Dear all,, at the moment I have a problem requesting an URL https://www.test.com:8443 And as a result I receive the following message.
Technical Information (for Support personnel)
Error Code: 502 Proxy Error. The specified Secure Sockets Layer (SSL) port is not allowed. ISA Server is not configured to allow SSL requests from this port. Most Web browsers use port 443 for SSL requests. (12204) IP Address: 10.10.10.5 Date: 8/18/2006 12:55:53 P
My configuration is SBS2003 Premium with SP1. ISA2004 SP2. Can someone help me with a step by step procedure. My experience is not so well with ISA2004 SP2. I suppose I must activate a port? Kind regards,
thx a lot. It'sworking now. Sometimes all the icons comes not up on the screen with a few refreshs is it better. I suppose with a restart of my sbs it will work fine. I let you know.
it's working now but not for the 100%. I make the change with the tunnel port editor. If I call the URL in my browser it take some time. The build of the webpage is slow. Some parts are missing. With a few refreshes I reach the webpage. Then I make few changes on my webpage, again parts are missing. I did a test with bypassing the ISA2004, no problem at all. What goes wrong?
I have no problem accessing that site, at least not the login page. However, I hope they will fix the server certificate!
If you want only to post a very limited number of log entries, just copy and paste them in the post itself. For 'attachments', include in the post an URL were we can download them.
The problem I have is after the logon. Then arise the slow webpages and the missing icons. When I bypass my SBS2003 with an other pc directly connected to the real world there is no problem with the site. What do you mean with the certificate?
all that is a bit chinese for me. I don't understand that the certificate doesn't match the FQDN of the site.
The first time I use the forum I put my msg in a wrong discussion set. Obviously someone has given me a response. See url below. Now I have a second solution. http://forums.isaserver.org/fb.aspx?m=2002024748 I understand you are living in Belgium? Can you give me a call? 0475 808 734.
a port number is represented in two bytes. That means that the port value can range from 0 (x'0000') to 65535 (x'FFFF'). In the other topic the goal of the script is to extend the TunnelPortRange from 1 to 65000. So, nearly all possible ports.
