RE: ONLY FIREWALL CLIENT
RE: ONLY FIREWALL CLIENT - 28.Jan.2006 6:52:11 PM
Hi Maj, In that case, you could subnet your block and create a route relationship between those addresses and the default External Network. You'll have to inform the router in front of the ISA firewall of those addresses. HTH, Tom
RE: ONLY FIREWALL CLIENT - 28.Jan.2006 6:57:31 PM
majedalanni
Hi If I subnet my network by prefix /29 and in ISA server in configuration --- network --- I add a network with new prefix and then make in network rule a route relastionship with external network and then what I do ???? Thanks
RE: ONLY FIREWALL CLIENT - 28.Jan.2006 7:01:02 PM
majedalanni
And when I creat a network with prefix /29 what type of network I choose Internal network or perimeter or VPN site to site or external network??
RE: ONLY FIREWALL CLIENT - 30.Jan.2006 9:00:25 PM
majedalanni
Hi, I create an internal named (public) network and put in it address of my public and make a route relationship with external and in firewall make a rule alow all from public to external Is that true or I miss somthing????? and in my client what I do ? did I configure his lan with ip from my network named public or what??? Thanks
RE: ONLY FIREWALL CLIENT - 2.Feb.2006 8:17:38 PM
majedalanni
Hi No I just subnet my block and add it in ISA confuguration network and in network rule I make a route rule to external and in firewall rule I alow all protocol from that subnet to external . Is that true ???? If not Can You Tell Me The Steps Please Please MANY THANKS
RE: ONLY FIREWALL CLIENT - 5.Feb.2006 9:05:16 PM
majedalanni
HI I now how subneting but it not work, I Have CCNA cert. but I am not good in ISA Just answer me Can I give my client a public IP not A private If yes how ? Many thanks brothers
RE: ONLY FIREWALL CLIENT - 5.Feb.2006 11:06:54 PM
Status: online
i dont think u can give a client a REAL IP behind and ISa server
RE: ONLY FIREWALL CLIENT - 6.Feb.2006 9:13:29 AM
majedalanni
Hi Ok see what I do I make a network name (Internal_public) and make a route rule to this network to external and put in the fist of rules and in firewall rules I put a rule to allow all protocol from (internal_public) to external but Its not work And in client pc how I configure it . which gateway I gave to it the ISA or My public gatewat? Many thanks and I realy want the answer
RE: ONLY FIREWALL CLIENT - 7.Feb.2006 5:20:30 PM
Hi Maj, First, is this public network connected to a NIC is NOT the NIC used for the default Internal Network? You need three NICs for this to work. Then configure the clients to use the IP address on the DMZ NIC as their default gateway. Then configure the router in front of the ISA firewall with the IP address on the external interface of the ISA firewall as the gateway address to your public address DMZ. HTH, Tom
RE: ONLY FIREWALL CLIENT - 7.Feb.2006 6:08:41 PM
majedalanni
HI I have two NIC One for public and the second for private? Is that work Thanks
RE: ONLY FIREWALL CLIENT - 7.Feb.2006 9:42:46 PM
Hi Maj, You need to add a DMZ interface for this, or put the public address hosts on a network behind a LAN router behind the ISA firewall's internal interface. HTH, Tom
