RE: Java Application Fails
All Forums >> [ISA 2006 Publishing] >> Web Publishing >> RE: Java Application Fails Page: <<   < prev  1 [2]
RE: Java Application Fails - 15.May2007 12:30:15 PM
rcitguy
Hello Stephan,
                     No problem and thank you very much for providing the code.
I added this to the .js file and ran it. As expected it added the new agent to the registry  and is now entry 11.
Unfortunately I have the same issue/error.  Basically the applet does not get initiated when using IE & Jre. [works fine with Mozilla or Netscape & jre]
I get this weird Incompatibly magic number value error and then loading the applet failed.
[java.lang.ClassFormatError: Incompatible magic value 1008813135 in class file arcClientJava]
I've tried to get our developers to look at the java 2 client we built to see if it's a compilation issue.
Thanks for your help and suggestions.
Robert
(in reply to sveelen)
Post #: 21
RE: Java Application Fails - 15.May2007 12:39:37 PM
sveelen
You have to make sure the entry is above the mozilla entry because the JRE also starts with mozilla (example: Mozilla/4.0 (Windows XP 5.1) Java/1.6.0)
Use the moveup function to position it above mozilla* and dont forget to update/save it
That should work.
(in reply to rcitguy)
Post #: 22
