My network configuration is Edge Firewall. I have create access rule to allow FW client and SecureNAT Client to access internet as followings : 1. Allow -- Protocol FTP,HTTP,HTTPS,POP3,SMTP -- From Internal -- To External -- Condition All Users 2. Allow -- Protocol FTP,HTTP,HTTPS,POP3,SMTP -- From Internal -- To External -- Condition All Authenticated Users
All FW clients can browse internet, Upload file to FTP Site and receive/send mail. All SecureNAT clients can browse internet, receive/send mail but can't connect to FTP Site.
I have tested both FW Client and SecureNAT Client with CuteFTP . SecureNAT client display these status messages
STATUS:> Getting listing "/pub"... STATUS:> Resolving host name ftp.globalscape.com... STATUS:> Host name ftp.globalscape.com resolved: ip = 64.243.64.21. STATUS:> Connecting to FTP server ftp.globalscape.com:21 (ip = 64.243.64.21)... STATUS:> Socket connected. Waiting for welcome message...
ERROR:> Timeout (60000 ms) occurred on receiving server response.
STATUS:> Waiting 30 seconds...
While FW Clients display these status messages
220 GlobalSCAPE Secure FTP Server (v. 3.0)
STATUS:> Connected. Authenticating...
COMMAND:> USER anonymous
331 Password required for anonymous.
COMMAND:> PASS *****
230 Login OK. Proceed.
STATUS:> Login successful.
Please help me config SecureNAT client to connect to FTP site.
The client opens a primary connection (control connection) to the FTP server.
The ISA Server computer notifies the filter about the connection.
The filter examines the data that is flowing through the primary connection and determines which secondary connection (data connection) the client is going to use.
The filter informs the ISA Server computer to allow that particular secondary connection.
The ISA Server computer opens the specific port, as indicated by the application filter.
Because a SecureNAT client doesn't support secondary connections without the help of an application filter, you are not able to access or publish FTP servers on alternate port ...
Hi elmajdal,
Do you know how to config application filter to help SecureNAT client access External FTP Server ?
FTP is pretty complicated to setup up. Well for me it was.
21 is the initial connector for FTP and this port needs to be mapped, after that, then ftp communicates on the second connection which is 20. This is for active mod.
out of the box ISA server fully supports the FTP protocol for SecureNAT and Firewall clients, including active and passive FTP mode. For Web Proxy clients, that means FTP over HTTP, ISA is CERN Proxy compatible what means only FTP downloads and active or passive FTP mode determined by a global configuration setting on the ISA itself.
I'm sorry for the mistake the actual configuration are 1. Allow -- Protocol FTP,HTTP,HTTPS,POP3,SMTP -- From Authenticated Computer Set -- To External -- Condition All Users 2. Allow -- Protocol FTP,HTTP,HTTPS,POP3,SMTP -- From Internal -- To External -- Condition All Authenticated Users
I need SecureNAT client for non-windows based client such as MAC or Linux Server. I create Authenticated Computer Set for MAC or Linux (ip ranges) and allow them to access internet in Rule #1. For the Rule#2 allow windows based client to access internet. So I would like to solve the FTP problem for SecureNAT client as inform above. Anyone help ?
I'm sorry againg for the mistake. The actual configuration are 1. Allow -- Protocol FTP,HTTP,HTTPS,POP3,SMTP -- From Authenticated Computer Set -- To External -- Condition All Users 2. Allow -- Protocol FTP,HTTP,HTTPS,POP3,SMTP -- From Internal -- To External -- Condition All Authenticated Users
I need SecureNAT client for non-windows based such as MAC or LinuxClient. I create Authenticated Computer Set for MAC or Linux (ip ranges) and allow them to access internet in Rule #1. For the Rule#2 allow windows based client to access internet. So I would like to solve the FTP problem for SecureNAT client as inform above. Anyone help ?
try this to solve this issue, you have to use the "Do not use proxy server for addresses beginning with:" configured to bypass the FTP server's IP address or FQDN name/Domain Name.
this can be found in :
Tools > Internet Options > Connections > LAN Settings > Advanced >
I appreciate that this thread was orginally posted over 4 years ago, but did you ever get to the bottom of the issue? We have a very similar problem at present.
Firewall clients can access external FTP without issue.
However, if we try to connect to an external FTP from a SecureNAT client (Windows Server for example) then the connection to FTP connects, but when you try to authenticate (after you enter the username) to the external FTP server the connection drops with a 'Connection closed by remote host.' error.
Example below:-
C:\Documents and Settings\SomeUser>ftp ftp.someftp.net Connected to ftp.someftp.net. 220-Microsoft FTP Service 220 Welcome to SomeFTP User (ftp.someftp.net:(none)): Connection closed by remote host.
If we install the firewall client on the server then it works fine. However, best practice is to only have your workstations (users) setup as 'Firewall Clients' and have servers as SecureNAT.
