p2p sharewarez
All Forums >> [ISA 2006 Firewall] >> General >> p2p sharewarez Page: [1]
p2p sharewarez - 8.Sep.2006 11:40:14 PM
mekaneky
Hi ,all
ISA 2006 SE on stand alone 2003 , some clients computers using share wares software as kaza and bitcomet,
these softwares using dynamic random port , so went to firewall client settings and under applications tab i add it as
( BitComet.exe ) and select value to disable.
i still see that application as session in ISA monitoring screen.
how can i stop like these softwares ( take in considartion no AD )
RE: p2p sharewarez - 11.Sep.2006 5:12:13 PM
Hi Mek,
Leave out the file extension when you enter the Firewall client settings for the application name.
(in reply to mekaneky)
RE: p2p sharewarez - 12.Sep.2006 10:58:28 AM
mekaneky
Hi Dr ,
do you mean BearShare instead of BearShare.exe !!!!!
RE: p2p sharewarez - 12.Sep.2006 3:37:44 PM
Hi Mek,
Yes!
RE: p2p sharewarez - 26.Sep.2006 2:54:14 AM
mekaneky
hi dr
i add
BitComet >>> disable
BitComet >>> disable EX
BitComet.exe >>> disable
BitComet.exe >>> disable EX
and even all that it still connect !!!!!!!
RE: p2p sharewarez - 26.Sep.2006 1:15:30 PM
Hi Mek,
Is it connecting via its Firewall client configuration, or its Web proxy or SecureNAT configuration?
RE: p2p sharewarez - 26.Sep.2006 8:24:13 PM
ORIGINAL: mekaneky
hi dr
i add
Removed Them all , except  :
BitComet >>> disable >>> 1
make sure the exe name of this software is BitComet in program files > respective folder
Tarek
Windows Expert - IT Pro MVP
RE: p2p sharewarez - 28.Sep.2006 4:29:20 AM
mekaneky
hi Dr , hi tarek
Is it connecting via its Firewall client configuration, or its Web proxy or SecureNAT configuration? >>> yes as firewall client
BitComet >>> disable >>> 1   <<<< it auto select 0 , have i to make it 1 ???? or let it as zero.??
(in reply to elmajdal)
RE: p2p sharewarez - 28.Sep.2006 10:04:38 AM
understand this :
0 = Off
1= on
right???
So BitComet >>> disable >>> 1
means disabling this BitComet is ON.
so yes make it 1.
Tarek
RE: p2p sharewarez - 30.Sep.2006 2:41:48 AM
mekaneky
hi all ,
thanks dr , thanks tarek.
but i wonder if these applications connect as Snat or proxy can i pervent them ( kindly remember it is work group not domain )
RE: p2p sharewarez - 30.Sep.2006 3:41:52 AM
the best way to block apps is by using siganture to block them :
http://www.isaserver.org/articles/2004blockp2pim.html
HTH
