Exchange Install Listener/Cert Problem
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> Exchange Install Listener/Cert Problem Page: [1]
Exchange Install Listener/Cert Problem - 8.Jan.2007 12:23:38 PM
ksteege
Not sure whats going on here my goal is to get ISA to work for remote Exchange Access - OWA, RPC over HTTPS, and ActiveSync.
I look through My certs and installed the one from my front-end server not problem as I would do with a new FE - I also saw the issue someone had with needing to have the cert in the the personal and trusted root which did not make sense to me but I did it anyway to no avail - when I look through the Cert Store everything looks fine.  However when I go through the Publish Exchange Wizard when I get to the Select Cert everything looks invalid (big red X's) even the server name under Certificate Installation Detials says Local Machine, Personal correctly installed but the Private Key has said either not installed or Private Key handle error.
My other Certs (Verisign) also say invalid there but when I browse to look at them in MMC they look fine...
Thanks in advance.
RE: Exchange Install Listener/Cert Problem - 8.Jan.2007 3:33:57 PM
ksteege
OK my bad - I removed and reinstalled the same cert and the cert shows up properly now.
Sorry for the false alarm
(in reply to ksteege)
