Subspace/Continuum
All Forums >> [ISA Server 2000 Misc.] >> Gaming >> Subspace/Continuum Page: [1]
Subspace/Continuum - 20.Dec.2002 7:01:00 PM
palindroem
Does anyone know what the correct app config / ISA ports to allow Subspace or Continuum to connect? It has a screen for setting SOCK5 proxy server host and port, but whatever I put in, the game just locks up . . . eventually failing at timeout.
thanks
RE: Subspace/Continuum - 23.Dec.2002 12:47:00 AM
Hi Pal,
I usually don't hang around in here, but when you said Subspace, I had to check this out! I used to play that game all the time in 1997/1998 and then it just disappeared. [Frown]
I did a Google search and found the software, and was surprized it worked in XP! I don't know the specific protocols, but if you use the Firewall client and create an "all IP traffic" rule to open access, it works great!
(in reply to palindroem)
RE: Subspace/Continuum - 24.Dec.2002 2:51:00 PM
palindroem
Great, If I can get this ISA to work I'll try that. Subspace (now Continuum) is about the only game I play, nice brainless way to relax while I try to figure things (ISA for now) out. I know that each zone (I play Extreme Games) uses its own port, could I limit the scope of the rule just for the specific port #?
Thanks again.
(What nic do you play under?)
-Droem-
RE: Subspace/Continuum - 24.Dec.2002 2:53:00 PM
Hi Droem,
I've been playing under the nic tshinder. I'm definitely not very good right now [Big Grin]
Like I said, I'm not sure what ports are used by the application and if it requires primary and secondary connections. Many games do, so that's something you need to be aware of if you want to create a Protocol Rule to amke it work.
