RSS |
Can't download zip/exe files
Can't download zip/exe files - 6.Aug.2007 11:53:07 PM
auchanaka1980
hi, i have installed the ISA server 2006 std editon, so before i used the isa server 2004 it's work without any problem. my problem is now i can't download the zip file/exes like that file. i don't know why. and browing is also slow. give me ur support. top urgent
RE: Can't download zip/exe files - 7.Aug.2007 1:06:18 AM
mzakir
are u using any web filters application with ISA ? what's ur DNS settings?
_____________________________ Malek Zakir MCP,MCSA:Security,MCSA:Messaging,MCTS,CCNA,DCH
RE: Can't download zip/exe files - 7.Aug.2007 5:33:18 AM
auchanaka1980
yes, i'm using the surfcontrol web filter version 5.5. but if i stop that service still the same. i uninstalled the surfcontrol.. i have a internal dns server with our main active directory. from there i forward the to ISP. if i run he nslookup from my cleint i can resolve the dns. Microsoft Windows [Version 5.2.3790] (C) Copyright 1985-2003 Microsoft Corp. C:\Documents and Settings\namal.****>nslookup Default Server: chipp.****.com Address: 192.168.187.1 > google.com Server: chipp.****.com Address: 192.168.187.1 DNS request timed out. timeout was 2 seconds. *** Request to chipp.****.com timed-out > google.com Server: chipp.****.com Address: 192.168.187.1 DNS request timed out. timeout was 2 seconds. *** Request to chipp.****.com timed-out > google.com Server: chipp.****.com Address: 192.168.187.1 DNS request timed out. timeout was 2 seconds. *** Request to chipp.****.com timed-out > google.com Server: chipp.****.com Address: 192.168.187.1 Non-authoritative answer: Name: google.com Addresses: 72.14.207.99, 64.233.187.99, 64.233.167.99 my isa server pc ip looks like, lan card. 192.168.187.200 255.255.255.0 DNS: 192.168.187.1/192.168.187.2 WAN card IP :203.143.***.*** 255.255.255.248 gateway:203.143.**.** ISP DNS isa rule is rule number 2 : forward to ISP Allow--DNS---chipp---external---all users i'm waiting your help.
RE: Can't download zip/exe files - 7.Aug.2007 5:55:51 AM
mzakir
For zip/exe prob. pls check your settings in surfcontrol & in http filter. What's ur client type where you are facing slow internet problem ?
RE: Can't download zip/exe files - 7.Aug.2007 6:42:13 AM
auchanaka1980
surfcontrol is uninstalled. no more. client are firewall/web proxy. both types have the problem.
RE: Can't download zip/exe files - 7.Aug.2007 7:08:29 AM
quote: WAN card IP :203.143.***.*** 255.255.255.248 gateway:203.143.**.** ISP DNS Never put a DNS on your External Card !
_____________________________ Tarek Majdalani Windows Expert - IT Pro MVP Facebook : https://www.facebook.com/ElMajdal.Net
RE: Can't download zip/exe files - 7.Aug.2007 8:54:49 AM
auchanaka1980
i removed dns from the WAN card . still i have the problem.
RE: Can't download zip/exe files - 8.Aug.2007 8:01:26 AM
auchanaka1980
Still surfing is slow compare to ISA SERVER 2004. any idea why is that. i'm waiting your support.
RE: Can't download zip/exe files - 8.Aug.2007 8:07:10 AM
mzakir
What's ur client types ?
RE: Can't download zip/exe files - 8.Aug.2007 8:24:24 AM
quote: ORIGINAL: auchanaka1980 surfcontrol is uninstalled. no more. client are firewall/web proxy. both types have the problem. Right click Every HTTP Rule, Configure HTTP and then check if you have any filtering applied, such as extension / signature ... or even, check the Logging tab under Monitoring Node, and see what RULE is blocking the download of these files, then you will have a better idea. HTH, Tarek
New Messages
No New Messages
Hot Topic w/ New Messages
Hot Topic w/o New Messages
Locked w/ New Messages
Locked w/o New Messages
Post New Thread Reply to Message Post New Poll Submit Vote Delete My Own Post Delete My Own Thread Rate Posts
