MySQL and Credtool Problems.
All Forums >> [ISA Server 2000 Firewall] >> Firewall Client >> MySQL and Credtool Problems. Page: [1]
MySQL and Credtool Problems. - 25.Apr.2006 5:05:53 PM
iomff
Hi there.
I've been flogging at this for a couple of days but not getting anywhere. Bear with me while I go through the setup and scenario.
The problem is I have a Win98SE machine with PWS installed and the Firewall Client, the database I need to connected to is the other side of the ISA Server on a hosts machine which does allow access.
I can ping the MySQL server, I can telnet into port 3306, I can make an ODBC connection and it connects just fine so I can run things like Crystal Reports on the database. I even wrote a simple VB app using a connection string that accesses the database. The problem is that my lowly Personal Web Server returns the following error:
Microsoft OLE DB Provider for ODBC Drivers error '80004005'
[MySQL][ODBC 3.51 Driver]Can't connect to MySQL server on '111.111.111.111' (10060)
(Obviously I've doctored the IP address, but you get the idea)
I think the problem is that because it is connecting from the PWS it requires anonymous authorisation. Fair enough, just run CredTool.exe and set it up. Unfortunatly I can't. It gives me the following error :
The MSPCUTIL.DLL file is linked to the missing export NTDLL.DLL:RtCreateUnicodeStringFromAsciz.
Has anyone any idea how to proceed so I can build some webpages based on the database?
Daniel.
