random requests failing
All Forums >> [ISA 2006 Firewall] >> General >> random requests failing Page: [1]
random requests failing - 30.Aug.2006 7:08:41 PM
CM2005
Hello,
I have 2 ISA2006 EE servers in a load balanced array, everything appears to be working fine except at random (about 2% of the time) a request fails with the following error information from the ISA logs:
Error Information | HTTP Status Code
0x603                |  121
0x603                |  64
I have not been able to find anything anywhere that has shed any light on this problem, any idea what may be the issue?
< Message edited by CM2005 -- 30.Aug.2006 7:14:46 PM >
RE: random requests failing - 4.Sep.2006 4:44:16 PM
Hi CM,
What client type are you using?
(in reply to CM2005)
RE: random requests failing - 5.Sep.2006 10:52:08 PM
CM2005
various clients, but I do have an additional bit of information that may shed light on the problem:
The request in question is retrieving the data in a blob (binary large object bit-array), if we change it to return a string instead the problem goes away.  The problem is the data in the blob format is ~800kb, as a string it is ~2mb which causes a noticeable drop in performance and increased bandwidth usage.  This problem did not exist in ISA2004 EE, so it has to be something that changed
RE: random requests failing - 6.Sep.2006 3:40:18 PM
Jim Harrison
When Tom asks "what client type", he means "are you making SecureNET, Web Proxy or Firewall Client requests?"
Is this traffic SSL?
Typically, you'll see result-code 64 in the web proxy for tunneled SSL traffic because ISA can't "see" the HTTP communications therein (unless you have ClearTunnel, but that's a horse of a different barrel-monkey).
Result-code 121 indicates a "The semaphore timeout period has expired." error; probably indicating the SSL session has died.
What you need to do is grab http://www.microsoft.com/downloads/details.aspx?familyid=D22EC2B9-4CD3-4BB6-91EC-0829E5F84063, install it, and run %ProgramFiles%\Microsoft ISABPA\isabpapack +repro' and follow the instructions.
It'll produce a .cab file on your desktop that contains all the data needed to understand the scenario (if you cause it to happen).
Jim Harrison
MCP(NT4, W2K), A+, Network+, PCG
My ISAServer.org Stuff
My Site
RE: random requests failing - 6.Sep.2006 3:43:03 PM
Hi Jim,
(in reply to Jim Harrison)
RE: random requests failing - 6.Sep.2006 4:02:24 PM
CM2005
I will give that a try and let you know what the results were.
RE: random requests failing - 6.Sep.2006 7:56:52 PM
CM2005
The client type is web proxy, and we are not using ssl.
I ran the tool you suggested,  trying to decipher the information in the cab file currently.
