Only allow certain web sites....
All Forums >> [ISA 2006 Firewall] >> Access Policies >> Only allow certain web sites.... Page: [1]
Only allow certain web sites.... - 11.Apr.2007 7:54:50 PM
frankenstein897
OK, so I have read the domain sets article:
http://www.isaserver.org/articles/2004domainnamesets.html
But, I am running ISA 2006.  And what I want to do is a little different, I think.  I only want to allow certain webs through ISA, nothing else.  We will not allow any other people differnt access.  So, I would prefer that all authenticated users be denied access to all web sites except a small list of web sites.  I have tried to create rules to make this happen but, I either get every site blocked or every site allowed.  I think I am missing something.
RE: Only allow certain web sites.... - 12.Apr.2007 1:29:50 AM
what rules do u have on your ISA server ??
Windows Expert - IT Pro MVP
(in reply to frankenstein897)
RE: Only allow certain web sites.... - 12.Apr.2007 8:21:39 AM
frankenstein897
Just the default deny all rule right now because nothing else is working :-).  This is a new install.
(in reply to elmajdal)
RE: Only allow certain web sites.... - 12.Apr.2007 8:34:18 AM
Let start with a basic rule first :
create a new rule :
Action: Allow
Protocols :  HTTP & HTTPS
To : External
Users : All Users
Can you users now surf the internet ??
If the answer is Yes, then lets do some changes in the above rule.
We will replace the External  Network in the TO,  with a Domain Name Set .
Create a new Domain Name set, and include in it the sites you want to allow your users to surf to, name it for example AllowedSites
now your rule should look like this :
Action: Allow
To : AllowedSites
Users : All Users
Tarek
RE: Only allow certain web sites.... - 12.Apr.2007 9:13:36 AM
frankenstein897
OK, it must be something with the setup of my ISA server because I do that and the first part works, I can get to any web site without issue.  But, as soon as I replace the TO with domain name set of the web sites I put in there I can't get to anything.  I am going to go back and look at the configuration and see if I have something messed up.  Thanks, I thought that was how you do it, I just wanted to make sure I wasn't doing something wrong.
Chris
RE: Only allow certain web sites.... - 12.Apr.2007 11:20:00 AM
mmm, did u try using Computer Set instead of Domain Name Set.
Maybe its a name resolution problem .
Create a New Computer Set and start populating it with the IPs of the URLs u want to allow and check if this will work.
RE: Only allow certain web sites.... - 12.Apr.2007 3:30:54 PM
frankenstein897
I will try that.  Thanks!
RE: Only allow certain web sites.... - 16.Apr.2007 3:22:35 PM
frankenstein897
Yep, you were right.  It must be a DNS thing becuase when I create a computer set and allow only those IPs it works.  Thanks.
RE: Only allow certain web sites.... - 16.Apr.2007 3:31:31 PM
Thats Greate !!
Thanks For the follow up.
now check this article : http://elmajdal.net/isaserver/Internal_DNS_Forwarding.aspx
Tarek.
RE: Only allow certain web sites.... - 16.Apr.2007 4:19:28 PM
frankenstein897
Great article.  Thank you!
RE: Only allow certain web sites.... - 16.Apr.2007 4:30:03 PM
You are most welcome.
