why does it take so long to list server's?
All Forums >> [ISA Server 2000 Misc.] >> Gaming >> why does it take so long to list server's? Page: [1]
why does it take so long to list server's? - 22.Dec.2001 10:47:00 PM
Doc
UT, quake3 etc take ages to list the servers, is this normal?
RE: why does it take so long to list server's? - 29.Dec.2001 6:38:00 PM
Doc
ok this is killing me, UT as an example - i can connect to servers no problem (by ip) and plays fine but when i try to list the server it gets the total nuber and when it gets to the point of pinging them it just hangs and eventually after 10mins shows a bunch of servers with a ping of 23999+, i created a ip filter to make the isa box pingable and have tested UT from the isa box itself and it lists the servers fine, now when i look in the ipp logs after trying to list the servers from a client box i see this
code:
2001-12-29 16:37:02 213.121.118.xxx 194.177.125.42 Udp 1025 137 BLOCKED 213.121.118.xxx
2001-12-29 16:37:05 213.121.118.xxx 12.147.50.14 Udp 1025 137 BLOCKED 213.121.118.xxx
2001-12-29 16:37:07 213.121.118.xxx 12.147.50.14 Udp 1025 137 BLOCKED 213.121.118.xxx
2001-12-29 16:37:10 213.121.118.xxx 217.175.227.111 Udp 1025 137 BLOCKED 213.121.118.xxx
2001-12-29 16:37:12 213.121.118.xxx 217.175.227.111 Udp 1025 137 BLOCKED 213.121.118.xxx
2001-12-29 16:37:15 213.121.118.xxx 212.65.12.13 Udp 1025 137 BLOCKED 213.121.118.xxx
2001-12-29 16:37:16 213.121.118.xxx 212.65.12.13 Udp 1025 137 BLOCKED 213.121.118.xxx
2001-12-29 16:37:20 213.121.118.xxx 195.149.21.27 Udp 1025 137 BLOCKED 213.121.118.xxx
anyone care to help me out
[This message has been edited by Doc (edited 29 December 2001).]
(in reply to Doc)
RE: why does it take so long to list server's? - 31.Dec.2001 7:51:00 PM
clutch
I have the firewall client installed on my local workstation, and I will try to list some Q3 games via the in-game browser tonight. Also, I have Kali installed on my secondary workstation so we'll see how Tracker takes to the firewall client, and I will try to post everything tonight.
clutch
(in reply to Doc)
RE: why does it take so long to list server's? - 31.Dec.2001 9:57:00 PM
JaimeP
I think its because there are servers that are on non-standard ports and when your client goes out to get info from them on these non-standard ports, they wont work and just time out. That is what is taking so long. You might try making an "all" rule and see if the list speeds up after that. This will confirm my theory.
-JaimeP
ISA Server Game/Apps Port List
(in reply to Doc)
RE: why does it take so long to list server's? - 31.Dec.2001 10:30:00 PM
Doc
i should add i have an "aal" rule for testing and it makes no difference
(in reply to Doc)
RE: why does it take so long to list server's? - 3.Jan.2002 6:55:00 AM
HJB417
have you treid using gamespy as an alternative?
5 computer network (1 win9x, 4 win2k), HPNA 1mb network, cable modem.
don't forget to do security tests
http://www.vulnerabilities.org/analysis.html
http://www.sdesign.com:8080/cgi-bin/fwtest.cgi
http://scan.sygatetech.com/
http://www.dslreports.com/scan
http://www.dslreports.com/secureme (I love this one)
(in reply to Doc)
RE: why does it take so long to list server's? - 3.Jan.2002 8:12:00 PM
Doc
yep, and it does exactly the same thing, and tried all seeing eye same thing again, i also got TA installed i have no prob listing server's on gamespy with that
(in reply to Doc)
RE: why does it take so long to list server's? - 4.Jan.2002 4:18:00 AM
HJB417
gamespy3d pings servers fine for me HL, CS, Q3. It doesn't use the ICMP ping. Tribes2 builtin gamebrowser works fine too.
(in reply to Doc)
RE: why does it take so long to list server's? - 4.Jan.2002 5:27:00 AM
Doc
well well, a fresh install of ISA and no custom packet filters and an "all" rule it works, very strange, this time as i build up the packet filters etc i'll keep testing to see what knocks it out
and thx for all the replys, i really apreciate it
(in reply to Doc)
RE: why does it take so long to list server's? - 4.Jan.2002 5:51:00 AM
clutch
Sorry about not getting back to you, I was called away to work on some other stuff for the last few days. Glad to hear you got it working though.
clutch
(in reply to Doc)
RE: why does it take so long to list server's? - 4.Jan.2002 7:01:00 PM
Doc
ok i found out what it was, everything was working fine till i started adding content rules, so i disabled them all it it worked again so i narrowed it down to one rule, "hotmail" in it i have *.passport.com and *.hotmail.com and only have it applied to certain users (not me) enabling that breaks UT really strange but it's true i can replicate it everytime
edit, well anything with a hostname causes it so i'm using ip ranges for now
[This message has been edited by Doc (edited 04 January 2002).]
(in reply to Doc)
RE: why does it take so long to list server's? - 5.Jan.2002 6:02:00 AM
HJB417
cool find, thx for the heads up
(in reply to Doc)
