Trying to find the cause of an error that has started to occur this week seemingly after installing SP2 for ISA2004.
A couple website are now coming back with 502 Proxy error's and will not load. The site I have been testing with is www.mix999.com Below is the error message as reported by the browser. Pretty straight forward setup. ISA is my Default Gateway and runs as a proxy/FW. I have put my machine into a top rule with all access to everything and it is still occuring. Any thoughts on the problem is appreciated.
Technical Information (for support personnel) Error Code: 502 Proxy Error. Not implemented (-2147467263) IP Address: 66.244.221.238 Date: 2/6/2006 5:06:47 PM Server: server13.theorthoticgroup.com Source: web filter
Thanks Kindly for confirming for me LL. I am glad I am not the only one!
Anyone have any suggestions on solving this issue? I have spend a couple of hours poking around ISA trying to understand and figure out what might be causing it. I am not a ISA Pro by any stretch though!
Thanks in Advance,
Mike
ORIGINAL: LLigetfa
I can confirm that I get the same error with my SP2 ISA.
Well I have found a work around.. It appears to be some sort of bug introduced in SP2 in the caching. I disabled caching and the page started working. Re-enabled and it stopped again. So I created a rule to never cache results for this site.
Not a big deal but would love to know why this would happen.
Alright, I tweaked my No-Cache rule again and it seems to be working again.
Here is my rule right now..
To: Domain Name Set - Contains 'www.mix999.com' Cache Store and Retrieval: Only if a valid version exists, and Never, no content will ever be cached HTTP: Uncheck Enable HTTP Caching FTP: Uncheck Enable FTP Caching Advanced: Check Do not cache Objects larger than: 1kb
Working right now... Yesterday I had missed unchecking the Enable HTTP Caching.
I have started seeing the same behavior. Under SP1 there was no issues now I get the dreaded...
Error Code: 502 Proxy Error. The HTTP request includes a non-supported header. Contact your ISA Server administrator. (12156) IP Address: 205.174.16.50 Date: 2/8/2006 4:20:08 PM Server: isasrv.rmhgroup.com Source: proxy
After installing SP2! I am experiencing this on atleast 2 sites know http://www.delta.com and sub pages within http://jefferson.lib.co.us. Where is Tom? We need help... I am about to call M$ and get a ticket started.
Delta problem for me as well.. The jefferson does work on my end though..
Any other sites? Anyone else having problems?
ORIGINAL: tkuskie
look the alerts, and you will see something like "The response was rejectec because....."
The detailed information...
Description: ISA Server was unable to process a response body from /MLB-39125253-placa-de-captura-de-tvfm-encore-com-controle-remoto-nf-_JM because the response was compressed by the ISO-8859-1 method, which is not supported by ISA Server. As a result, the response was discarded. This happens when the server ignores the request from ISA Server for GZIP compression and instead compresses the response with ISO-8859-1.
What is ISO-8859-1 method ??? How can we turn the ISA Server compatible with it ???
Interesting. I will look into this on Monday morning. I wonder if we can figure out what HTTP Server software is doing this. Might help understand the issue a bit more.
Mike
ORIGINAL: ricardobecker
Hey guys, I have a tip...
Mike
We have the same issue. I've followed all of the links posted and found that only delta.com is affected. Delta.com is why I'm looking for a solution. Our company uses delta.com nearly everyday. So I know that this is a direct result of sp2. delta.com worked on friday, sp2 applied saturday, delta.com not working on monday. I've read the documents and post but still do not see a clear solution and tests on the ideas presented still do not deliver delta.com. Any ideas or developments.
I have a support contract with MSFT and asked them about this "The HTTP request includes a non-supported header" issue. It's a known bug in ISA SP2 and there is no known workaround, other than uninstalling SP2. There isn't a MSKB article about it yet or a bug number that they could provide - sorry for the lack of detail.
I'm only commenting on the 'non-supported header' problem - the other issues are probably not related to the issue I talked to our MS rep about.
< Message edited by ClintD -- 13.Feb.2006 4:45:25 PM >
-----Original Message----- From: Jim Harrison [mailto:Jim@isatools.org] Sent: maandag 13 februari 2006 20:51 To: [ISAserver.org Discussion List] Subject: [isalist] RE: ISA 2004 SP2 Http Filter http://www.ISAserver.org
Ok - if you or your customers / family / friends / pets / household gadgets have installed ISA Server 2004 SP2 and are experiencing this "502 http filter blocked" response for sites that work without SP2, please call PSS and provide: - ISAInfo (http://isatools.org/isainfo/isainfo.zip) - network captures at the ISA external interface We're trying to assess the scope of the problem and we can't do that without hard data. ------------------------------------------------------- Jim Harrison MCP(NT4, W2K), A+, Network+, PCG http://isaserver.org/Jim_Harrison/
We installed the SP2 and now receive this same error for at least two sites, delta.com and neucoinc.com when users attempt to use them. I have been reading through the posts here and we have just implemented the cache-disable from above. Will post results when we continue testing.
