RE: All user vs Internet group...?!?
RE: All user vs Internet group...?!? - 11.Sep.2005 3:30:00 PM
Hi Al-Taee,
I think you are somewhat confused by the Windows Update issue.
There are some authentication issues in the ActiveX controls used by the Windows Update site. Therefore the KB states that you should allow anonymous access to certain URL's to workaround that limitation.
On the other hand, when you go interactively to the Windows Update site, you must have local adminstrator rights to perform the scanning and the updates. However, when the host is using the Automatic Update feature, the logged in user must *not* have local administrator.
Personally I have no experience with the Symantec Live Update feature, but in general many of the Update features do not support authenticated proxies. Therefore, I suggested you add those sites also to that specific anonymous access rule.
HTH, Stefaan
RE: All user vs Internet group...?!? - 12.Sep.2005 9:35:00 AM
iraq it
Hi Stefaan,
OK, i made this rule and i dont know if my servers will update the windows without any login (i.e. without hitting the Alt+Ctrl+del).
When the host is using the Automatic Update feature, the logged in user must *not* have local administrator.
What thats mean? all my domain clients set the windows update to automatic everyday so is that mean users will get the update even if they dont have local administrator (now assume they login).
I used SAV as a Server / Client and thats solve my problem because the clients got the update from the DC server (SAV Server)without any rule.
Thanks, Al-Taee
RE: All user vs Internet group...?!? - 12.Sep.2005 2:21:00 PM
Hi Al-Taee,
Automatic Update runs as a service. So, nobody need to be logged in and if someone is logged in, he/she must not have administrator rights.
You can check that out in the ISA log. You should see connections to the Windows Update sites. Also, on the internal hosts itself, you can find a file 'WindowsUpdate.log' in the Windows directory. You can there verify if the Automatic Update Agent contacted successfully the Window Update servers.
HTH, Stefaan
RE: All user vs Internet group...?!? - 13.Sep.2005 5:53:00 AM
iraq it
Hi Stefaan,
Its On at all the servers and i will check the log files at the time and see the result.
HTH, Al-Taee
RE: All user vs Internet group...?!? - 14.Sep.2005 5:14:00 AM
iraq it
Hi Stefaan,
I didnt get any access to the windows update access rule and i got these message from one of the server:
2005-09-14 10:01:45 1160 710 Report Uploading 1 events using cached cookie, reporting URL = http://stats.update.microsoft.com/ReportingWebService/ReportingWebService.asmx
2005-09-14 10:02:10 1160 710 Report WARNING: Failed to upload events to the server with hr = c00ce509.
2005-09-14 10:02:10 1160 710 PT WARNING: ReportEventBatch failure, error = 0x80244021, soap client error = 10, soap error code = 0, HTTP status code = 502
2005-09-14 10:02:10 1160 710 Report WARNING: Reporter failed to upload events with hr = 80244021.
And this from another server:
2005-09-14 10:00:09 1176 1ec AU Forced install timer expired for scheduled install
Thanks.
RE: All user vs Internet group...?!? - 14.Sep.2005 12:31:00 PM
iraq it
Stefaan,
For example, the only anonymous access rules should be those you require for server access to the Internet. Since servers typically (and should not) have logged on users, you need to create anonymous access rules to enable or deny connections from these servers (access control for servers is usually done by using source IP address). All other rules should require user authentication from either the Firewall client configuration, Web proxy client configuration, or both.
The 1st part is exactly close to what you said.
Note that another reason why your anonymous access rules are configured for servers only is that servers should not have the Firewall client software installed. Although they can be configured as Web proxy clients, if the servers require Web access when there is no logged on user, an authenticated access rule will cause the serverÆs attempt to connect to the Internet will fail.
I configure my servers as web proxy clients and sometimes I used the Internet for downloading some drivers but now I have anonymous access rules for windows update and the ordinary access rule so is that ok, iam little confuse?
Iam checking my XP client now and i have diffrent logs then in the servers so either the update just release or i have problem in the rules because i didnt see the windows update rule in the logging today, what do you think my freind?
Regards, Al-Taee
RE: All user vs Internet group...?!? - 14.Sep.2005 3:50:00 PM
Hi Al-Taee,
Thanks.
What do you see in the ISA logging?
HTH, Stefaan
RE: All user vs Internet group...?!? - 14.Sep.2005 3:57:00 PM
Hi Al-Taee,
Regards, Al-Taee
In order to use Windows Update you *must* allow anonymous access for those specific sites! So, if all internal servers and clients must be able to do that, *all* of them must have anonymous access to those sites.
Of course, another solution is to implement WSUS ( http://www.microsoft.com/wsus ). In that case, only the WSUS server must have anonymous access to the Windows Update sites.
HTH, Stefaan
RE: All user vs Internet group...?!? - 15.Sep.2005 8:53:00 AM
iraq it
The problem i didnt see my WindowsUpdate access rule in the logging, i check the logging at the time that the update suppose to start but nothing from these servers just some searching for DNS and other issues.
Thanks, Al-Taee
RE: All user vs Internet group...?!? - 15.Sep.2005 5:32:00 PM
Hi Al-Taee,
quote: My rules order are as follows: ISA monitor Publishing SQL 2k3 Anonymous: Protocol:http+https From:Internal To:Windwos sites Action:Allow Apply:All user + Internet users Infrastructure rule Deny website Web access Default rule
Remove the 'Internet users' from the rule. For anonymous access you should use 'All users' only.
HTH, Stefaan [ September 15, 2005, 05:33 PM: Message edited by: spouseele ]
RE: All user vs Internet group...?!? - 15.Sep.2005 5:35:00 PM
Hi Al-Taee,
if you don't find it in the ISA log, then the request is never sent by the client or you have disabled the logging on that rule. So, I suggest you double check rule and the logging.
HTH, Stefaan
RE: All user vs Internet group...?!? - 16.Sep.2005 2:33:00 AM
iraq it
Hi Stefaan,
I will remove the Internet group when i go to work Monday but is this influence the other access rules?
Well, i leave eveything to the defualt settings but i will check the rule and enable the logging if its not mark.
I have a problem with the mail security for exchange server and hope you could give a hint for that.
I installed mail security for the exchange server and before I was able to double click the shortcut and make any configuration I want but (I think) after the Web proxy work and my user become authenticated I couldn't able to open the program even with entering the user name and password thats promoted me for, the program page will still loading for nothing. When I cancel the action or prompt, I got the following page:
You are not authorized to view this page You do not have permission to view this directory or page using the credentials that you supplied. --------------------------------------------------------------------------------
Please try the following:
Contact the Web site administrator if you believe you should be able to view this directory or page. Click the Refresh button to try again with different credentials. HTTP Error 401.1 - Unauthorized: Access is denied due to invalid credentials. Internet Information Services (IIS)
Go to Microsoft Product Support Services and perform a title search for the words HTTP and 401. Open IIS Help, which is accessible in IIS Manager (inetmgr), and search for topics titled Authentica
With this address at the address bar in IE: http://Gci-exch-01:8081/
So do i need to enable a port or protocol because this is the 3rd time i install this program but with the same problem?
Thanks, Al-Taee
RE: All user vs Internet group...?!? - 16.Sep.2005 7:24:00 AM
Hi Al-Taee,
removing the Internet group from the anonymous access rule should not influence the other access rules. Check out my article http://www.isaserver.org/articles/ISA2004_AccessRules.html for more info.
For the exchange issue, I don't know what you are talking about. So, please start a new topic for that issue.
HTH, Stefaan
RE: All user vs Internet group...?!? - 17.Sep.2005 5:27:00 AM
iraq it
Hi Stefaan,
A fast question regarding Tom's article and figure (4):
http://www.isaserver.org/tutorials/2004bestpractices-p1.html
About Configuring local addresses for Direct Access Direct Access allows Web proxy clients to bypass the Web proxy configuration to connect to resources configured for Direct Access.
Do i need to do what appear in figure (4) for windows update sites?
Thanks, Al-Taee
RE: All user vs Internet group...?!? - 18.Sep.2005 5:32:00 AM
iraq it
Hi Stefaan,
How To enable logging for windows update rule?
Nothing happen even with apply the soultion of my last post.
See the log for ISA Server?
Event Type: Error Event Source: Windows Update Agent Event Category: Software Sync Event ID: 16 Date: 9/18/2005 Time: 9:09:07 AM User: N/A Computer: GCI-ISA-01 Description: Unable to Connect: Windows is unable to connect to the automatic updates service and therefore cannot download and install updates according to the set schedule. Windows will continue to try to establish a connection.
One of MS. solutions suggest:
This behavior occurs because the Automatic Update service runs under the Local System account. The Local System account is not a member of the BackOffice Internet Users group and does not have permissions to use the Internet through ISA Server.
And to fix it, follow: http://support.microsoft.com/default.aspx?scid=kb;en-us;838177
I always got this msg. in all my servers in windowsupdate.log: Forced install timer expired for scheduled install
Thanks, Al-Taee
RE: All user vs Internet group...?!? - 18.Sep.2005 2:16:00 PM
Hi Al-Taee,
configuring direct access for the Windows Update sites won't help you. As far as I know, if the Windows update sites are reachable anonymously *and* the Windows Update client can act as a Web Proxy client it should work. Check out http://support.microsoft.com/kb/900935 for more info.
In any case, whether the Windows Update succeed or not, you should see at least the requests in the ISA logging.
BTW --- can you perform a Windows Update interactively (via IE)?
HTH, Stefaan
RE: All user vs Internet group...?!? - 19.Sep.2005 4:57:00 AM
iraq it
Hi Stefaan,
It seems that I will spend my time just solving ISA problems! Yesterday I faced the same problem of All User. I mean I can access the Internet only if I add All User to the Client access rule.
The problem seems strange, I saw that my forwarder DNS server has been changed to 192.168.1.1 & 255.255.255.0 with allowing recursion enabled and thatÆs why I got many error pages and slow Internet services, right? I donÆt know how it changed but I can tell you that during the last week some of my ITs build a DNS server (192.168.1.1) in the lab but it was separate from my network and I donÆt know the relation and how the IP changed.
Now, I put back the right DNS forwarder and disable recursion but I canÆt access the Internet unless I add All User to the rule. I test the auto discovery option with FWCtool and it works but I canÆt get Internet with the error below.
Technical Information (for support personnel) ò Error Code: 502 Proxy Error. The ISA Server denied the specified Uniform Resource Locator (URL). (12202) ò IP Address: 10.127.1.1 ò Date: 9/19/2005 6:06:28 AM ò Server: isa-01.GCI.GOV.IQ ò Source: proxy What I can see that the LAN card that connected to the Internet terminal is not active (no activity) and when I double click on it and close the message of multiple gateway appear even I only put one gateway on this LAN but donÆt appear with All User.
Thanks, Al-Taee
