RE: Communicating two private subnets
All Forums >> [ISA Server 2004 General ] >> Server Publishing >> RE: Communicating two private subnets Page: <<   < prev  1 [2]
RE: Communicating two private subnets - 17.Jan.2006 10:41:28 AM
ana_beatriz
HI Tom,
I know about firewall chaining but what I understood what I read on teh documentation about ot is that you have to redirect all request of teh same type to the same firewall and what I need is to route to different firewalls depending on the domain requested.
It is possible to activate different routes for different domains using firewall chaining?
(in reply to ana_beatriz)
Post #: 21
RE: Communicating two private subnets - 17.Jan.2006 4:01:56 PM
Hi Ana,
No, you have to hard code for that.
Are you looking for something like "Policy Based Routing"?
Post #: 22
RE: Communicating two private subnets - 18.Jan.2006 10:44:49 AM
ana_beatriz
Not really because POlicy based Routing is used to communicate the same networks but using different routes; what we want is to communicate different networks based on their domain_names (beacuse all of them have the same internal networkId) the only different between them is the domain_name (domain1, domain2, domain3,...) This is the reason we are interested in examining the application layer, to search for the FQDN of the machine and with the domain name, send the paket to a destination or other.
Then, when the packet arrives to the isa server serving the other network it explores the FQDN and retransmits to the properly internal machine.
I think that it is possible using application filters programmed properly, but I think that it is not possible using only implemented things (maybe with the socksv5 filter that I said to you the other day)
DO you have any other idea?
Thanks a lot,
Ana Beatriz Solana
Post #: 23
RE: Communicating two private subnets - 19.Jan.2006 6:58:19 AM
Hi Ana,
You could do this with publishing rules, both Web and Server Publishing rules.
I sure would like to see an example network diagram of the exact configuration you're trying to accomplish.
Post #: 24
RE: Communicating two private subnets - 19.Jan.2006 12:36:23 PM
ana_beatriz
The exactly situation is the following:
               10.0.0.1     163.10.2.5                  163.158.92.25      10.0.0.1
Domain 1 ------Isa server ----------- Internet ------------isa server------ Domain 2
10.0.0.0/16                                          |                                             10.0.0.0/16
                                                        |  168.56.23.12
                                                  isa server
                                                        |    10.0.0.1
                                                   Domain 3
                                                   10.0.0.0/16
Each of this domains have the same range of IP private addresses and all of their machines can want to communicate with any machine in any other subnet, so it is not possible to make port mapping for all the possible combinations.
The solution could be routing by fqdn because the name of the domains are different, so having different DNS zones we could reach any subnet and internally resolves the IP address, it is like IPNL.
Post #: 25
RE: Communicating two private subnets - 20.Jan.2006 4:33:32 PM
Hi Anna,
Are these AD domains or DNS names?
Post #: 26
RE: Communicating two private subnets - 20.Jan.2006 7:51:03 PM
ana_beatriz
Hi TOm,
Yes, all machines know the domain names of all of the machines (because all machines in the private subnets are called equal but with different domain name. Example: a.domain1, b.domain1  a.domain2,b.domain2   a.domain3,b.domain3)
thanks,
ana bea
Post #: 27
RE: Communicating two private subnets - 21.Jan.2006 3:56:02 PM
Hi Ana,
I'm just trying to figure out if these are only DNS domains, or if you expect AD to coincide with DNS domains?
Post #: 28
RE: Communicating two private subnets - 23.Jan.2006 9:29:26 AM
ana_beatriz
It doesn't really matter us, the only important things is that each domain is server by a differnet DNS server, if tge solution consist on creating different AD, we will think in that possibility.
ana bea
Post #: 29
RE: Communicating two private subnets - 23.Jan.2006 3:03:40 PM
Hi Ana,
OK, in those scenarios I use publishing rules (both Web and Server Publishing Rules) to allow access to remote site networks.
Post #: 30
RE: Communicating two private subnets - 24.Jan.2006 9:37:39 AM
ana_beatriz
Yes, but the problem is that if I want to publish the same protocol for different machine I couldn't use the same port, could I?
So, there is not anything in ISA to perform FQDN routing, isn't there?
ana beatriz
Post #: 31
RE: Communicating two private subnets - 24.Jan.2006 3:20:51 PM
Hi Ana,
Sure you can. You just need to use another IP address.
DNS is responsible for name resolution, so there's no problem with that either.
Make sense?
Post #: 32
RE: Communicating two private subnets - 26.Jan.2006 9:16:32 AM
ana_beatriz
NOt really, because I only have one IP public address to server my private subnet. So my idea was that all traffic from a protocol arrived ISA machine and there, it resolved the DNS name (of destination machines in the private subnet) and sent to it.
ana bea
Post #: 33
RE: Communicating two private subnets - 26.Jan.2006 10:52:58 AM
ana_beatriz
Hi again Tom,
I have another different question now. HOw can I publish a service that it is in teh same machine as ISA Server 2004? I am going to have SBS 2003 installed.
So, I want to publish the service but it is in the public interface, can I use the Server PUblishing rules in a similar way?
ana bea
Post #: 34
RE: Communicating two private subnets - 27.Jan.2006 5:11:40 PM
ORIGINAL: ana_beatriz
ana bea
Hi Ana,
I think you're trying to do something that cannot be done
Post #: 35
RE: Communicating two private subnets - 27.Jan.2006 5:12:47 PM
Hi again Tom,
ana bea
Hi Ana,
Yes, but make sure you use the installation wizards with SBS, because there are many security and configuration compromises made when the ISA firewall software is installed on SBS.
Post #: 36
RE: Communicating two private subnets - 27.Jan.2006 6:14:06 PM
ana_beatriz
Thanks very much for all Tom,
I think we are going to use the configuration with needes services in the same ISA machine, so we were careful.
ana bea
Post #: 37
