RE: All user vs Internet group...?!?
RE: All user vs Internet group...?!? - 20.Sep.2005 2:33:00 PM
Hi Al-Taee,
please post the following information *unmodified*: - ipconfig /all on ISA - route print on ISA - ipconfig /all on the internal DNS server - ipconfig /all on an internal workstation
HTH, Stefaan
RE: All user vs Internet group...?!? - 22.Sep.2005 4:01:00 AM
iraq it
Hi Stefaan,
Here are the most important data requested:
Windows IP Configuration
Host Name . . . . . . . . . . . . : gci-isa-01 Primary Dns Suffix . . . . . . . : GCI.GOV.IQ Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : Yes WINS Proxy Enabled. . . . . . . . : Yes DNS Suffix Search List. . . . . . : GCI.GOV.IQ GOV.IQ
Ethernet adapter Internal Network:
Gigabit Server Adapter #2 DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 10.127.1.1 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : 10.127.1.2
Ethernet adapter Internet VSAT:
DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 80.146.156.82 Subnet Mask . . . . . . . . . . . : 255.255.255.240 Default Gateway . . . . . . . . . : 80.146.156.81
- route print on ISA Active Routes: Network Destination Netmask Gateway Interface 0.0.0.0 0.0.0.0 80.146.156.81 80.146.156.82 10.127.1.0 255.255.255.0 10.127.1.1 10.127.1.1 10.127.1.1 255.255.255.255 127.0.0.1 127.0.0.1 10.255.255.255 255.255.255.255 10.127.1.1 10.127.1.1 80.146.156.80 255.255.255.240 80.146.156.82 80.146.156.82 80.146.156.82 255.255.255.255 127.0.0.1 127.0.0.1 80.255.255.255 255.255.255.255 80.146.156.82 80.146.156.82 127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 224.0.0.0 240.0.0.0 10.127.1.1 10.127.1.1 224.0.0.0 240.0.0.0 80.146.156.82 80.146.156.82 255.255.255.255 255.255.255.255 10.127.1.1 10.127.1.1 255.255.255.255 255.255.255.255 80.146.156.82 80.146.156.82 Default Gateway: 80.146.156.81
Host Name . . . . . . . . . . . . : GCI-DC-01 Primary Dns Suffix . . . . . . . : GCI.GOV.IQ Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : GCI.GOV.IQ GOV.IQ
Ethernet adapter Local Area Connection:
DHCP Enabled. . . . . . . . . . . : No IP Address. . . . . . . . . . . . : 10.127.1.2 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 10.127.1.1 DNS Servers . . . . . . . . . . . : 10.127.1.2
- ipconfig /all on an internal workstation Host Name . . . . . . . . . . . . : GCI-001 Primary Dns Suffix . . . . . . . : GCI.GOV.IQ Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : GCI.GOV.IQ GOV.IQ
Ethernet adapter Internet ISA:
Connection-specific DNS Suffix . : GCI.GOV.IQ DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 10.127.1.107 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 10.127.1.1 DHCP Server . . . . . . . . . . . : 10.127.1.2 DNS Servers . . . . . . . . . . . : 10.127.1.2 Lease Obtained. . . . . . . . . . : Thursday, September 22, 2005 9:44:34 A Lease Expires . . . . . . . . . . : Friday, September 30, 2005 9:44:34 AM
By the way, i still able to use Internet without DNS Forwarders and iam able to use the new version of yahoo IM even i have proxy cleints, all you have to do is to change the proxy settings to Firewall with no Proxy! Any comments?
Thanks, Al-Taee
RE: All user vs Internet group...?!? - 22.Sep.2005 6:05:00 PM
Hi Al-Taee,
the IP settings seems all correct to me. That's good!
According to the given info, the only host who could directly resolve external FQDN's is your internal DNS server. All other hosts, including the ISA, are depending on that.
Now, if you have no longer forwarders you shouldn't be able to resolve external FQDN's except if they are still in the cache of the DNS server or the ISA server. So, try some external FQDN's you never tried before.
About the Yahoo IM, I can't comment on that because I don't know the product.
HTH, Stefaan
RE: All user vs Internet group...?!? - 23.Sep.2005 9:18:00 AM
iraq it
Hi Stefaan,
Exactly i agree with you and i cleared the DNS cache many times and also the Client DNS cache and still i can access the Internet. I tried also to use new websites but i can access it. I read some articles in MS. and it seems the DNS recursion is the default option for DNS process and it use root hint if coudnt find the DNS IPs forwarder so any way to know which DNS proess the client use?
The yahoo IM means Yahoo Internet messenger and the new version of it is now working with the ISA 2004 and its was not before!
Thanks, Al-Taee
RE: All user vs Internet group...?!? - 23.Sep.2005 3:55:00 PM
Hi Al-Taee,
if no forwarders are configured then the DNS server will use the root hint file for the resolver process. That means he will contact the Internet DNS root servers and do the whole recursion process by itself. However, if you have configured forwarders then the DNS server will first contact the forwarders and let them do the heavy work.
Now, what will happen if the forwarders are not reachable? That depends on the check box ôDo not use recursionö in the forwarders tab. If that box is *not* checked then the DNS server will switch to the root hint file and regulary check if the forwarders are reachable again. If that box is checked (recommended setting), DNS resolving will no longer work.
So, you'll have to find out first how the DNS resolving is working. In any case, if it goes through the ISA server you should see that in the ISA logging. Otherwise it sounds that your ISA server is not the only exitpoint of your network.
PS: don't forget that a netmon trace on the DNS server can also be very useful.
HTH, Stefaan
RE: All user vs Internet group...?!? - 25.Sep.2005 3:06:00 AM
iraq it
Hi Stefaan,
B]Now, what will happen if the forwarders are not reachable? That depends on the check box ôDo not use recursionö in the forwarders tab. If that box is *not* checked then the DNS server will switch to the root hint file and regulary check if the forwarders are reachable again. If that box is checked (recommended setting.[/B]
I create a filter to my ISP DNS IP and it was working but i remove the DNS IPs forwarder along with allow using recursion and i got results with slow Internet service and with the following IPs for Destination IP for DNS rule.
210.9.72.173 192.115.106.10 193.0.0.195 128.242.107.5 168.143.179.5 209.1.222.247 202.160.241.153 209.1.222.244 62.148.192.154 204.0.99.15 193.210.18.13 62.42.230.163
Then i re-assign the ISP DNS IPs for Forwarder and i didnt get anything in logging regarding DNS untill i clear the cache and i got only some IP requests for DNS forwarder. Also, i remove the forwarder and remain disable recursion and i still got results Hi Stefaan,
Then i re-assign the ISP DNS IPs for Forwarder and i didnt get anything in logging regarding DNS untill i clear the cache and i got only some IP requests for DNS forwarder so what do you think, is it ok?
Can you send me the link to that tool?
Regards, Al-Taee
Can you send me the link to this tool?
Regards, Al-Taee
RE: All user vs Internet group...?!? - 25.Sep.2005 3:09:00 AM
iraq it
Hi Stefaan,
[/B]Now, what will happen if the forwarders are not reachable? That depends on the check box ôDo not use recursionö in the forwarders tab. If that box is *not* checked then the DNS server will switch to the root hint file and regulary check if the forwarders are reachable again. If that box is checked (recommended setting.[/B]
Then i re-assign the ISP DNS IPs for Forwarder and i didnt get anything in logging regarding DNS untill i clear the cache and i got only some IP requests for DNS forwarder. Also, i remove the forwarder and remain disable recursion and i still got results so what do you think, is it ok?
Regards, Al-Taee
RE: All user vs Internet group...?!? - 25.Sep.2005 3:15:00 AM
iraq it
Hi Stefaan,
Now, what will happen if the forwarders are not reachable? That depends on the check box ôDo not use recursionö in the forwarders tab. If that box is *not* checked then the DNS server will switch to the root hint file and regulary check if the forwarders are reachable again. If that box is checked (recommended setting).
Regards, Al-Taee
RE: All user vs Internet group...?!? - 28.Sep.2005 4:25:00 AM
iraq it
Hi Stefaan,
why did you remove the forwarders in the first place? I highly recommend to use your ISP DNS servers as forwarders to do the heavy work.
I didnt remove it, i just said that even if i remove the forwarder the Internet will still continue working.
The Network Monitor tool is a Windows Component included with Windows 2003 (Control Panel -> Add or Remove Programs).
This tool doesnt give a details regarding DNS port and requests.
If you are running on Windows 2000, check out my favorite free and excellent tool Ethereal. For more info, check out http://www.ethereal.com.
I think this tool is better.
Regards, Al-Taee
RE: All user vs Internet group...?!? - 10.Oct.2005 9:07:00 AM
iraq it
Hi Stefaan,
I have more than 50 workgroup computers (Win. 98, Win. ME and Win. XP) distributed in the building. Now, we plan to update Windows, Office, Antivirus program but as you know I have ISA2004 that allow only the Internet group (WP clients) so what's the best solution to do this assuming it will take 2 weeks and I don't want to allow un-authenticated users (All Users).
1 - Join the computers to the domain and use one user to update all the issues above and then they can use the computer using their user. When I update the windows or office with users1 (Domain Admin. User = authenticated) will the users2 (Domain user = un-authenticated to ISA) have the updated things when he login the PC?
2 - Tell me if there is a way to create a rule to allow only a computer administrator to update these issues in the workgroup computers?
Thanks, Al-Taee
