Authentication with two domains
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> Authentication with two domains Page: [1]
Authentication with two domains - 10.Oct.2006 11:51:11 AM
boydie1122
Our old Setup:
ISA 2004 in DMZ,  joined to DMZ domain, publishing an internal FE servers OWA that is in the INTERNAL domain.  We have a checkpoing NG firewall in the DMZ and ISA just serves to publish OWA.
Internally we have an Internal Domain and our FE server and two BE servers are joined to it.
We have Basic Authentication and only port 443 between the DMZ and INtenal Networks.
Our New Setup
Is exactly the same only with ISA 2006.  We can access the FBA page but it is not possible to log in.  We I trey Windows Authentication I believe it is trying to authenticate with the DMZ domain.  When I try LDAP authentication and open port 389 on Checkpoint it seems to try and login but never gets there.
Any ideas because this seems like a standard configuration and one 50% of ISA users probably do but it does not work.
THanks,
Nathan
RE: Authentication with two domains - 10.Oct.2006 5:51:53 PM
boydie1122
I think this is an issue of pre-authentication vs straight through authentication that ISA 2004 offered with FBA.  I now have it setup to use LDAP to an internal DC and have opened port 389 on the checkpoint firewall.
The PSS guy tells me that I don't need to setup LDAPS for this to work, but I think he maybe wrong.  What do you guys think?
(in reply to boydie1122)
RE: Authentication with two domains - 10.Oct.2006 7:34:55 PM
Personnaly I would use LDAPS and this is needed is you want to support password changing features.
RE: Authentication with two domains - 12.Oct.2006 12:19:56 AM
boydie1122
The issue was resolved after speaking with the 4th PSS person.  It was ultimately pre-authentication in ISA 2006 that was not required in 2004.  Only 1 of 4 ISA PSS people knew ISA 2004 did not need to pre-authenticate.
I think at one point I probably had all the combination of settings but not together.  We needed to open the LDAP port that we previously had not had to do, and contrary to 1 PSS person you do need LDAP two ways.
The main problem was that we were using the NETBIOS name of the Domain, within the LDAP listener settings, and this is a conflict with the certificate that requires FQDN.  Once we changed the LDAP domain settings to FQDN from Netbios we were able to pre-authenticate.
Anyway this is working in the DMZ domain and is publishing OWA FBA, EAS, OMA and RPC over HTTPs on the same rule with the same listener.  We are using 1 IP address and ISA is behind a firewall with only ports 389 and 443 open to the internal network from ISA in the DMZ.
