Conflict Between LAT&Router Address Table
All Forums >> [ISA Server 2000 Misc.] >> Tips & Tricks >> Conflict Between LAT&Router Address Table Page: [1]
Conflict Between LAT&Router Address Table - 13.Feb.2006 8:42:49 AM
adilpiracha
HI all,
i have a problem in my ISA2000 server..more events generated in the event viewer box ERROR is "The ISA Server services cannot create a packet filter 64.233.183.103. This event occurs when there is a conflict between the Local Address Table (LAT) configuration and the Windows 2000 routing table. Check the routing table and the LAT to find the source of the conflict." so i have to clear events after 1hour..kindly solve problem
RE: Conflict Between LAT&Router Address Table - 20.Mar.2006 3:32:14 PM
pnx
I've the same problem with my isa2000.
Internal:
ip 10.0.2.205
sn 255.255.255.0
External:
ip 10.0.1.2
sn 255.255.255.252
ga 10.0.1.1
LAT is:
- from 10.0.2.0 to 10.0.2.255
- from 10.255.255.255 to 10.255.255.255
Where is the problem?
(in reply to adilpiracha)
RE: Conflict Between LAT&Router Address Table - 20.Mar.2006 8:05:13 PM
Hi pnx,
what happens if you remove the entry '10.255.255.255 to 10.255.255.255' from the LAT?
(in reply to pnx)
RE: Conflict Between LAT&Router Address Table - 21.Mar.2006 11:35:57 AM
pnx
Hi Stefann, thanks for help.
I don't know why, but the errors disappeared themself.
I had another problem, now solved, look here:
http://forums.isaserver.org/m_2002011247/mpage_1/key_/tm.htm#2002011329
Could you give me an explanation?
Giuseppe.
(in reply to spouseele)
RE: Conflict Between LAT&Router Address Table - 13.Jun.2006 6:58:06 PM
Titeunic
This is a problem i still have. Any one any ideas ?
The external and internal ipadres are in the same subnet
(in reply to pnx)
RE: Conflict Between LAT&Router Address Table - 13.Jun.2006 10:03:14 PM
pnx
I think internal and external IPs MUST be in different subnets... ;)
(in reply to Titeunic)
RE: Conflict Between LAT&Router Address Table - 2.Aug.2006 11:26:58 PM
Zer0CooL
I'm going off of memory here, but I believe you see those errors if you have the Firewall portion of ISA installed but you only
have one NIC. (and only one network)
If you're just using ISA as a Web Proxy, you don't need the Firewall portion installed.
EDIT: I just saw PNX reply, and that is correct.
"pnx
I think internal and external IPs MUST be in different subnets... ;) "
< Message edited by Zer0CooL -- 2.Aug.2006 11:28:50 PM >
(in reply to pnx)
