Publishing OWA to Ex2007
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> Publishing OWA to Ex2007 Page: [1]
Publishing OWA to Ex2007 - 4.Oct.2006 1:31:38 AM
thomforeman
In our test environment we have setup external clients go through an ISA2006 server to get to our test Exchange Server 2007. I have created a rule, following Dr Shinder's How to for setting up the Exchange Web Client rule and the external users can get to the OWA login screen. But no matter what credentials we enter the login screen comes right back and there is a message saying:
"You could not be logged on to ISA Server. Make sure that your domain name, user name, and password are correct, and then try again."
The internal clients can access OWA using HTTPS no problem. If we try to access OWA on the ISA2006 server we get the same bahavior as the external users.
I do not have a lot of ISA experience and think I have set something up incorrectly. If anyone has any ideas I would be very appreciative.
Thom
RE: Publishing OWA to Ex2007 - 6.Oct.2006 12:42:55 AM
thomforeman
After spending hours and hours on this, there were some IP address changes that resolved this problem.
(in reply to thomforeman)
RE: Publishing OWA to Ex2007 - 10.Oct.2006 6:15:56 PM
cabraun
Hi Thom,
Not sure if you are still monitoring this thread, but if so, I was wondering if you could elaborate a bit on the exact resolution.  We are seeing precissly the same behavior and the only difference from your environment and ours, that I can see is you are labbing Ex2007 with ISA2006 and we are labbing Ex2003 with ISA2006.
Everything is fine if we connect via the front end server directly or if we connect via our ISA2004 configuration, but when we set things up with ISA2006 and try to log in via the Form Based Authentication, we just get sent back to the logon screen and are told:
Can you elaborate on what sort of IP Address problems you faced?
Charles
< Message edited by cabraun -- 10.Oct.2006 6:17:33 PM >
RE: Publishing OWA to Ex2007 - 12.Dec.2006 3:17:11 PM
ltfreeng1
Anyone got some more info on this?
(in reply to cabraun)
RE: Publishing OWA to Ex2007 - 13.Dec.2006 10:00:06 AM
mdekker
I'm having this problem also. Error: 12239... Anyone?
(in reply to ltfreeng1)
