RE: Oddball OWA woes
RE: Oddball OWA woes - 5.Mar.2006 6:42:42 PM
jmercer54
Thanks, Tom - I'll create the file and send it to you either today or tomorrow - much appreciated. :) I'm not sure how to get it to you - can't seem to find an email address. The email that's easiest to use right now for me is jmercer@optonline.net, if you want to send me a note so I can reply with the attachment... Thanks again!
< Message edited by jmercer54 -- 5.Mar.2006 6:45:19 PM >
RE: Oddball OWA woes - 7.Mar.2006 7:59:23 PM
jmercer54
Thanks, Tom - it's on it's way! :)
RE: Oddball OWA woes - 13.Mar.2006 4:19:57 PM
jmercer54
Hi, Tom... sorry about that! I'll send it again. I used my ISP's webmail interface to send it, and I don't usually use that, so perhaps I screwed something up. This time I'm going to use my usual Outlook/POP3 interface. Look for an email from jmercer@optonline.net. Thanks again! Jim (PS - it's coming through as an xml attachment, if that makes any difference... thanks!)
< Message edited by jmercer54 -- 13.Mar.2006 4:22:20 PM >
RE: Oddball OWA woes - 13.Mar.2006 5:01:10 PM
jmercer54
Ok - it's on the way... no bounce so far. I also sent a plain email without attachment as a "litmus" just in case something funky is going on with the attachment. Thanks Jim
RE: Oddball OWA woes - 15.Mar.2006 2:14:33 PM
jmercer54
Tom, Thanks for all your help! I really appreciate the hours you spent with me unravelling this mystery - everything is now working 100% correctly! :)
RE: Oddball OWA woes - 2.Apr.2006 10:25:04 PM
jbarsodi
can anyone post the resolution to the problem?
RE: Oddball OWA woes - 3.Apr.2006 6:03:50 PM
jbarsodi
my issue was related to the listener, I cannot tell you how many times I rebuilt the rule.... but when I deleted are recreated the listener it seemed to fixe my "oddball OWA woes"... :)
