Problems authenticating to external websites through ISA 2006
All Forums >> [ISA 2006 Firewall] >> General >> Problems authenticating to external websites through ISA 2006 Page: [1]
Problems authenticating to external websites through IS... - 25.Apr.2007 7:52:15 PM
it_support@pei.ac.nz
I am a technician at an educational institute that has been put in charge of an issue that we a currently have in regards to web authentication. We have just recently upgraded to ISA 2006 from ISA 2004 and we are running it on a DL320 with windows 2003 server. Some of our users are experiencing an authentication issue where the ISA continues to ask them for credentials for each item that loads on a page.
I found the identical symptom at http://support.microsoft.com/kb/886996 however, it did not offer a solution to solving the problem if the site is an external site and not one published by you.
How do I get ISA to quit asking the user for authentication to the external website?
Any help would be most appreciated
RE: Problems authenticating to external websites throug... - 28.Apr.2007 12:45:36 PM
There is a registry entry that is something like ReturnAuthIfAuthenticated that will fixed this problem. Looks through my blog postings from the last month or so and you will find it.
(in reply to it_support@pei.ac.nz)
RE: Problems authenticating to external websites throug... - 29.Apr.2007 7:23:31 PM
Hello Tom,
Thanks for you post.  I had a look at your blog back to January 2007 and could only find one article related to authentication.  It was "Getting Prompted for Authentication When You Enable Firewall Client and Web Proxy Client Autodiscovery?".  I went to the related Microsoft link and it did not relate to the problem I had posted. Am I looking in the wrong place?
Cameron
RE: Problems authenticating to external websites throug... - 1.May2007 7:19:34 AM
Hi Cameron,
Yes, that's the one. Make that Registry change and see if that fixes it for you.
RE: Problems authenticating to external websites throug... - 8.May2007 3:59:37 AM
kulwinder
Hi tom,
I am new to this forum and i need your help. As per the reply by cameron i could not find any microsoft link or any thing related in january 2007 blog to solve my "authentication problem". kindly assist
Kulwinder
RE: Problems authenticating to external websites throug... - 8.May2007 3:08:42 PM
Hi Kulwinder,
http://support.microsoft.com/kb/885683
(in reply to kulwinder)
RE: Problems authenticating to external websites throug... - 8.May2007 5:28:14 PM
We are running ISA 2006 and we do not use an ISA client.  Do you think that fix will still work?  The fix says that modifying your registry can cause irreparable damage so I am being cautious.
Kind regards,
Cameron Mottus, B.Ed, A+, LPIC-1
IT Systems Engineer
Kind Regards,
Cameron Mottus,
IT Systems Engineer
Practical Education Institute
RE: Problems authenticating to external websites throug... - 8.May2007 7:56:46 PM
Hi Cameron,
The change is safe and won't break anything.
RE: Problems authenticating to external websites throug... - 9.May2007 7:13:49 AM
Laura_II
Hi, I have the same problem too
Users that can surf on the web are asked for credentials, for example, when the site have streaming videos.
I followed
and
http://support.microsoft.com/kb/889035
but doesn't work
I have only 3 rules (ISA 2006 Standard):
1.- DNS from Internal to External (all users)
2.- POP3 and SMTP from Internal to External (group called MailUsers)
3.- HTTP and HTTPS from Internal to External (group called WebUsers)
Any help will be greatly appreciated
RE: Problems authenticating to external websites throug... - 9.May2007 8:53:38 AM
Hi Laura,
Is the Firewall client installed and working correctly?
(in reply to Laura_II)
RE: Problems authenticating to external websites throug... - 9.May2007 9:33:52 AM
Laura_II
Hi Tom
I guess, the firewall client icon (with a green arrow) is on the taskbar tray.
RE: Problems authenticating to external websites throug... - 9.May2007 11:15:16 AM
Hi Laura,
OK. Is the Web browser configured to use integrated authentication?
RE: Problems authenticating to external websites throug... - 9.May2007 12:24:25 PM
Laura_II
Hi Tom
Yes, only integrated authentication is enabled. And "Require all users to authenticate" is disabled.
RE: Problems authenticating to external websites throug... - 9.May2007 12:24:26 PM
Laura_II
Hi Tom
RE: Problems authenticating to external websites throug... - 9.May2007 12:24:48 PM
Laura_II
Hi Tom
RE: Problems authenticating to external websites throug... - 9.May2007 12:29:49 PM
In the User Accounts dialog box on the clients, click the Manage Passwords button and clear out the password cache and see if that helps.
RE: Problems authenticating to external websites throug... - 10.May2007 5:32:37 AM
Laura_II
I do it, but nothing has changed
Finally I decided to change my strategy.
I saved my current firewall policies and I run the network template again and selected Edge firewall and "Allow limited Web access, allow ISP network services" instead "Block all".
Now users can see videos but credentials aren't asked
RE: Problems authenticating to external websites throug... - 10.May2007 10:05:19 AM
That is good! Since the ISA Firewall is a domain member and and the clients are configured as Web proxy and Firewall clients, you don't want to ask for credentails.
Create an "all open" rule that applies only to authenticated users and put that above the rule the template created.
