RE: Roll up discussion link for posts up to 01-7-2006
RE: Roll up discussion link for posts up to 01-7-2006 - 8.Jan.2006 4:11:36 PM
denli
I haven't a clue. I am however running GFi WebMonitor 3.1.42 on that server. It hasn't crashed any more, but the load is minimal for the moment. I will check it up again when people starts showing up for work tomorrow.
/Dennis
RE: Roll up discussion link for posts up to 01-7-2006 - 8.Jan.2006 6:20:36 PM
Hi Dennis, It might be GFI, but I wouldn't want to blame it without some testing. Keep us up to date on how things work out when the load increases during the work week. Thanks! Tom
RE: Roll up discussion link for posts up to 01-7-2006 - 8.Jan.2006 6:59:07 PM
denli
I also remembered that I've got Collective Software LogHostname 1.0.3 (trialversion) set up on that machine too.
/Dennis
RE: Roll up discussion link for posts up to 01-7-2006 - 9.Jan.2006 1:39:15 PM
denli
I still got problems but the ISA doesn't hang every 3 minutes any more. Restarting the MSDE clears up the problems for a while. I'm thinking of migrating to SQL instead (or perhaps SQL 2005 Express).
/Dennis
RE: Roll up discussion link for posts up to 01-7-2006 - 9.Jan.2006 6:03:41 PM
Hi Dennis, Maybe you could tune the amount of memory used by MSDE, although that shoudn't be required, it might help with the stability issue. Tom
RE: Roll up discussion link for posts up to 01-7-2006 - 9.Jan.2006 9:40:31 PM
denli
Hi Tom, Now it has gone from bad to worse. After uninstalling GFi WebMonitor and Longhostname none of my clients can use HTTPS any more. I'm going to try setting up another member in the array and check if I can replicate the problem with a freshly installed ISA Server.
/Dennis
RE: Roll up discussion link for posts up to 01-7-2006 - 10.Jan.2006 1:49:48 PM
Snojlsky
Curious.. Haven’t used signatures before, afraid it would have too much impact on performance. Anyone that have noticed performance impact when running this? It:s looks like a realy nice script/solution J Best regards
RE: Roll up discussion link for posts up to 01-7-2006 - 11.Jan.2006 4:07:17 PM
Hi Dennis, YIKES! That's very strange that only SSL connections are affected. Let us know what happens with your replication attempt. Thanks! Tom
RE: Roll up discussion link for posts up to 01-7-2006 - 11.Jan.2006 4:28:54 PM
ORIGINAL: Snojlsky Curious.. Haven't used signatures before, afraid it would have too much impact on performance. Anyone that have noticed performance impact when running this? It:s looks like a realy nice script/solution J Best regards Hi Snoj, Depends on how much traffic you have and your current level of processor utilization. You can always backup your config, run the script, and see the effects and if it taxes your processor too much, you can restore the previous config. HTH, Tom
