Single ISA2006 std edt - OWA & Outlook Anywhere rules problems
All Forums >> [ISA 2006 Publishing] >> Exchange Publishing >> Single ISA2006 std edt - OWA & Outlook Anywhere rules problems Page: [1]
Single ISA2006 std edt - OWA & Outlook Anywhere rules p... - 27.Jun.2007 4:17:57 PM
patelbg2002
HI
I'm currently looking at implementing Outlook Anywhere and Outlook Web
Access within my company as a part of our Exchange 2007 deployment.
I have setup two client access servers and NLB to a single IP Address
192.168.1.200
Created a forward lookup zone called companyname.com
Added an A record "mail" - mail.companyname.com and associated to IP
address 192.168.1.200
I have created a single SSL Certificate mail.companyname.com
I have added the certificate to both CAS servers.
URL (Internal and External) for Outlook Anywhere is mail.company.com
URL (Internal and External) for OWA is mail.company.com/owa
I have a single ISA 2006 standard edition server
Added the SSL cert into the personal directory and trusted third party
I create a rule for OWA using the ISA wizard, web listener is
authenticating using HTML Form Authentication - Works no problem
When I to try and create an Outlook Anywhere rule via the wizard....
and create a Web Listener to use HTML Authentication - I get the
following ISA error
A Web listener specifying the same port and similar IP addresses is
already used by rule "Outlook Web Access".  The port and IP addresses
specified in a Web listener cannot overlap with the IP addresses and
ports specified in another Web listener already used in a different
rule.
Is there an alternative to get both rules working on the same ISA box?
Or do I need another ISA server to process requests for Outlook
Anywhere,
Or Possibly Another CAS server specifically for OWA changing the Default
Web Directory to process SSL on port 444??
Any ideas / help would be gratefully received
Best Regards
B
RE: Single ISA2006 std edt - OWA & Outlook Anywhere rul... - 28.Jun.2007 10:18:01 AM
If you have two CAS machines, then you should be using ISA Firewall Web Farm Load Balancing and not NLB on the CAS machines.
(in reply to patelbg2002)
