Redirect owa.mydomain.com to owa.mydomain.com/exchange
All Forums >> [ISA 2006 General] >> General >> Redirect owa.mydomain.com to owa.mydomain.com/exchange Page: [1] 2   next >   >>
Redirect owa.mydomain.com to owa.mydomain.com/exchange - 7.Jul.2006 7:38:43 PM
marcus2v
I've set up publishing rules for Outlook Web Access and RPC/HTTPs using Tom's superb 4 part article. With ISA 2004 I was able to add an extra path to the OWA publishing rule ("/ redirects to /Exchange\*), but this doesn't seem to work with ISA 2006 (just corrupts the configuration until I delete both OWA/RPC publishing rules and associated objects).
How do I set it up so the https://owa.mydomain.com redirects to https://owa.mydomain.com/exchange ?
Marcus
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 8.Jul.2006 9:49:36 AM
dmatos
Hello Marcus.
I currently use an aspx page on the root to redirect:
1. create a file named redirect.aspx on the root folder for owa.yourdomain.com
2. insert this into the file:
<%@ Page Language="C#" %>
<script runat="server">
private void Page_Load(object sender, System.EventArgs e)
if (Request.ServerVariables["HTTP_HOST"] == "owa.yourdomain.com")
   Response.Redirect("https://owa.yourdomain.com/exchange/",false);
if (Request.ServerVariables["HTTP_HOST"] == "owa.yourdomain.local")
if (Request.ServerVariables["HTTP_HOST"] == "owa")
Response.Write(Request.ServerVariables["HTTP_HOST"]);
</script>
3. set redirect.aspx as a default document with high priority in IIS
4. notice that I have several redirects. I use this asp.net script to allow the users to type owa, owa.yourdomain.local or owa.yourdomain.com, over http or https. it all redirects correctly to the correct https site.
(you need asp.net enabled on the site. I could have used case-statements, but I was just lazy... it works...)
(in reply to marcus2v)
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 9.Jul.2006 6:25:58 PM
Hi Dmatos,
(in reply to dmatos)
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 10.Jul.2006 3:28:51 PM
Chris6
I don't know if this is the right way but I just changed the external path for "/exchange" to "/".
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 10.Jul.2006 4:12:44 PM
Hi Chris,
That's interesting, because I would think that would not work. If someone enters www.domain.com/exchange then they would be redirected to www.domain.com/  which would take them away from /exchange
(in reply to Chris6)
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 24.Aug.2006 5:54:07 PM
jrice
Dmatos
How do you have your paths setup?  I have the redirects working internally but not externally.  I'm assuming it's the "/" to "/exchange\" path that's causing the problem, but I still can't make it work.  any suggestions?
The redirect was creating using the MS article on redirecting OWA.
Thanks.
Rice
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 24.Aug.2006 10:01:32 PM
gja
The way I did is by making another rule blocking traffic to http://www.mydomain.nl with as path "/" and redirect all the traffic to http://www.mydomain.nl/exchange.
And this works very good
(in reply to jrice)
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 24.Aug.2006 10:56:30 PM
Hi G,
That's a very nice tip!
(in reply to gja)
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 9.May2007 8:19:36 AM
whooligan
Hello,
Microsoft has posted a fix for this at http://support.microsoft.com/kb/930415
Terence
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 9.May2007 8:51:55 AM
Hi Wholigan,
(in reply to whooligan)
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 9.May2007 10:31:03 AM
whooligan
Hello Thomas,
Problem we run into is that the redirection still doesn't work.
When typing /owa we get the login page of OWA, but without we get the forms based login from ISA.
When using the latter and logging it we see it loading some things from /8.0.685.24/scripts/premium/ and /8.0.685.24/themes/base/
the outcome is as in the picture below:
Any ideas?
Kind regards,
Terence
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 9.May2007 11:30:10 AM
Is this Exchange 2007? If so, I can't help as I'm boycotting it until they come up with a useable User Interface
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 9.May2007 12:48:37 PM
whooligan
Hello Thomas,
Yes, Exchange 2007
Terence Snijtsheuvel
www.virtuall.nl
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 10.May2007 11:43:55 AM
Hmmm. OK, I'm installing Exchange 2007 now and I'll see what the procedures are. I know there are a LOT of issues with 2007 compared to 2003, so it's going to take a awhile to figure these things out.
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 21.May2007 3:41:20 PM
tiggerspr96
Ok here's how I have configured Redirection to work in ISA 2006:
Configure a new web publishing rule using the wizard
Name the rule if you like "Exchange Redirection", click next
In the "Select Rule Action" window chose "deny", click next
In the "Publishing Type" window choose the publishing scenario that best fits your ISA 2006 implementation.  In my case the default "Publish a single web site or load balancer" was choosen since external GSLB's are being used for load balancing and fault tolerance, click next
In the "Server Connection Security" window choose the level of security that best fits your implementation.  In my case the default "Use SSL to connect to the published Web Server or server farm" was choosen since I am using certificates to deploy SSL, click next
In the "Internal Publishing Details" (part 1) window enter the name of the CAS server and/or it's FQDN as configured in your internal DNS.  You can also enter the CAS server's IP address in case your ISA server cannot resolve the computer name or FQDN.  In my case internal GSLB's are being used to provide a FQDN that will resolves to all the CAS servers in my environment for load balancing and fault tolerance, click next
In the "Internal Publishing Details" (part 2) window enter the path for the folder to be published which is, "exchange" (no quotes), click next
In the "Public Name Details" windows enter the public name or FQDN that your users will use to get to OWA.  For example, webmail.yourcompanyname.com.  Note: your certificate installed on ISA that your weblistener is configured for must have the exact FQDN or redirection will not work, click next
In the "Select Web Listener" window, select the same weblistener from the menu drop down that you used for accessing OWA using "webmail.yourcompanyname.com/owa", click next
In the "Authentication Delagation" window, select from the menu drop down, Basic Authentication Note: This option should be used stricly with having implemented SSL inconjunction.  This method of authentication sends user's credentials in clear text, click next
In the "User Sets" window, accept the default for All Authenticated Users unless your needs demand other wise, click next
You will now be told that the wizard is complete and click finish
Now goto the newly created web access rule you have created and make sure that rule is just above the Exchange Published Rule for access to OWA. If it is not move the rule to the proper location by right clicking on the rule and moving the rule up or down as needed.
Once the rule is in the proper location right click on the rule again and choose properties.  Then choose the "Action" tab and click the check box for "Redirect HTTP requests to this Web Page" and type in the box below the external FQDN of  your OWA website with the following path afterwards, "webmail.yourcompanyname.com/exchange" (no quotes)
Then choose the "Paths" tab and click to highlight the default exchange path and click on the "edit" button on the right.  In the "Path Mapping" window enter "/*" (no quotes) where the "Specify the folder on this Web Site that you want to publish.  To publish the entire Web site, leave this field blank".   Then in the "External Path" field make sure the "The following folder" option is selected and enter "/" (no quotes) in the field just below and click "ok"
The chose the "Application Settings" tab and click to choose "Use customized HTML forms instead of the default" and in the field below "Type the custom HTML form set directory (must exist on all array members):" enter "Exchange" (no quotes), then click "ok"
Finally, do not forget to click "Apply" and not "Discard" above the Firewall Polcy tab and you should not successfully have redirection configured.  Note: do not forget the flush the DNS cache on your client side machines in case they have been resolving to the improper page prior to implementing this new web publishing rule.
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 22.May2007 8:50:43 AM
Hi Tigger,
(in reply to tiggerspr96)
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 23.Mar.2009 2:39:19 PM
chetton2000
Dmatos,
I know this is old, but bear with me as my redirector recently stopped working and it has been 2 years since I set it up so I can't even remember how I set it up.  When you say you have this set up on the root folder, I assume you mean the exchange server itself?  Is this safe?  Does this give direct HTTP access to the exchange server without providing the ISA security?  Anyone else, please provide info as well.  Thanks.
ORIGINAL: dmatos
Hello Marcus.
</script>
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 23.Mar.2009 7:15:12 PM
ORIGINAL: chetton2000
Dmatos,
ORIGINAL: dmatos
Hello Marcus.
</script>
Yeah, this is bad practice as it allows anonymous access to your Exchange server - not good!
(in reply to chetton2000)
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 24.Mar.2009 8:35:46 AM
No need to do that now -- just create a deny rule and then redirect.
Post #: 19
RE: Redirect owa.mydomain.com to owa.mydomain.com/exchange - 2.Apr.2009 5:07:59 PM
chetton2000
ORIGINAL: tshinder
Tom, can you clarify what you mean on this?  Thanks.
Post #: 20
