upgrading from isa 2004 se to isa 2006 se
All Forums >> [ISA 2006 General] >> Installation and Planning >> upgrading from isa 2004 se to isa 2006 se Page: [1]
upgrading from isa 2004 se to isa 2006 se - 21.Dec.2006 8:42:45 AM
zbrownmd
first thing I read to do is un-install the firewall client share and message screener if installed.
I inherited this server from someone who is no longer with us so I don't know know how it was built.  They're not using the firewall client anywhere on the enterprise.
When I start to upgrade to isa 2006 se, I'm told I need to uninstall the components firewall client share and message screener.
???how do I do that?  I can't verify if one or both has been installed
anyone have any ideas where to uninstall those?
thanks for yer help!
RE: upgrading from isa 2004 se to isa 2006 se - 21.Dec.2006 10:54:03 AM
if u dont know anything, instead of wasting time, go with the following steps:
1- Export your current ISA 2004 Configurations
2- Uninstall ISA 2004
3- Install ISA 2006
4- Import the configuration you exported in step 1 .
Windows Expert - IT Pro MVP
(in reply to zbrownmd)
RE: upgrading from isa 2004 se to isa 2006 se - 4.Jan.2007 12:15:44 PM
kstephens
To uninstall the components firewall client share and message screener is just like uninstalling ISA 2004. Goto the Control Panel, Programs and do a change/remove when it asks you for either Modify, or Remove. If you choose Modify, do a Custom installation and uncheck the FireWall Client and the Message Screener, complete the wizard and then install ISA 2006.
If you get a message concerning ISA Server Storage, installation error. I found the fix on Microsoft Forums :( http://www.microsoft.com/technet/community/newsgroups/server/isa.mspx ), search for ISA Server Storage error and you will find out that you have to remove the server from the Domain, install ISA 2006 and re-join back to Domain after installation completes.
Good luck.
