Open Port udp 5082 failure
All Forums >> [ISA Server 2000 General] >> H.323 Gatekeeper >> Open Port udp 5082 failure Page: [1]
Open Port udp 5082 failure - 4.Jun.2003 7:38:00 AM
smarisetty
I tried to open the UDP 5082 through a procotol definition and protocol rule. Checking the ISA logs, I still see that this port is being blocked for incoming packets.
Any ideas where and what to look for.
thanks
sm
RE: Open Port udp 5082 failure - 4.Jun.2003 7:58:00 PM
Hi smarisetty,
how does your protocol definition looks like? It should be something like "UDP port 5082 send receive" for outbound access.
(in reply to smarisetty)
RE: Open Port udp 5082 failure - 5.Jun.2003 5:20:00 AM
smarisetty
I have added the rules send-receive and receive-send. I also tried send and receive. when all four a present, I see the same problem. Not able to figure out why it is being blocked.
sm
RE: Open Port udp 5082 failure - 5.Jun.2003 5:27:00 AM
smarisetty
Let me clarify one more point, the UDP port for incoming accesses are being blocked. I have not seen blocks on any outgoing.
This is how the logs message looks like:
192.246.69.247 63.198.196.228 Udp 5082 11836 BLOCKED 63.198.196.228
sm
RE: Open Port udp 5082 failure - 5.Jun.2003 8:57:00 PM
Hi smarisetty,
the direction receive/send or receive won't help you because they are intended for inbound access (server publishing rules). So, you need to use send/receive or send (unidirectional).
What is the Firewall log telling you? Don't forget to enable the logging of *all* fields in ISA server. In the ISA helpfile there is a section called Firewall and Web Proxy log fields, a must read. Additional information can be found in the article http://support.microsoft.com/default.aspx?scid=kb;en-us;Q284818 .
Have you already restarted the Firewall service on ISA server? Also, is there a relative long time between the send and receive packet?
RE: Open Port udp 5082 failure - 5.Jun.2003 10:46:00 PM
smarisetty
The UDP packets that I see dropped are in-bound from the external IP. I tried the server publishing rule as well.
The firewall log pretty much says that the UDP from an external source Ip is being blocked with the internal source ip of my ISA server.
I did re-start the server after each change. The application that I am try to make work is the sjphone-SIP mode from SJlabs.com. It can be downloaded by anyone for tying out.
When I do a netstat -na, I do see the UDP port bind to the ISA IP, but don't see that this port has LISTENING status.
sm
sm
RE: Open Port udp 5082 failure - 7.Jun.2003 12:19:00 AM
Hi sm,
hmm... it looks like you are trying to define a protocol rule for a complex protocol. Have you already tried to use the H.323 application filter and Gatekeeper, because the product seems to support that? If that does not work, create an open protocol (all IP traffic) and open site&content rule (all destinations, all content) and make sure the Firewall client is installed.
RE: Open Port udp 5082 failure - 8.Jun.2003 7:49:00 AM
smarisetty
Stefaan,
I am trying to get the VOIP work with sjphone from sjlabs.com and a service provided by fwdnet.net.
Not sure what is going on. Tried everyting for days and can't seem to explain what is going on. The VOIP applet works partially.
sm
RE: Open Port udp 5082 failure - 8.Jun.2003 11:29:00 AM
Hi sm,
I have no experience with that product are service, but did you try the H.323 configuration?
Also, in order to get some understanding of how the used protocols are working, install Ethereal on the workstation, place the workstation outside of ISA and capture a session.
Next, make sure the Firewall client is installed on the workstation and you have an open protocol and site&content on the ISA server. Maybe a fresh install of ISA server is recommended too. Verifiy also you have enabled the logging of all fields in ISA server. Now, with the workstation behind ISA, capture again a session. The analysis of both the Ethereal traces and the ISA logs should give you some clue why it is not working.
RE: Open Port udp 5082 failure - 12.Jun.2003 7:57:00 AM
sysadmin
Hi! Sim,
I too had problems setting up Infogate VoIP behind ISA.
I tried other way.
I installed a machine outside ISA, and installed Tiny Personal Firewall on it. Then went configuring the VoIP. Tiny Personal firewall gives out all the things in real time related to any outbound or inbound access with detailed IP address and ports being used to connect.
Using this logs I created appropriate protocol rules and filters and VoIP was working ok.
hope you can apply the same methodology.
Sysadmin
RE: Open Port udp 5082 failure - 12.Jun.2003 8:08:00 PM
Hi Sysadmin,
he has it already working with the Firewall client but he wants to use the SecureNAT client! [Big Grin]
Your methodology has the same goal: determining how the protocol is working and then create the necessary protocol definitions and rules.
BTW --- did you try to use the H.323 features for the VOIP client?
