi Stephen,
that's weird! Once the VPN connection is up, all traffic destined for the remote site should go through the VPN tunnel. Therefore it is completely shielded for the ISA server. So, the ISA server can *not* even interfere with that traffic!
Are you sure that the client PC is configured as SecureNAT client only when the VPN connection is up?
Post #: 91
RE: How to pass IPSec traffic through ISA Server - 29.Jan.2005 8:49:00 PM
Hey guys,
just to let you know I've updated the article with the latest IETF Internet RFC's 3947 Negotiation of NAT-Traversal in the IKE and 3948 UDP Encapsulation of IPsec Packets. This completes at last the standarization process of the IPsec NAT Traversal solution.
Also, it is a pity that the two excellent Microsoft Technet Webcasts "IPsec and NAT-T : Finally in Harmony? (Level 400)" and "Demystifying IPsec (Level 400)" given by Steve Riley are no longer available on the Microsoft Webcast site. However, on Steve Riley's website you should be able to find the excellent powerpoint presentation IPsec and NAT: Finally in harmony .
Post #: 92
RE: How to pass IPSec traffic through ISA Server - 15.Mar.2005 11:19:00 AM
sdsmtss
Hi Stefaan,
I just wanted to share my findings when I used Server 2003/ISA 2004 to pass IPSec traffic.
My setup consisted of a ISA Server 2004 machine, Server 2003 machine on my internal network and Windows XP machine on the external network.
When I publish my internal servers UDP ports 500 and 4500 I was unable to ping the external IP used in the publishing rule from my external Windows XP machine. There were actually a couple problems.
The first problem was that I had to disable "IPSec Services" on the ISA server machine.
The second problem was the NoDefaultExempt registry key had to be changed so that it was the same on both the Windows XP and Server 2003 machines because they aren't by default. (Some guy actually sent me a tin of chocolates when I helped him with the NoDefaultExempt problem on another message board.)
After I made those changes, I was able to ping both ways but that didn't last long. If I ping the external client from the internal server, it works but about ten minutes later then it doesn't work. I can't ping either way:confused: Then after I wait awhile, it works again.
If I would only initiate the ping from the external client, then it would always work.
I'm not 100% but I think the problem is related to me having multiple IP's on the external interface of the ISA Server. This problem seems to disappear if I am using the first(default) IP listed for the publishing rule. So if I am correct, then you can only publish IPSec for one server using ISA 2004. I wanted to publish two:(
A very big mistake that I made while testing was to switch the default IP on my external interface. I also use this ISA Server to publish Exchange. Everything seemed to be working fine untill somebody complained to me about emails being rejected by The University of Minnesota's email server. Since all outgoing traffic was being sent from the new default IP which didn't match my MX record they blocked my server.
I'm getting a little off topic so maybe I should end now. If you have succesfully published multiple servers using IPSec then please let me know how.
Stephen
Post #: 93
RE: How to pass IPSec traffic through ISA Server - 24.May2005 4:19:00 AM
doerr.sebastian
Hi to all,
this article is very close to my problem.
On the customer site i am using an SBS2003 (standard) and a Lancom Router. This works excelent for the customers Internet an E-Mail traffic and my VPN Dial for Administration out of my home office (direct internet connection).
Trying to make a connection from my office (also there is a SBS2003 standard wont work. SBS does the Internet connection (no ISA no Router is involved).
The connection is established with my client but the protokoll shows that there is only traffic in one direction).
Lancom Support says that i have to enabled IPSEC Passthru on my SBS but could not tell me how to do that.
Is anyone able to tell me how to enable my SBS for passig IPSEC thru?
Best Regards
SD from Germany
Post #: 94
RE: How to pass IPSec traffic through ISA Server - 24.May2005 2:07:00 PM
Hi Stephen,
this article is about outbound IPSec passthrough. You are talking about publishing an internal IPSec host. Some info about this scenario can be found at:
- http://www.microsoft.com/technet/prodtechnol/isa/2004/plan/vpnprotocol.mspx .
- http://www.microsoft.com/technet/prodtechnol/isa/2004/plan/publishingvpnservers.mspx .
Post #: 95
RE: How to pass IPSec traffic through ISA Server - 24.May2005 2:09:00 PM
Hi SD,
I'm sorry, but I have no experience at all with SBS. Re-post your question in a new topic and hopefully somebody is able to answer your specific question.
Post #: 96
RE: How to pass IPSec traffic through ISA Server - 6.Sep.2005 11:08:00 AM
itsupport@resi.com.au
Stefaan,
Only yesterday I was given the task of installing the Cisco VPN Client to a 3rd party company.
By passing our MS ISA 2000 Server via an external IP address, the VPN connection worked.
However when tried to go through the ISA 2000 server the client would not connect.
I configured our ISA server as per point 3 of your article http://www.isaserver.org/articles/IPSec_Passthrough.html but with no luck.
The 3rd party is using a Cisco VPN Concentrator 3005, they gave me Cisco VPN client 2.5 to install.
Any hits would be greatly appreciated.
ITSupportRMC
Post #: 97
RE: How to pass IPSec traffic through ISA Server - 6.Sep.2005 2:32:00 PM
Hi ITSupportRMC,
1. to my knowledge the Cisco VPN client should be version 3.6 or later. Check out section '5.2. Cisco'.
2. don't forget to read section '4. Configuring ISA Clients' too!
Post #: 98
RE: How to pass IPSec traffic through ISA Server - 7.Apr.2006 7:16:12 AM
itsuncoast
Hi, I mistakingly sent you a personal message a couple of weeks ago about my issue.
I have a 2000 SBS and trying to get a Cisco VPN Client v4.8 through without success.  The concentraor admin says NAT-T is enabled and I have read your article and subsequent posts but still no luck.
I have copied some of the relevant lines from the logs below.  I am certainly no expert but I can't see where anything is getting blocked.  I have asked the cisco admin to look at any logs his end but haven't heard back yet.  I just want to make sure my end is right before I start pointing fingers.
#Software: Microsoft(R) Internet Security and Acceleration Server 2000
#Version: 1.0
#Date: 2006-04-05 00:00:23
#Fields: date time source-ip destination-ip protocol param#1 param#2 tcp-flags filter-rule interface ip-header
2006-04-05 01:06:45 210.193.241.42 203.0.220.234 Udp 51351 500 - ALLOWED 210.193.241.42 45 00 03 88 77 73 00 00 80 11 00 00 d2 c1 f1 2a cb 00 dc ea
2006-04-05 01:06:51 210.193.241.42 203.0.220.234 Udp 51351 500 - ALLOWED 210.193.241.42 45 00 03 88 77 e7 00 00 80 11 00 00 d2 c1 f1 2a cb 00 dc ea
2006-04-05 01:06:56 210.193.241.42 203.0.220.234 Udp 51351 500 - ALLOWED 210.193.241.42 45 00 03 88 78 a4 00 00 80 11 00 00 d2 c1 f1 2a cb 00 dc ea
2006-04-05 01:07:01 210.193.241.42 203.0.220.234 Udp 51351 500 - ALLOWED 210.193.241.42 45 00 03 88 7a be 00 00 80 11 00 00 d2 c1 f1 2a cb 00 dc ea
#Fields: c-ip cs-username c-agent date time s-computername r-host r-ip r-port time-taken cs-bytes sc-bytes cs-protocol cs-transport s-operation sc-status sessionid connectionid
192.168.0.200 - - 2006-04-07 02:17:25 SERVER - - - 16 - - 0 UDP Bind 0 2 1
192.168.0.200 - - 2006-04-07 02:17:25 SERVER - 203.0.220.234 500 - - - 500 UDP UdpMap 0 2 1
192.168.0.200 - - 2006-04-07 02:19:53 SERVER - 203.0.220.234 500 147672 7008 - 500 UDP UdpMap 20000 2 1
192.168.0.200 - - 2006-04-07 02:19:53 SERVER - - - 147703 7008 - 0 UDP Bind 20001 2 1
#Version: 1.0
#Date: 2006-04-07 02:27:10
#Fields: c-ip cs-username c-agent sc-authenticated date time s-svcname s-computername cs-referred r-host r-ip r-port time-taken cs-bytes sc-bytes cs-protocol cs-transport s-operation cs-uri cs-mime-type s-object-source sc-status s-cache-info rule#1 rule#2 sessionid connectionid
192.168.0.200 - - N 2006-04-07 02:30:49 fwsrv SERVER - - - - - - - 0 UDP Bind - - - 0 - Users - 5 4
192.168.0.200 - - N 2006-04-07 02:30:49 fwsrv SERVER - - 203.0.220.234 500 - - - 500 UDP UdpMap - - - 0 - IPSec Pass Thru-All Users Allow rule 5 4
192.168.0.200 - - N 2006-04-07 02:32:06 fwsrv SERVER - - 203.0.220.234 500 77437 3504 - 500 UDP UdpMap - - - 20000 - IPSec Pass Thru-All Users Allow rule 5 4
192.168.0.200 - - N 2006-04-07 02:32:06 fwsrv SERVER - - - - 77437 3504 - 0 UDP Bind - - - 20001 - Users - 5 4
Any assistance would be greatly appreciated by myself and my customer who is becoming less patient.
Neil
(in reply to networklab)
Post #: 99
RE: How to pass IPSec traffic through ISA Server - 7.Apr.2006 1:26:15 PM
Hi Neil,
according to the info given, it sounds that the IKE negotiation starts but no response is received. What is the Cisco VPN client logging telling you? How far does the IKE negotiation get? A NetMon trace on the ISA external interface can also give some useful information.
BTW --- for the Cisco VPN client logging, check out http://forums.isaserver.org/m_130199300/mpage_1/tm.htm.
(in reply to itsuncoast)
Post #: 100
Page:   <<   < prev  3 4 [5] 6 7   next >   >> << Older Topic    Newer Topic >>
