WinMx
All Forums >> [ISA Server 2000 Misc.] >> Gaming >> WinMx Page: [1]
WinMx - 29.Oct.2002 4:24:00 PM
Mr.Bluesman
It seems this has been asked alot, but I still can't get it to work. I have the following setup: 3 protocol definitions: 1- port 6699 TCP Inbound, 2- Port 6257 UDP receive, 3- Port 6257 UDP Send.
IP Packet Filters: 1 -Allow TCP both directions - Local and remote ports set to Any. 2- Allow UDP both directions - Local and remote ports set to any.
Protocol Rule: Allow the 3 protocol definitions listed above.
Trying to connect using the Socksv4 proxy & Firewall client is installed.
Am I missing a setting here? Thanks for any help.
RE: WinMx - 30.Oct.2002 4:23:00 PM
ASHRID
IF you have the firewall client installed you shouldnt need any additional config (protocols/ports etc).
Been a while since I used it though
(in reply to Mr.Bluesman)
RE: WinMx - 22.Nov.2002 10:00:00 PM
ustraveler99
I am having the same problem that you had.
I have set up protocol rules, packet rules, publishing rules, installed the firewall client and cannot get passed the blinking yellow "connecting" icon.
I have 2 protocol definitions:
2- Port 6257 UDP send receive,
IP Packet Filters:
Protocol Rule:
Allow the 2 protocol definitions listed above.
I have tried with and without the Socksv4 proxy
I have installed the Firewall client on the winmx workstation.
I have also tried where the winmx workstation points to the ISA server as a proxy server.
I have uninstalled winmx, rebooted and re-installed.
Nothing seems to work.
I am sooo frustrated. Can someone offer me some help here? What am I missing?
Traveler
RE: WinMx - 24.Nov.2002 6:36:00 PM
tabbertmj
I think I have found the answer. WinMX is set to connect with a secondary connection. Right now I have to may ports open, but I did get WinMX to connect. I have a protocol definition as follows...
6699 TCP Inbound
Secondary Connections:
1728 TCP Outbound
1769-1772 UDP Receive Send
1885-1886 UDP Receive Send
6257 UDP Receive Send
6699 TCP Outbound
7950-7952 TCP Outbound
I hope that will help somebody. I would like to hear other results with those settings. I will try to narrow them down some. But it is a start. Good luck.
Mike
RE: WinMx - 12.Dec.2002 2:30:00 PM
mboczek
I used to have winmx working but about 6 months ago had to rebuild my isa server. Of course when I finally got round to re-enabling winmx - it didn't work.
It appears that my older version of winmx (sorry, it was either 2.2.x or 3.2.1 (not sure which)) was trying to connect to some winmx.com servers that it couldn't resolve (find). I updated to 3.31 and the problem went away.
Anyone who tries the following setup without success should try updating to winmx 3.31 before giving up [Wink]
Protocol Definitions:-
(1)port 6699 TCP inbound, no secondaries
(2)port 6699 TCP outbound, no secondaries
(3)port 6257 UDP send/receive, no secondaries
(4)port 6257 UDP receive/send, no secondaries
Protocol Rule:-
allow, selected protocols, all the above ie 1 to 4.
IP Packet Filters
(5) Custom, UDP protocol, direction both, fixed local port 6257, remote port all.
(6) Custom, TCP protocol, direction both, fixed local port 6699, remote port all.
Server Publishing Rules
(7) (int ip as required), external IP default, map using rule (4) above.
(8) (int ip as required), external IP default, map using rule (1) above.
WinMX
Outgoing TCP Connection - connect direct
Incomming TCP - listen on port 6699
In/out UDP - send & receive datagrams on port 6257
Host name resolution - use operating system
Network - make a primary connection
Firewall Client (probably unnecesary)
app winmx, localbindtcpports, 6699
app winmx, localbindudpports, 6257
The above works with winmx installed on a pc on a lan behind an ISA server - may need to change if running on the isa itself.
It allows primary connects, including uploads (although they seem slow - not a bad thing [Razz] ).
Disable packet filter (6) to prevent uploads.
Without the UDP rules I could get a connection, but didn't receive any search responses.
Other than the last few comments I'm not sure which of these rules are mandatory and which can be omitted. You are welcome to refine...
Malc
RE: WinMx - 14.Dec.2002 5:04:00 PM
jedy
@malc
thank you for the detailed discription! =)
I have tried your setup but I am still having problems ... =(
My problem is the server publishing rule. I can not specify the external ip default because the ISA works with an dial-out connection.
Can someone give me a configuration making Winmx workt behind the ISA without an server publishing rule!??
jedy
RE: WinMx - 26.Dec.2002 5:23:00 PM
jedy
Hello!
After hard work WinMX 3.31 runs on my client so far [Wink]
So I would like to share my experience with ISA and WinMX. With observance of the following steps the configuration was successful!
1) Create a protocol rule to allow all IP traffic outbound
2) Use the firewall client
3) Create two protocol definitions
1. primary: 6699 TCP in
secondaries: 1024-5000 udp send/receive
1024-5000 udp receive/send
6257 udp send/receive
6257 udp receive/send
(secondaries probably unnecesary)
2. 6257 UDP receive/send
no secondaries
4) Create a protocol rule with the above protocol definitions
WinMX Configuration:
Network: make a secondary connection
Outgoing TCP: direct
Incomming TCP: listen Port 6699
In/Out UDP: send/receive port 6257
Firewall Client Applications:
WinMX.exe: remotebindudp 6257
WinMX.exe: localbindudp 6257
WinMX.exe: remotebindtcp 6699
WinMX.exe: localbindtcp 6699
good luck =)
jedy
RE: WinMx - 23.Jan.2003 3:37:00 PM
Joe F.
Now finally WinMX runs on my S-NAT Clients!
First, i've made the 4 protocol definitions like Malc Boczek (and of course selected all in protocol rule). I have not added the packet filters and server publishing rules, but 3 more protocol rules for TCP Outgoing Port 7950,7951,7952. And it works [Smile]
RE: WinMx - 26.Feb.2003 3:16:00 PM
djmrmagic
YES ! Joe F, your the man. Where did you get those ports from?? But mine now works as a Secure NAT client! Thanks!
