RE: Getting 502 proxy error after upgrading to SP2
All Forums >> [ISA Server 2004 Firewall] >> HTTP Filtering >> RE: Getting 502 proxy error after upgrading to SP2 Page: <<   < prev  1 [2] 3 4   next >   >>
RE: Getting 502 proxy error after upgrading to SP2 - 15.Feb.2006 10:36:00 PM
bedpan
The Cache exlusion 'helps' with www.mix999.com but does not seem to help with delta.com. The errors recieved on each are differnt.... It appears to be an issue within the Web Proxy Filter that the Delta Error is coming up (I may be off base on this statement). I suggest you contact PSS to file a ticket. If it proves to be a bug in SP2 I would think they would not charge for support on it.. You may want to verify that prior to opening though.
Mike
ORIGINAL: glanrock
New to the forums!
We installed the SP2 and now receive this same error for at least two sites, delta.com and neucoinc.com when users attempt to use them. I have been reading through the posts here and we have just implemented the cache-disable from above. Will post results when we continue testing.
Any other advice would be appreciated.
John
(in reply to glanrock)
Post #: 21
RE: Getting 502 proxy error after upgrading to SP2 - 16.Feb.2006 7:23:51 PM
dglasgow
We have just found that using http://www.delta.com/home/index.jsp instead of www.delta.com seems to work as a workaround while we wait on MS to issue a fix.
HTH
Doug
(in reply to bedpan)
Post #: 22
RE: Getting 502 proxy error after upgrading to SP2 - 17.Feb.2006 8:08:10 PM
hfernandes2001
Same problem here !!!
I'll contact Microsoft. When i heve some news i post it here !
hfernandes
(in reply to dglasgow)
Post #: 23
RE: Getting 502 proxy error after upgrading to SP2 - 17.Feb.2006 8:26:11 PM
dglasgow
Unfortunately, though the delta workaround gets you in to the home page, you still get the error when you try to search for flights...
(in reply to hfernandes2001)
Post #: 24
RE: Getting 502 proxy error after upgrading to SP2 - 17.Feb.2006 9:19:01 PM
Chuck Brown
This is what I got from MS
Hi Chuck,
There have been some reports of issues with the new compression filter introduced in SP2. Try disabling this filter – in ISA mmc – under Configuration -> Add-ins -> Compression filter. Do this on all machines in the array. Then restart the ISA server control service on each machine in turn.
Jacob
I hope this helps Chuck...
Post #: 25
RE: Getting 502 proxy error after upgrading to SP2 - 17.Feb.2006 9:22:18 PM
dglasgow
Yeah, that does not fix this problem.
(in reply to Chuck Brown)
Post #: 26
RE: Getting 502 proxy error after upgrading to SP2 - 18.Feb.2006 12:54:11 AM
sambo
Glad to see I'm not going crazy.  I ran across the same 502 proxy error this afternoon.  Had the owner of a company who ran up against this breathing down my back this afternoon.  I also discovered the workaround by googling for Delta and then clicking the longer Delta home page URL.  However I had left the office shortly after that so I wonder if this owner tried booking a flight.  Sure I'm going to get the 20 questions treatment next week if he did.
Post #: 27
RE: Getting 502 proxy error after upgrading to SP2 - 19.Feb.2006 11:53:34 AM
JohNEE
This is the one I get - proxy related when visiting http://www.trillian.cc/downloads/browse.php?n=10&c=&s=l&x=21&y=8&t=s: and clicking any of the download links.  I installed ISA 2004 SP2 on Tuesday 14th Feb.  First incidence of the problem.
Error Code: 502 Proxy Error. The HTTP request includes a non-supported header. Contact your ISA Server administrator. (12156) IP Address: 66.216.70.167
Date: 19/02/2006 10:44:18
Server: *******
Source: proxy
Have tried disabling the compression filter as suggested to no effect - I think that is related to the similar web filter error rather than this proxy error.
Oliver.
< Message edited by JohNEE -- 19.Feb.2006 11:54:44 AM >
Post #: 28
RE: Getting 502 proxy error after upgrading to SP2 - 21.Feb.2006 4:29:30 PM
Chuck Brown
Check out this white paper, look toward the bottom, MS is suposed to be working on this,
838365  HTTP compression support in ISA Server 2004
http://support.microsoft.com/default.aspx?scid=kb;EN-US;838365
(in reply to JohNEE)
Post #: 29
RE: Getting 502 proxy error after upgrading to SP2 - 21.Feb.2006 7:09:12 PM
hfernandes2001
ORIGINAL: Chuck Brown
Nope !! I still getting the error !!!
Post #: 30
RE: Getting 502 proxy error after upgrading to SP2 - 21.Feb.2006 10:32:26 PM
RobertSeattle
Is this an ISA 2004 SP2 to ISA 2004 SP2 issue?  I'm getting it as well for www.delta.com too.  Delta Airlines must be pissed!
Post #: 31
RE: Getting 502 proxy error after upgrading to SP2 - 22.Feb.2006 4:22:55 PM
Chuck Brown
I think I'm going to remove SP2 until MS figures this crap out! I starting to get calls from unhappy customers!
(in reply to RobertSeattle)
Post #: 32
RE: Getting 502 proxy error after upgrading to SP2 - 22.Feb.2006 5:21:07 PM
egunther
Have you found a work around to facilitate access to Delta.com?  My users are screaming but I am reluctant to roll back the service pack if there is a simple work around - I just haven't found one yet.
Erich
(in reply to BHarrison)
Post #: 33
RE: Getting 502 proxy error after upgrading to SP2 - 22.Feb.2006 5:24:37 PM
Chuck Brown
Yea, send your users this link http://www.delta.com/home/index.jsp
(in reply to egunther)
Post #: 34
RE: Getting 502 proxy error after upgrading to SP2 - 22.Feb.2006 5:26:39 PM
egunther
That just gets you the home page.  The unsupported header error occurs when you try to log in or search for a flight.  None of the other fixes pustulated work either (like disabling the compression filter).  It looks like I have to roll back the service pack.
Erich
Post #: 35
RE: Getting 502 proxy error after upgrading to SP2 - 23.Feb.2006 6:38:45 PM
Chuck Brown
Well I rolled backed SP2, and everything is back to normal, you have to remove SP2 in add&remove, you need to tick the box that says "show updates". then you will see SP2, Good luck everybody
Post #: 36
RE: Getting 502 proxy error after upgrading to SP2 - 23.Feb.2006 7:37:34 PM
egunther
I did the same and all is well.
Post #: 37
RE: Getting 502 proxy error after upgrading to SP2 - 23.Feb.2006 7:42:02 PM
sambo
Yep, I believe I'm going that route as well until I start seeing some reassurances from Microsoft that this is fully sorted out.
Post #: 38
RE: Getting 502 proxy error after upgrading to SP2 - 28.Feb.2006 5:21:45 AM
Sunny.C
i am having the same problem with www.packardbell.com after installing sevice pack 2.
Post #: 39
RE: Getting 502 proxy error after upgrading to SP2 - 1.Mar.2006 4:38:11 AM
Raice
Same thing at
http://wm.quest.com/Library/getDocument.asp?target=asadafe2
after installing SP2
(in reply to Sunny.C)
Post #: 40
Page:   <<   < prev  1 [2] 3 4   next >   >> << Older Topic    Newer Topic >>
