ISA Logging problems
All Forums >> [ISA Server 2004 Firewall] >> Logging and Reporting >> ISA Logging problems Page: [1]
ISA Logging problems - 2.May2006 1:27:26 PM
i_pacu
Hy all,
I'm having this problem: ISA Server 2004 does not log the URL in an MS SQL Database. It logs the hostname (like www.yahoo.com) but not the entire URL (like www.yahoo.com/xxx/yyy). anyone had this problem? I mention that ISA Server 2004 SP2 is installed on the machine.
Ionut
RE: ISA Logging problems - 3.May2006 2:29:49 PM
Are you using the Web proxy client configuration?
(in reply to i_pacu)
RE: ISA Logging problems - 10.May2006 3:01:19 PM
i_pacu
Thanks for your answer Tom. It seems that this an issue in ISA Server 2004 SP2. Microsoft does not have an article to manage this problem. So, if you have ISA Server 2004 with SP2 and you log in an MSSQL database hte URL is not logged!!!!
Ionut
RE: ISA Logging problems - 12.Jul.2006 1:50:29 PM
NoneAndOne
Is there anything new on this?  We would like to update to SP2, but certainly don't want to loose uri info
RE: ISA Logging problems - 12.Sep.2006 10:39:06 AM
Boedus
I am using a SQL server to log ISA and I do not have this issue.
In the SQL schema there are 2 fields named :
- DestHost
- uri
DestHost contains the destination host only, such as www.microsoft.com and,
uri contains the full url the guy has visited such as : www.microsoft.com/mcp/learning.asp
I do not know if those fields exists in the MSDE or text logs
(in reply to NoneAndOne)
RE: ISA Logging problems - 18.Oct.2006 10:56:39 AM
cyabu
Are you using SQL Enterprise Manager to view the log?
It has a limit on max chars to show and that might be causing it.
Instead try to use Query Analyzer to view the uri field, setting the max chars per column to 2048 under Options->Results.
hope it helps
(in reply to Boedus)
