RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR
All Forums >> [ISA Server 2000 Misc.] >> Tips & Tricks >> RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR Page: <<   < prev  1 [2] 3 4 5   next >   >>
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 10.Nov.2003 5:55:00 AM
iahsan
Dear Hunaid,
You are right.. I should start coming up with suggestions.. sort of realized that after reading my own posts [Razz] . I'll use your points and add my own where I think there should be a change. Check back later.
Imran
(in reply to munnobhai)
Post #: 21
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 10.Nov.2003 8:26:00 AM
munnobhai
Dear All,
Thanks for contribution. [Wink]
Well Saqib I think your java sites script is not updated .... have it from http://207.226.41.252:83/scripts.zip
As all sms sites related to Pakistan are working fine , because all of them using *.vectracom.net.
Please, check it and let me know if there is any issue !
Hunaid.
NetCommunications
munnobhai@hotmail.com
Post #: 22
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 10.Nov.2003 8:40:00 AM
munnobhai
Dear All,
Some new mimes arrived regarding .exe so have the
updated mimes list with the script to add them:
Hunaid.
NetCommunications
Post #: 23
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 10.Nov.2003 4:08:00 PM
munnobhai
Dear All,
I have found an application that limits the bandwidth at client side .... still testing it.
Please , hang on till I can introduce it after
successful test !
Hunaid.
NetCommunications
Post #: 24
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 11.Nov.2003 3:31:00 AM
munnobhai
Dear All,
Please check this :
http://forums.isaserver.org/ultimatebb.cgi?ubb=get_topic;f=12;t=000288
Hunaid.
NetCommunications
Post #: 25
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 12.Nov.2003 12:52:00 PM
cpics
hi there,
i hv a cable internet setu here in karachi i hv about 130 users running on ISA server i hv a problem in msn6 i hv a indivisual firewall server but it's no use and my web is running on another seperate server all of my clinets have so much trouble in connecting msn messneger 6 so please let me know how should i solve this problem and get rid of so many complains how do i configure both of my servers to get the best output
thanks
amir ali khan
Post #: 26
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 12.Nov.2003 2:13:00 PM
azfar
well your kind of setup is working good with 5 or pre version of msn but now in msn6 its also needs a web proxy to sign on, I have checked it when my web proxy service stoped it never connect and when both services or working properly its work fine.Any way you can move your msn6 clients onto your web proxy service by forcing them to use http proxy or socks 4 in connection setting.
Azfar Hashmi
Email : azfarhashmi@hotmail.com
Post #: 27
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 13.Nov.2003 8:19:00 AM
azfar
If it not works then write us here some more detail about your exact problem and your network configuration also isa configuration.
Azfar Hashmi
Post #: 28
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 13.Nov.2003 11:13:00 AM
cpics
hi there
i hv found the solution of my problem with some exceptions now msn6 is working just fine better then before i just install the feature pack and it's update for ISA server and it's work but my web server is bit slower then before if anyone know the solution pls leave a msg for me one more thing is that licence of ISA server is most important to run feature pack and it's patches
thanks all of you
Post #: 29
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 13.Nov.2003 1:18:00 PM
azfar
Every body knows that they can't install isa server fixes on evaluation version.
Azfar Hashmi
Post #: 30
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 19.Nov.2003 6:22:00 PM
munnobhai
Dear All,
Please check this for bandwidth manager :
http://forums.isaserver.org/ultimatebb.cgi?ubb=get_topic;f=12;t=000293
Hunaid Haroon Al Qureshi
NetCommunications
Post #: 31
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 27.Nov.2003 1:12:00 PM
icebox
Hi All..!
I'm newcomer and I'm using Isa 2000 on WIN2k AD SP3 Patched.. I'm on dialup. Hunaid's article was a big help in setting up the server but i'm still having trouble with MSN6. Clients get an error "Signing in failed because you do not have the correct user ID and password for your
HTTP Proxy server. See the Connection Tab in Messenger options" even though they are authenticated and everything else on thier side is working fine. Yahoo messenger hardly takes 5-10 secs to connect. I've also applied the script at toolzz.com for MSN MSGR but still getting the same message. MSN does connect but after million tries..
any help will be highly appreciated
Post #: 32
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 27.Nov.2003 7:42:00 PM
munnobhai
Hello Dear,
You can solve this by using the HTTP proxy settings in MSN 6.x and setting the user id and password there !
NetCommunications
Post #: 33
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 3.Dec.2003 6:45:00 AM
asif79_pk
hy! i use yahoo chat but java applet error come and didn't open this windows so tell me where i download javascript
Post #: 34
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 3.Dec.2003 1:51:00 PM
cpics
i still got so much problem in msn6 nothing is useful for me till now anyone have any other solution aur idea pls ler me know as soon as possible
Post #: 35
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 10.Dec.2003 3:10:00 PM
icebox
Hi All...
Hunaid thanks for your reply .. i tried putting both id and pass and selecting HTTP proxy in msn messenger but it still gives the same error
Let me clear that users are connecting thru Isa firewall client .
Configuration of servers:
Windows 2000 SP4 Active Directory PDC Active Directory integerated DNS,DHCP, ISA 2000 with Feature pack and service pack, Link translator and url scan filter installed, Clients are authenticated, a standered protocol containing HTTP, HTTPS and MSN protocol, I've also made a custom protcol that allows ports in/outbond 6891 -6900 TCP, I also tried a site and content rule for MSN servers but still getting the same error... Plz help me out here .. I will be thankfull..
Nabeel
Post #: 36
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 17.Dec.2003 2:39:00 AM
ismaster
change default bandwidth to 25 in and out.i had this problem first but now its ok.i blocked downloading in day time.install service pack and feature pack for isa server.try this
Post #: 37
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 8.Mar.2004 11:27:00 AM
cpics
hi hunaid
i hv a very cable net setup i want some tips from u i have 2 servers on my setup one for web and the other is for firewall services i want to block the browsing on my firewall and utlilize that bandtwidth for msn messenger as it use http for connecting msn give me hint for this procedure
Post #: 38
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 8.Apr.2004 7:16:00 AM
dangerous538
hunaid i couls not find that scripts u posted kindly tell me the exact url thanks for ur contribution(Apna Internet Cable Network)Lahore
Post #: 39
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 9.Apr.2004 10:20:00 AM
munnobhai
Dear all,
For the scripts please add me on msn messenger because my IP is changing frequently now !
Post #: 40
Page:   <<   < prev  1 [2] 3 4 5   next >   >> << Older Topic    Newer Topic >>
