Access to ISP SMTP server
All Forums >> [ISA Server 2000 General] >> General >> Access to ISP SMTP server Page: [1]
Access to ISP SMTP server - 9.Jul.2006 12:57:58 PM
vikrant1971
I have a ISA 2000 in my LAN, configured in integrated mode.
I am able to receive mails through outlook express using POP but it is not allowing me to send any mails using SMTP.
While I try to send mails it is give the following error:
The connection to the server has failed. Account: 'test', Server: 'smtp.xyz.com', Protocol: SMTP, Port: 25, Secure(SSL): No, Socket Error: 10053, Error Number: 0x800CCC0E.
This was working one month back and there has been no changes in the configuration.
any clues?
while it is also not allowing to have a telnet session to port 25 while i am able to telnet pop.xyz.com 110.
please help.
Regards
Vik
RE: Access to ISP SMTP server - 9.Jul.2006 6:26:40 PM
Hi Vik,
what is the ISA firewall logging telling you? Make sure you have enabled the logging of the fields Rule#1 (Protocol rule) and Rule#2 (Site&cContent rule).
(in reply to vikrant1971)
RE: Access to ISP SMTP server - 10.Jul.2006 11:45:43 AM
vikrant1971
i have enabled the logging.
below is an extract of the file
#Software: Microsoft(R) Internet Security and Acceleration Server 2000
#Version: 1.0
#Date: 2006-07-10 00:00:04
#Fields: c-ip  cs-username c-agent       date          time          s-computername   r-host r-ip   r-port time-taken
10.187.39.20 admin msimn.exe:3:5.2 N 2006-07-10 09:12:12 fwsrv MSISA01  - - 82.178.27.19  25 - - -
cs-bytes sc-bytes cs-protocol cs-transport s-operation sc-status sessionid connectionid
 25 TCP Connect - - - 10053 - SMTP Allow rule 2379 310 smtp.omantel.net.om 82.178.27.19 - - - - - - GHBN - - - 0 - SMTP Allow rule 2379 0
I also have created SMTP packet filer rule inbound and outbound and allowed everything. Still not working.
Please help.
Regards
Vik.
(in reply to spouseele)
RE: Access to ISP SMTP server - 10.Jul.2006 9:12:57 PM
Hi Vik,
are you sure you have posted all the relevant log entries? Where are the fields Rule#1 and Rule#2?
I have tried a smtp connection to that server 'smtp.omantel.net.om'. It didn't work from here either. That could indicate that this is an SMTP relay server who only allows connections from a selected IP range owned by that provider.
BTW --- never mess with the IP packet filters to get an access or publishing rule working. If you have to do that then that indicates something else is wrong.
RE: Access to ISP SMTP server - 11.Jul.2006 1:39:41 PM
vikrant1971
Dear Stefan,
I tried to telnet smtp.omantel.net.om 25 using a dialup conenction while i disabled the local network conenction and was sucessfull.
I am sure it has to do with the firewall rules and filters.
Please  help me in making it work.
Regards
Vikrant
RE: Access to ISP SMTP server - 11.Jul.2006 8:52:01 PM
Hi Vik,
To get the most information out of the logfiles, I strongly recommend to enable the logging of all fields. In the MMC, go to the node Monitoring Configuration, then select Logs. In the details pane, right-click the applicable service and then click Properties. On the Fields tab, click Select All. Also I prefer you post in ISA format because it somewhat more handy to use for me.
RE: Access to ISP SMTP server - 13.Jul.2006 9:10:44 AM
gorbs2002ua
I'm actually having the same issue actually.  I am getting a status 10053 error message in my log file trying to send smtp. Very frustating as it was working previously as well so darned if I know what I've done at this point!!
Here is a copy of the log file line with my log options set to all fields.  I've XXXed the ip address of the smtp server.
192.168.200.4    -    -    N    2006-07-13    06:52:08    fwsrv    SPEEDY_VI    -    -    XX.XXX.XX.XX    25    -    -    -    25    TCP    Connect    -    -    -    10053    -    Allow All    Allow rule    2    9
Greg
RE: Access to ISP SMTP server - 13.Jul.2006 9:18:46 AM
gorbs2002ua
Neeever mind :-)
I looked at one of the older posts and I saw a reference to mcafee and then I sure enough figured out my problems starterd after I threw mcafee on the isa server.  It was blocking port 25.  Disabled that and now I'm functioning like a champ again.
greg
(in reply to gorbs2002ua)
RE: Access to ISP SMTP server - 13.Jul.2006 12:42:52 PM
vikrant1971
hi greg,
Thanks for your post. I just looked and found mcafee is running in the ISA server. Did u completely remove mcafee or disable some it's features. Please do let me know.
Regards
VIk.
RE: Access to ISP SMTP server - 13.Jul.2006 2:36:13 PM
vikrant1971
Hi Guys,
Hurray...It works.
I disabled mass mailing worms on port 25 on the mcafee console of the ISA server.
Now I am able to send mails using the same smtp server.
Stefan and Greg thanks a ton for your support. Without your help it was going to be a failure.
God bless you.
Warm regards and Thanks
Vik.
RE: Access to ISP SMTP server - 13.Jul.2006 9:06:08 PM
Hi Vik,
good to hear you have it working and it was not ISA's fault!
