well done hunaid.....i m impressed....ur settings r kool...but a few drawbacks....still they work magic... i have recently started a network and running a dialup... i have a couple of questions regarding msn and kazaa....sometimes msn simply does not connect( with very low traffic on the dialup )and can i manage the download bandwidth for kazaa with bsb... also y have u disabled socks v4 filter......
hi there is a problem on block download sms and chat servers are not working although i have added the sites in java sites give me the solution to solve this problem thanks
hi Munnu Bhai .. I am just CONSTANTLY SENDING U MESSAGES ON MSN ... BUT U DID`NT REPLIED ME.. SINCE MORNING AND STILL I M WAITING FOR UR REPLY ....... ACTUALLY I NEED TO ASK SOME QUESTIONS ABOUT UR BEST CONFIGURATION OF ISA SERVER 2000 FOR CABLE OPERATORS.. SO WOULD U MIND ANSWERING ME
I went through all of your article but i couldn't get through to stop downloading, when i finish making rule of Block DL and Block FTP it stops browsing on client machin, When delete those rules clients can successfully browse the sites. Tell me what's wrong with that.
Dear Hunaid, ur scripts are working perfect no doubt but the problem is only in "Allow all" rule.Your most settings are just working because of this rule only if u block this rule and than check these settings (Sms etc) u will know what i mean.this is just a friendly advice not a criticise. In my network i have blocked "Allow All" rule and it helps alot in getting some extra bandwith. Sincerely Yours,
Saqib Ali Network Admin. ECS Cablenet(Simply The Best). 6626731-6605096-6626936 0300-2485225 ecscablenet@hotmail.com
Well Saqib I know the disadvantages of allow all rule and I am currently finding out all ports which are neccessary to open for any kind of network and all popular applications and it will be completed in few days. Just keep in touch.
Dear ISA Users, Hope you all will be fine. your this software ISA SERVER for Win2000 Server is very Good and Scure about networking. Dear Admin, I See All the Elements in ISA Server. I Want to Let you know that i am a Network Adminstrator I am running an internet cable in my Area. And I am Using Your Product ISA SERVER on Administrator computer. Dear, I want to Run Paltalk on Client Computer, But It Doesn't Work On client, Paltalk making Problems About voice On Client. I am so Helpless about to Confiugre ISA SERVER for Paltalk. I Contact with Paltalk Administrator. He Told me that I shoud Have to open some ports which is releated paltalk. He Said that i shoud have to open these ports from ISA SERVER. TCP 2090 file transfer UDP 2090 voice stream TCP 2091 video listening port UDP 2091 control stream TCP 2095 file transfer - (older versions) Outbound ports TCP 5001-5020 text messaging TCP 8100-8700 firewall / network mode group voice UDP 8100-8700 group voice UDP 1024-2500 voice stream - user configurable UDP 1024-2500 control stream - user configurable These Ports I have to Configure in ISA Server for Paltalk Support. Please Tell me how can I open these Ports Plz Tell me in Details and Graphicaly I Will Wait For Your Reply.. i will be very thank full to you. Adnan Akhter. My Mail Address : A4_M@yahoo.com
hello ISA user hope every1 will be fine.....i want to ask amur (cpis) that what is the configration of 2 server which he prepare.....and on client side wut they do is they install 2 firewall or wut they do? and wut did Adnan for Paltalk do u have any solution?i have also this problem when i start paltalk its error is "login error " even login and password is corect plz reply as soon as possible thanx fahim imfahim@hotmail.com
RE: BEST ISA SERVER CONFIGURATION FOR A CABLE NET OPERATOR - 23.Jul.2004 5:06:00 AM
sir i did not got ur scripts plz mail me at vuphi2000@yahoo.com i m new to ISA plz --------------------------------------------------------------------------------
Salam Hunaid Bhai! i just read your topic i am trying to download the scripts.zip file but unable to download may be link has been changed can u please tell me if i download it from www.toolz.com is it same as you have in your web server have u uploaded this script file on toolz website as well thanks in Advance bye
