IAS - Event 5050
All Forums >> [ISA Server 2004 Firewall] >> VPN >> IAS - Event 5050 Page: [1]
IAS - Event 5050 - 3.May2006 6:04:03 AM
chamann
I am trying to figure out what causes the following event log entrys ..... but so far no luck :-(
Event Type: Information
Event Source: IAS
Event Category: None
Event ID: 5050
Date:  3/05/2006
Time:  3:12:56 p.m.
User:  N/A
Computer: ISA01
Description:
The description for Event ID ( 5050 ) in Source ( IAS ) cannot be found. The local computer may not have the necessary registry information or message DLL files to display messages from a remote computer. You may be able to use the /AUXSOURCE= flag to retrieve this description; see Help and Support for details. The following information is part of the event
The machine is running Windows 2003 SP1 (all hotfixes are installed) and ISA 2004 SP2. It is used as Firewall and Webproxy server.
Any suggestions?
Cheers,
Christoph
RE: IAS - Event 5050 - 3.May2006 2:37:03 PM
Hi Christoph,
Is IAS installed on the ISA firewall?
(in reply to chamann)
RE: IAS - Event 5050 - 4.May2006 12:01:24 AM
chamann
Hi Tom!
No, IAS is not installed on the server.
The machine was member of the domain, put out of the domain, ISA was installed on it and after that we decided to rejoin the machine to the domain :-)
While the machine was not a member of the domain radius was used for authentication but it is no longer used. I turned it of as I am now using AD groups. The Radius server is still defined under "Define radius server".
This error is odd - I found nothing in the MS support database and other people having the error and posted it to newsgroups got no answers :-(
Cheers,
Christoph
RE: IAS - Event 5050 - 4.May2006 8:14:36 PM
Hi Chistoph,
OK, what server?
You only mentioned the ISA firewall, so I assumed that IAS was installed on the firewall.
So there is an IAS server on another machine on the network? Is the firewall configured to use IAS or are there still IAS entries in the firewall configuration?
RE: IAS - Event 5050 - 5.May2006 1:33:45 AM
chamann
Hi Tom!
The IAS was (and still is) running on a server in the "inside" network - IAS was never installed on the machine running ISA server. IAS was used for authentication when the machine was not part of the domain. The firewall is now part of the domain and is using AD groups for authentication. So technically speaking the ISA was only a "IAS client"
Do you think that the error (maybe) occurs because I left the radius server's IP address under "define radius server"?
Cheers,
Christoph
RE: IAS - Event 5050 - 7.May2006 7:03:44 PM
Hi Chistoph,
Could be. Try removing the entry for the RADIUS server and see what happens.
RE: IAS - Event 5050 - 8.May2006 6:27:44 AM
chamann
just tried it (removed the RADIUS server entry) but no luck - the error is still occurring :-(
Cheers,
Christoph
RE: IAS - Event 5050 - 15.May2006 3:27:30 AM
chamann
Hi Tom!
Just an update - the error disappeared but I have no idea why (nothing was changed on the ISA server ...)
Cheers,
Christoph
RE: IAS - Event 5050 - 15.May2006 3:57:12 PM
Hi Chistoph,
Ha! Must be magic
Let us know if it shows up again.
RE: IAS - Event 5050 - 16.May2006 2:05:25 AM
chamann
you asked for it - here it is :-) The error is back - no idea why ....
Cheers,
Christoph
RE: IAS - Event 5050 - 21.May2006 6:17:30 PM
Hi Chrisoph,
ACK! Well, I'd say its a bug or something. If everything else is working, I'd ignore it.
RE: IAS - Event 5050 - 26.Jul.2009 7:18:22 AM
Nov
I know i'm a digger, but disabling user mapping helped me solve this problem. At least this event is showing up in event viewer for about 5 hours
< Message edited by Nov -- 26.Jul.2009 7:21:59 AM >
RE: IAS - Event 5050 - 26.Jul.2009 12:20:05 PM
Ah, that might have been it.
Yes, if you're not using RADIUS, then user mapping isn't required.
Thanks for the followup!
(in reply to Nov)
