RE: Fail to install ISA?
RE: Fail to install ISA? - 25.Jan.2006 11:18:29 AM
iraq it
Thanks elmajdal, quote:
here i believe u dont even need an ADC or any trust relation. ADC is a complete copy of ur original DC. if u dont want ur DC to be copied in ur remote sites , then just create another new domain , and establish a site-to-site vpn connection between the two lan. Amazing point here, i dont want to have DC copy at the remote sites but can i achieve the SQL replication between any two sites using the Site-to-site VPN? Well, i think yes because i did the SQL replication without Domain membership, between VPN romaing client and SQL server at the HQ through ISA. If i do with this solution so when do you think i need to have trust between them later? quote:
u dont even need a trust relation between the two lans. when i recommended ADC, i thought u need the exact domain and users to exist in both network . it seems that the remote site doesnot require all that. Yes, separate network will be fair i think. I will need a DNS, DHCP, web proxy clients and other things so it seems the DC copy will not needed. Thanks, Al,
RE: Fail to install ISA? - 25.Jan.2006 4:52:05 PM
hi, then u will never need any DC relation or ADC. good luck in ur network implementation. just establish vpn, and open the required protocols for SQl. Good luck
RE: Fail to install ISA? - 25.Jan.2006 6:57:17 PM
iraq it
Thanks elmajdal for your help. I will deploy the site-to-site VPN and i will use a name near to my original domain name if someday i need a trust between the domains. Al
