Automate Backup of ISA Config with Script
All Forums >> [ISA Server 2004 Firewall] >> General >> Automate Backup of ISA Config with Script Page: [1]
Automate Backup of ISA Config with Script - 14.Dec.2005 10:14:08 AM
aeropostale
Hi @ all. Does anybody have a script that backups the ISA 2004 Configuration ? Thanks a lot !  Aero P.
RE: Automate Backup of ISA Config with Script - 14.Dec.2005 11:57:59 AM
aeropostale
it seems that i have found a solution on the german isa site http://www.msisafaq.de/ well, i put only the script here, did not have tested yet.will do it today. Aero P.
(in reply to aeropostale)
RE: Automate Backup of ISA Config with Script - 14.Dec.2005 11:58:54 AM
aeropostale
Here's the script  Dim fileName
Dim WSHNetwork
Dim shareName: shareName = WScript.Arguments(0)
Dim xmldom : set xmldom = CreateObject("Msxml2.DOMDocument")
Dim fpc : set fpc = WScript.CreateObject("Fpc.Root")
Dim array : set array = fpc.GetContainingArray
set WSHNetwork = CreateObject("WScript.Network")
fileName=shareName & "\" & WSHNetwork.ComputerName & "-" & Month(Now) & "-" & Day(Now) & "-
" & Year(Now) & ".xml"
array.Export xmldom, 0
xmldom.save(fileName)
RE: Automate Backup of ISA Config with Script - 15.Dec.2005 3:35:24 AM
ClintD
Ise the ISAExportImport utility from the SDK\Samples\Scripts directory on the CD in a batch file.
c:\cscript isaexportimport.vbs e %filename%.xml
RE: Automate Backup of ISA Config with Script - 15.Dec.2005 8:59:03 AM
aeropostale
oh, great.
thx a lot ! on my ISA 2004 CD, this vbs is located on SDK\samples\admin
Aero P.
< Message edited by aeropostale -- 15.Dec.2005 9:03:46 AM >
(in reply to ClintD)
RE: Automate Backup of ISA Config with Script - 15.Dec.2005 1:56:22 PM
nofear
can you explain please
this script,you mentinoed above,how could i apply it?what should i do
please advice
RE: Automate Backup of ISA Config with Script - 15.Dec.2005 2:31:53 PM
ClintD
Tell us what you don't understand about it... it exports the entire ISA configuration into a file named %filename%.xml that you can archive for backup/restore scenarios.
(in reply to nofear)
RE: Automate Backup of ISA Config with Script - 16.Dec.2005 2:50:45 PM
nofear
Fisrt of all
i need to know..
i have an ISA server 2003 standard edition
what should i do to backup its all configuration to XML via your script?
let me guess...i shall write this script to txt file and save it as .vbs
then i will go and copy it to the ISA desktop and doubleclick it
thats it
or shall i modify the script ..and what about the SDK?what shall i do regarding it?
Dim fileName
Dim WSHNetwork
in the script there is (FileName) variable in the first line..shall i change it or what
and in the last line there is also  "xmldom.save(fileName) "..shall i enter any file name or just leave the scripts as is?
RE: Automate Backup of ISA Config with Script - 16.Dec.2005 3:41:45 PM
Ashokk001
Nofear,
You don't need to do anything to the script file. Use the file that ClintD is referring to IsaExport.vbs
you need to copy this file into the isa server and use it like again ClintD mentioned.
cscript c:\isaexport.vbs myisabackup.xml, you can give the filename any name i just used the myisabackup.xml as an example.
Once you got the file created using the above menthod, copy it to your memory stick and archive it or store it anywhere safe. HTH,
Ashok.
RE: Automate Backup of ISA Config with Script - 16.Dec.2005 4:53:01 PM
ClintD
In the cscript command, you have to add the 'e' or the 'i' after the vbs file argument.
Export
cscript c:\isaexport.vbs e myisabackup.xml
Import
cscript c:\isaexport.vbs i myisabackup.xml
(in reply to Ashokk001)
RE: Automate Backup of ISA Config with Script - 19.Dec.2005 10:40:51 AM
nofear
i want to ask final question
As you mentioned above,there is a script in the ISA cd in SDK\SAMPLES\ADMIN\ImportExport.vbs
shall i use this script or the one you mentioned above (listed here below)?
"Dim fileName
Dim WSHNetwork
which one shall i use,,the above one or the one in SDK\SAMPLES\ADMIN\ImportExport.vbs
RE: Automate Backup of ISA Config with Script - 19.Dec.2005 10:53:12 AM
Ashokk001
NOfear,
The script that you included in the post is not tested so you can try that in your test network if you wish but i would use the isaexport.vbs since this is from MS directly and is probably gone through some testing.
Can try both if you want but i would recommend the isaexport.vbs personally
Ashok.
RE: Automate Backup of ISA Config with Script - 19.Dec.2005 11:08:17 AM
nofear
To be sure..you measn the one that is tested and you recommend is the one in script in the ISA cd in SDK\SAMPLES\ADMIN\ImportExport.vbs..right?
RE: Automate Backup of ISA Config with Script - 19.Dec.2005 11:26:29 AM
Ashokk001
Yes
RE: Automate Backup of ISA Config with Script - 19.Dec.2005 12:27:02 PM
nofear
another question
i want to take a weekly backup for my isa configuration.
is there a way so that this script can be run alone every week (lets say each time to save the XML file to c:\isa FOLDER)
so that i can each week backup that folder.
and if yes..is there is a way so that in week one,the script will generate a file called ISA1.xml..in next week he will create ISA2.xml and so on,so that it will not override the xml it created the previous week..in that case i will have copy of my ISA configuration each week (easiest to restore)
thaaaaaaaaaaaanks!!!
< Message edited by nofear -- 19.Dec.2005 12:28:11 PM >
RE: Automate Backup of ISA Config with Script - 19.Dec.2005 2:30:35 PM
nofear
notice
while using the script in the ISA cd in SDK\SAMPLES\ADMIN\ImportExport.vbs ..i noticed the following
When i export the ISA configuration via  the script it gives me XML that its size is somehow smaller (in KB) than when i right click the ISA Server in ISA consol and choose export....this makes me afraid...please advice
RE: Automate Backup of ISA Config with Script - 26.May2006 9:00:11 PM
Bane
Any one have a working script to write a differnt export file for each date? Essentially I want to have the date for that day's config file export reflected in the the filename.
Jamy
RE: Automate Backup of ISA Config with Script - 26.May2006 10:13:33 PM
Yes, check this: http://forums.isaserver.org/m_2002017454/mpage_1/key_/tm.htm#2002017767
plus, u can have an email sent to u whenever the backup is done.
Windows Expert - IT Pro MVP
(in reply to Bane)
