RE: ISA 2k6 upgrade and reconfiguring our current config???
All Forums >> [ISA 2006 General] >> Installation and Planning >> RE: ISA 2k6 upgrade and reconfiguring our current config??? Page: <<   < prev  1 [2]
RE: ISA 2k6 upgrade and reconfiguring our current confi... - 4.Dec.2006 9:38:17 AM
Hi Manning,
Hmmmm, looks like my recommendation was fairly strong
(in reply to manning)
Post #: 21
RE: ISA 2k6 upgrade and reconfiguring our current confi... - 5.Dec.2006 10:11:19 AM
manning
Ah, so you did write that. Well, I get the idea from you other articles.
Any thoughts on the Gateway issue I am running into? Is it an issue? Do I need to define the specific address I thought I should be able to use as a gateway in the router's table?
EDIT Let me add that when I run netdiag on the new ISA 2006 server that I am trying to use as the default gateway I do not get a failed result for the gateway test. I do however get a failed result for the DC list test in the global section of the results.
EDIT 2 Well, it helps to check and make sure routing is actually running on the ISA server. Not sure why it wasn't running, but that was why I was getting the gateway error when I tried to use the new server as my default gateway.
< Message edited by manning -- 19.Dec.2006 10:28:34 AM >
Manning
I only do this because I have to.
ISA 2006 standard on Server 2k3 R2
Post #: 22
