EverQuest 2 configuration
All Forums >> [ISA Server 2000 Misc.] >> Gaming >> EverQuest 2 configuration Page: [1]
EverQuest 2 configuration - 21.Nov.2004 8:13:00 AM
Encyclia
Here are the protocols you need to configure:
For the Sony Station applications at the beginning:
-For the Sony Station Launch Pad
1. UDP 3016 Send/Receive
Secondary connection:
UDP 3017-3021 Send/Receive
2. UDP 9700 Send/Receive
9701-9703
-For the Sony Station Launch Pad Patching
1. TCP 7000 Outbound
For the actual EverQuest 2 game:
-For the EQ2 Patching mechanism (runs every time you connect):
1. TCP 7010 Outbound
-For the actual EQ2 Game Play:
1. UDP 9100 Send/Receive
Secondary Connection:
UDP 32800-33000 Send/Receive
I made this into one rule, and we're connecting and playing with no problems.
______________________________________________
Note: The Windows XP Firewall (SP2) will cause disconnects. Disabling it while playing works, though we haven't tried any specific settings in the XP firewall to test.
Note: The 32800-33000 range of ports can be configured as individual protocols...one protocol per port to allow the connections. When I was first sorting it out I found that certain ports in that range allowed connections to specific areas in the game. Sooo....before I configured the 32800-33000 range as secondary connections to the 9100 UDP port, whenever I went to a new area of the game it would fail to connect. I'd then look at the logs and figure out which port the game tried to connect on, and create a protocol definition for it, then it would work thereafter.
RE: EverQuest 2 configuration - 23.Nov.2004 7:56:00 AM
HI,
i have only one Problem with your ISA Configuration.
I can`t join a Zone-Server. Nothing will loaded.
I can`t nothing see in my ISA Log-Files that any Ports are blocked.
Any Ideas?
thx
Kr99
(in reply to Encyclia)
RE: EverQuest 2 configuration - 10.Dec.2004 8:48:00 PM
Greetings, just wanted to say thanks for the info!
However I have the same problem as the poster above, all patching works, and i can get to the char select screen, but I cannot connect to a zone server.
The secondary connection ports are all set too.
Could it be some missing ICMP filters that are causing this?
Cheers,
Sonny
RE: EverQuest 2 configuration - 14.Dec.2004 5:05:00 PM
Greetings. I am having the same issue. Everything works perfectly except connecting to zone. No messages in any of the logs. Could it be something wrong with the routing configuration?
RE: EverQuest 2 configuration - 3.Jan.2005 6:41:00 PM
My bet is that you aren't using the ISA client on your PC which is required when you are using secondary connections. [Smile]
RE: EverQuest 2 configuration - 4.Jan.2005 5:53:00 PM
I have created the open ports as stated and I have the firewall client installed. I can get everything to work, except playing the game. The login screen brings up the PLAY button,but when I press it. it does its little thing and then just takes me right back to the PLAY screen. The firewall logs and proxy logs dont show anything that is being blocked in any way. I do see all the ports that are opened listing communication fine. If I take the laptop to work and use their network, I can connect just fine to EQII and play. They are behind a cisco pix. Theres still something missing.......
Any ideas????
RE: EverQuest 2 configuration - 14.Jan.2005 12:23:00 PM
Ok, can we have the top in english for the non-tech pure gamers? Where is all that info supposed to go? A little direction would be great!
RE: EverQuest 2 configuration - 18.Jan.2005 12:56:00 AM
Arpophyllum
Sorry about the lack of response, I've been playing constantly. Haven't checked the boards since I posted this originally.
Yes, the firewall client IS required. You will fail to connect to the zone servers. The secondary connections are managed by the client communications with the ISA server.
Also, firewalls on the box and other systems, like modem/routers may cause other issues that I don't have experience with since I'm behind a bridging DSL modem.
RE: EverQuest 2 configuration - 18.Jan.2005 1:12:00 AM
Arpophyllum
<marinemike>...the protocols I list are 'Protocol Definitions' in ISA 2k, and they need to be added to an enable rule.
There's an article about understanding the Firewall Client Control Channel that covers some of the details you may be looking for...though it IS technical.
http://www.isaserver.org/articles/Understanding_the_Firewall_Client_Control_Channel.html
RE: EverQuest 2 configuration - 18.Jan.2005 1:27:00 AM
Arpophyllum
regarding the ICMP/ping ports/IPs that Sony mentions in their help section: I started creating allow rules for ICMP for the ranges they specified, but when I realized that it was the secondary connections that were the issue, I disabled all the rules for the ICMP allows that I had setup and can play with no problems.
RE: EverQuest 2 configuration - 22.Feb.2005 3:45:00 AM
Nox
Ok - Let's pretend I'm a blithering idiot that knows NOTHING about configuring ports and permissions...wait, we don't need to pretend. I'm a gamer and not an IT guy, so I could use a little direction on HOW and WHERE to do this on my system. My daughter's system locks up during the patching process - we're on an 802.11g wireless network. It does, however, stay online when surfing the web.
Help me! Please!
[Eek!]
RE: EverQuest 2 configuration - 24.Feb.2005 5:20:00 AM
If I completely disable the firewall, do I still have to manually open ports?
RE: EverQuest 2 configuration - 9.Mar.2005 12:11:00 AM
Arpophyllum
Help me! Please!
[Eek!]
The information I've listed above is only applicable to a configuration where your firewall is an ISA 2000 system with a windows XP client that has the ISA 2k firewall client installed and the windows XP firewall turned off. From your post it doesn't sound like you're running ISA 2k.
RE: EverQuest 2 configuration - 9.Mar.2005 12:13:00 AM
Arpophyllum
Disable what firewall??? ISA?? I have the XP firewall turned off, if that's what you're referring to. Disabling the ISA services would leave the ISA system in a locked down state and zero packets would go through (if my memory is correct).
RE: EverQuest 2 configuration - 4.Apr.2005 10:21:00 AM
I can`t join a Zone-Server using your specified configuration. Patch and Login do fine, but i cannot come past the user creation screen. I'm using ISA Server 2004 with (and without) firewall client. Is there anything else to configure ? Please help.
Michael
RE: EverQuest 2 configuration - 7.Apr.2005 4:25:00 PM
bdh113s
Heya!
The secondary UDP connections... Are they initiated from the EQ2 servers? As in, they are new UDP transmissions started and sent back to the client?
RE: EverQuest 2 configuration - 8.Apr.2005 8:09:00 AM
I got it running. You really have to, as written in the original posting , create a seperate protocol definition for each primary / secondary pair. You then can pack them all into one Rule ( From Internal to External).
Have a look not to have specified the ports in another rule.
Have fun and thanks for the reply
Michael
RE: EverQuest 2 configuration - 26.Apr.2005 11:47:00 PM
Encyclia
Originally posted by Brian Hofmeister:
Heya!
No, they are secondary connections initiated by the client. You'll see these entries in the ISA firewall logs as initiated by everquest2.exe (or is it eq2.exe? can't remember). I think that when you're zoning, the client either already knows what port the zone is, or the server tells it what port to use, but the connection is initiated by the client.
RE: EverQuest 2 configuration - 26.Apr.2005 11:48:00 PM
Encyclia
Michael
Glad you got it going!
Post #: 19
