RE: Discussion about article on using the ISA firewall to enable selective IM use
RE: Discussion about article on using the ISA firewall ... - 1.Jun.2006 9:30:13 PM
EnriqueFM
Hi Tom: The article is good and full detailed. But I've a problem, in my ISA Server 2004 the mentioned "Filtering" button in protocol dialog is disabled so can't go on with configuration. Do you know the reason? The server is in first configuration, I have two rules for route IP camera traffic, the defaul 'Deny all traffic' rule and a 'Allow all outbound Traffic' added by my self. Thank's PD. I'm in my fist steps with ISA Server.
RE: Discussion about article on using the ISA firewall ... - 4.Jun.2006 5:30:07 PM
Hi Enrique, If the filtering button is disabled, it indicates that the protocol in question doesn't have a filter or if its HTTP, then the HTTP filter might have been unbound. HTH, Tom
RE: Discussion about article on using the ISA firewall ... - 7.Jun.2006 11:59:07 PM
mciftci
Dear Sir, I want some users to reach limited web sites and messenger service. With url sets it is easy to define the sites permitted. But what should i do to give messenger service permission to specific users? Thank you very much for your help in advance.
mciftci
RE: Discussion about article on using the ISA firewall ... - 9.Jun.2006 2:52:44 AM
Hi MCI, You can create a domain name set for those sites and then create an allow rule to that domain name set. HTH, Tom
RE: Discussion about article on using the ISA firewall ... - 9.Jun.2006 10:35:05 AM
mciftci
Dear Sir, Thank you very much for your quick response. At first i thought could not tell the problem. Then i saw the answer is an aspirin. As you adviced, i have created a domain set with the domains below. Everything works well... Maybe it will be usefull for other people. Thanks again. Access Rule: Messenger permission for some users Protocols : HTTP, HTTPS, Msn Messenger. From: Internal To: Domain Name Set (Which includes *.msn.com , *.hotmail.com , *.live.com , *.passport.com) Condition: User Group (Which includes your permitted users) MC
RE: Discussion about article on using the ISA firewall ... - 1.Aug.2006 12:02:32 PM
BedriOzgur
Hello, I have tried the article and it working fine but after making a deep check I saw that some of my users are still able to connect to MSN Messenger network. They were just seting their status to Appear Offline and chatting wjile appearing offline. This is a new feature coming with MSN 8 / Windows Live Messenger. Users using v7.5 were blocked but those who use Windows Live Messenger were not. I tried to enter a new signature for Windows Live Messenger. Exactly the same as MSN Messenger 7.5, but the Name and Signature values are set to Windows Live Messenger. I works great, 20 minutes since I entered the signature and 13th Phone Call from my unhappy users. Hope it helps... Bedri Özgür
RE: Discussion about article on using the ISA firewall ... - 2.Aug.2006 10:18:22 AM
sunlight
Hi, thanks for your articles. I'm wondering.. is this article good for windows LIVE messenger too ? In the past I created a rule to allow MSN Messenger in ISA (and worked fine with msn up to version 7.5) but no more working with msn live messenger. thanks
Discussion about article on using the ISA firewall to e... - 7.Dec.2006 1:47:31 PM
jdaristizabal
Hi Tshinder I follow tour article instructions several times and I don't know why still doesn't work for MSN Messenger 7.5. It just worked for Windows Messenger. I'm trying to implement your article in a Small Business Server 2003 Premium Installation. Could you give me some tips why it is possible that it doesn't work for me? Thank you
Juan
RE: Discussion about article on using the ISA firewall ... - 22.Dec.2006 2:59:51 AM
ivalvin
Hi Tom I've bought your books and I think they are excellent, but I've the same problem as EnriqueFM. My filering button is disabled, and I don't know what do you mean when you say that the HTTP filter might have been unbound. Thanks in advance Israel
RE: Discussion about article on using the ISA firewall ... - 22.Dec.2006 3:26:41 AM
Hi ivalvin, if i am not mistaken , i think you mean the Configure HTTP ? This is caused by you disassociating the Web Proxy filter from the HTTP protocol. In the HTTP protocol that you have in your rule, go into the Toolbox\Protocols and in the properties of that protocol, re-associate the Web Proxy filter.
RE: Discussion about article on using the ISA firewall ... - 22.Dec.2006 3:43:39 AM
ivalvin
Hi Tarek I have tried it and works!! Thank you so much!! Israel
RE: Discussion about article on using the ISA firewall ... - 22.Dec.2006 4:47:51 AM
ORIGINAL: ivalvin Hi Tarek I have tried it and works!! Thank you so much!! Israel Glad it worked, and thanks for the follow up.
RE: Discussion about article on using the ISA firewall ... - 28.May2007 3:11:45 AM
rungroj
Hi Tom I'm using ISA 2006. I can create a new access rule as your procedure but when right on new rule that I created there is no the HTTP policy configulation. Please be advice ASAP Best regards Rungroj
RE: Discussion about article on using the ISA firewall ... - 6.Sep.2007 12:18:49 PM
lovina
It does block MSN Messenger but also block all the http. I only have 5 users so I don't have exception. I just want to block all MSN messenger instead it block all my http and https. What did I do wrong. Or could you tell me how to block MSN only thanks
