MEMORY ALLOCATION FOR MSDE
All Forums >> [ISA Server 2004 Firewall] >> Logging and Reporting >> MEMORY ALLOCATION FOR MSDE Page: [1]
MEMORY ALLOCATION FOR MSDE - 6.Dec.2005 3:50:28 PM
jogreg
Currently the MSDE process is taking up 1.5 GB of RAM, I checked the allocated memory and is set to the default (2147483647).
What is the recommended amount of memory that should be allocated for MSDE?
In the next few months there will be about 1000 users going through the ISA server. It's only used as a Proxy Server.
Would it make a big difference if a change the web proxy logging to W3c format instead of MSDE??
Thanks in advance
RE: MEMORY ALLOCATION FOR MSDE - 3.Jan.2006 4:29:45 PM
Hi Jo,
Check out:
http://support.microsoft.com/default.aspx?scid=kb;en-us;325003
(in reply to jogreg)
RE: MEMORY ALLOCATION FOR MSDE - 4.Jan.2006 7:47:44 AM
Covani
Hi, the same here.. Use SQL Server 2000 and ISA 2004 Enterprise on same server.
Currently 1.5 GB ram resource only for mssql process, although I have disabled SQL server from services. It runs only the mssql$ for ISA..
any suggestions?
RE: MEMORY ALLOCATION FOR MSDE - 4.Jan.2006 3:09:39 PM
LLigetfa
Do you mean any OTHER suggestions?  What is wrong with the link Tom posted?
(in reply to Covani)
RE: MEMORY ALLOCATION FOR MSDE - 5.Jan.2006 3:31:42 AM
Hi Les,
Thanks for that. I thought I was seeing things and my post actually wasnt' there :)
(in reply to LLigetfa)
RE: MEMORY ALLOCATION FOR MSDE - 5.Jan.2006 3:41:36 AM
Maybe this one will work better:
http://support.microsoft.com/default.aspx?scid=kb;en-us;909636&sd=rss&spid=2108
RE: MEMORY ALLOCATION FOR MSDE - 5.Jan.2006 4:55:11 AM
LLigetfa
Well... if those two links are not enough, one could always use the board search on something as simple as memory msde and get all the threads that have discussed this time and time again.
http://forums.isaserver.org/searchpro.aspx?phrase=msde+memory&author=&forumid=ALL&topicreply=both&message=body&timeframe=%3E&timefilter=0&language=single&top=300&criteria=AND&submitbutton=+OK+
RE: MEMORY ALLOCATION FOR MSDE - 5.Jan.2006 6:26:25 PM
RE: MEMORY ALLOCATION FOR MSDE - 6.Jan.2006 4:10:31 PM
pruittwh
I had the same problem.  MSSQL$MSFW was causing memory threshold alerts (monitoring via NetIQ).  I changed the logging method to W3C file format in an effort to stop ISA from using MSDE.  Admitting my ignorance, is the MSSQL@MSFW service necessary if I'm not logging to an MSDE database?  Microsoft Firewall and SQLAgent$MSFW are both shown as dependencies on this service.  Can I disable the service?  or will it cause the Firewall not to start?  I was guessing that since I'm not logging to an MSDE database, I could solve the memory issue without limiting the amount of memory that the service hogs.  Thoughts?  Comments?
William
RE: MEMORY ALLOCATION FOR MSDE - 6.Jan.2006 4:39:33 PM
Hi William,
You can remove the SQL logging service by rerunning setup from the Add/Remove Programs applet and removing the Advanced Logging feature.
(in reply to pruittwh)
RE: MEMORY ALLOCATION FOR MSDE - 8.Jan.2006 4:30:45 AM
J.F.
Hello:
If you want an easier way to display/edit the amount of memory MSDE can use, get the script named "ISA_MSDE_Max_Memory.vbs" from www.ISAscripts.org.  It doesn't require OSQL.EXE and has just a couple simple command-line switches.
  Cheers,
     JF
RE: MEMORY ALLOCATION FOR MSDE - 8.Jan.2006 3:54:15 PM
Hi Jason,
Thanks! Great link!
BTW -- you have a great site! Come back more often
< Message edited by tshinder -- 8.Jan.2006 3:55:26 PM >
(in reply to J.F.)
RE: MEMORY ALLOCATION FOR MSDE - 9.Jan.2006 12:39:27 AM
J.F.
Thank you!  I've been meaning to drop you a line to say Hello and to say thanks for posting a link to my site in your Links area, but the end of 2005 was *really* busy for me and I just got engaged too     The beginning of the year is always slow for my work, though, so I should have more free time to browse the forums and newsgroups that I like, and your site is the best for ISA of course!
   Cheers!
      JF
RE: MEMORY ALLOCATION FOR MSDE - 9.Jan.2006 7:13:46 PM
Hi Jason,
Thanks for the kind words about the site. We'll create a virtual mutual admiration society :)
I'd be glad to mention your classes/consultation offerings in next month's newsletter. Let me know what you want folks to know.
If you can post on the message boards that would be great! If you want to write some articles and be part of your author's group, send me a note at tshinder@tacteam.net and I'll get you set up and provide you some details.
(in reply to J.F.)
RE: MEMORY ALLOCATION FOR MSDE - 17.Jan.2006 8:43:17 AM
Covani
Hi guys,
Many thanks for the links..
By the way i have decided to leave ISA Server free to have so much memory because:
CAUSE
Microsoft SQL Server uses the available physical memory to optimize MSDE insertion and query processes. SQL Server is designed to release physical memory as soon as there is a request for physical memory from other processes that are running on the computer.
RE: MEMORY ALLOCATION FOR MSDE - 17.Jan.2006 4:00:01 PM
Hi Covani,
Yes, that's why I don't change it. I think most people want to change it because they're not aware of this.
RE: MEMORY ALLOCATION FOR MSDE - 17.Jan.2006 6:54:42 PM
LLigetfa
While this may be considereed scope creep, I capped my MSDE because I was having problems trying to allocate RAM cache.
http://forums.isaserver.org/m_340014500/mpage_1/key_ram%2ccache/tm.htm#340014500
I never did get a clear answer on the board and I cannot remember the details of what I tried.  I don't recall now whether MSDE trumps RAM cache.
RE: MEMORY ALLOCATION FOR MSDE - 17.Jan.2006 6:59:41 PM
LLigetfa
ORIGINAL: tshinder
Yes, that's why I don't change it...
Since you fessed up to running with only 256MB in another thread, I have to wonder how MSDE can even run.
http://forums.isaserver.org/m_2002003649/mpage_1/key_/tm.htm#2002003649
RE: MEMORY ALLOCATION FOR MSDE - 19.Jan.2006 6:31:38 AM
Hi Les,
Runs great. I almost never see my MSDE process run higher than 60MB. I don't know why it *seems* to go haywire on some boxes. I've never seen any of those boxes in person, so I haven't had a chance to troubleshoot the issue.
Post #: 19
